    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.5m Views 345 Watching
    • fredo6F
      @cadfather said:
      Hi Fredo - just to let you know, after replacing the file 'FreeScale_Common.rb' the tool stops working
      it's not a big deal though - whenever you stumble upon it..
      It works for me. Could you redownload it and try again.
      Just in case, here is the version I use:
      By the way, does it do what it is suppose to do, that is remove the separators in the toolbar?
      [Edit] See this post http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948&p=158953#p158953
      • CadFatherC
        CadFather
        fantastico Fredo - it works! ☀
        • H
          hansschatz
          Thank you! It's very useful!
          • fredo6F
            NEW VERSION 2.0g NOW RELEASED
            IMPORTANT: I decided to change the name of this plugin, as the previous name could create confusion with an existing company and infringe their trademark. Please use now the new name FredoScale when referring to this plugin.
            This version is identical to the previous one 2.0f, except the possibility to configure the toolbar without separators (a request from CadFather). The option can be selected in the Default Parameter dialog box.
            See main post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948&st=0&sk=t&sd=a#p144180
            It works with the current LibFredo6 3.1f
            • COSEDIMARCOC
              COSEDIMARCO
              Updated the Italian Translation File
              Italian Translation of FredoScale 2.0g
              [floatl:2wjeiugn]COSEDIMARCO - The Website[/floatl:2wjeiugn]
                Can the old Freescale folders be deleted?
                • Jean-FrancoJ
                  Jean-Franco
                  Yes, I did it and it works, no problem.
                  Jean-Franco
                  • utilerU
                    utiler
                    The reason for my latest posts, Thom.
                    404 Not Found
                    (www.sketchucation.com)
                    Just Curious...
                    • fredo6F
                      Yes, in general you can safely erase the subfolder (here FREESCALE_Dir_20) once you have installed a more recent version.
                      • david_hD
                        david_h
                        Anybody else having a problem getting the install to work? Mine deosn't show up. The old one worked fine. .. but the new one. . .nuthin'.
                        EDITGot it figgered out. Crisis averted. 😄
                        • marleusM
                          marleus
                          THANK YOU Fredo!!!!!!
                          You're brilliant.
                          Finally I get my chair seats right 👍
                          Markus Sillander
                          Vantaa, Finland
                          I'm on FormFonts now
                          http://www.formfonts.com
                            Marinho
                            Hi Fredo, morning, meu name is Marinho, and I live in Luciara, Mato Grosso state, Brasil (nearly 11°30'00"S - 50°30'00"W at side of Araguaia River). I want you if you can send me please the your famous plugin, now with changed name, FREDOSCALE 2.0f. I use the Sketchup 6.0 and lake very match can use this plugin.I dont find it to download in anyplace in internet.
                            Tanks a lot,
                            Best regards
                            Marinho.
                              Tanks a lot,
                              Best regards
                              Marinho.
                              Check the first post of this thread: http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948#p144180
                                Marinho
                                Hi Thomthom, I checked the link viewtopic.php?f=180&t=17948#p144180 but I dont find nothing about download FredScale 2.0g. Am I wrong? 😠
                                Tanks,...
                                  At the end of the post, there's a little box saying "Attachments" - In that there's a link "FredoScale 2.0g.zip"
                                    Download link is here:
                                    http://www.sketchucation.com/forums/scf/download/file.php?id=27660
                                      mics_54
                                        Marinho
                                        Hi Thomthom, Hi TIG, tanks... but I am litle craze.... I have password
                                        for the two... forun and site Sketchucation, but when I see "FredoScale
                                        2.gf to download to unzip (via SELECT ALU in Sketchup Plugins folder
                                        (731.49 KB) and I click it, I receive the notice "you are not....." and
                                        in this page, there are not place to login. TIG, tanks you for the
                                        direct link to download, but the same things, I am going to a place
                                        where I dont can log me. I am completly lost. The same with the links of
                                        tutorials in home page of Sketchucation. Links where I dont have
                                        acess to login,even though, I have the passwords. Sorry, but I need nost help.
                                        Tanks
                                        Marinho.
                                        • GaieusG
                                          Hi Marinho,
                                          You need not register/log in on the main site of SketchUcation at all. All tutorials can be freely viewed without logging in.
                                          The only place you need to log in (to se and download attachments) is the forum.Please, let me know if you have problems with that.
                                            Marinho
                                            Hi every people, tanks a lot. Gaieus, for instance: now I clik in link above from TIG "download/file.php?id=27660";imediatyle I see a new page whit the message: " INFORMATION - you are not authorised to download this attachment" Way? I am loged at forum. Way I canot download the file?
                                            Tanks,
                                            Marinho 😳
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 58
                                            • 59
                                            • 15 / 59
