    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.5m Views 345 Watching
    • fredo6F
      @cadfather said:
      Hi Fredo
      what are the chances i can remove the separators from the icons toolbar?
      Drop the attached file into the FREESCALE_Dir_20 folder.
      Then restart Sketchup, set the option in the Default Parameters dialog box, and then restart sketchup again.
      to drop into FREESCALE_Dir_20 subfolder
      • fredo6F
        @cadfather said:
        Hi Fredo - just to let you know, after replacing the file 'FreeScale_Common.rb' the tool stops working
        it's not a big deal though - whenever you stumble upon it..
        It works for me. Could you redownload it and try again.
        Just in case, here is the version I use:
        By the way, does it do what it is suppose to do, that is remove the separators in the toolbar?
        [Edit] See this post http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948&p=158953#p158953
        • CadFatherC
          CadFather
          fantastico Fredo - it works! ☀
          • H
            hansschatz
            Thank you! It's very useful!
            • fredo6F
              NEW VERSION 2.0g NOW RELEASED
              IMPORTANT: I decided to change the name of this plugin, as the previous name could create confusion with an existing company and infringe their trademark. Please use now the new name FredoScale when referring to this plugin.
              This version is identical to the previous one 2.0f, except the possibility to configure the toolbar without separators (a request from CadFather). The option can be selected in the Default Parameter dialog box.
              See main post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948&st=0&sk=t&sd=a#p144180
              It works with the current LibFredo6 3.1f
              • COSEDIMARCOC
                COSEDIMARCO
                Updated the Italian Translation File
                Italian Translation of FredoScale 2.0g
                [floatl:2wjeiugn]COSEDIMARCO - The Website[/floatl:2wjeiugn]
                  Can the old Freescale folders be deleted?
                  • Jean-FrancoJ
                    Jean-Franco
                    Yes, I did it and it works, no problem.
                    Jean-Franco
                    • utilerU
                      utiler
                      The reason for my latest posts, Thom.
                      404 Not Found
                      (www.sketchucation.com)
                      Just Curious...
                      • fredo6F
                        Yes, in general you can safely erase the subfolder (here FREESCALE_Dir_20) once you have installed a more recent version.
                        • david_hD
                          david_h
                          Anybody else having a problem getting the install to work? Mine deosn't show up. The old one worked fine. .. but the new one. . .nuthin'.
                          EDITGot it figgered out. Crisis averted. 😄
                          • marleusM
                            marleus
                            THANK YOU Fredo!!!!!!
                            You're brilliant.
                            Finally I get my chair seats right 👍
                            Markus Sillander
                            Vantaa, Finland
                            I'm on FormFonts now
                            http://www.formfonts.com
                              Marinho
                              Hi Fredo, morning, meu name is Marinho, and I live in Luciara, Mato Grosso state, Brasil (nearly 11°30'00"S - 50°30'00"W at side of Araguaia River). I want you if you can send me please the your famous plugin, now with changed name, FREDOSCALE 2.0f. I use the Sketchup 6.0 and lake very match can use this plugin.I dont find it to download in anyplace in internet.
                              Tanks a lot,
                              Best regards
                              Marinho.
                                Tanks a lot,
                                Best regards
                                Marinho.
                                Check the first post of this thread: http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948#p144180
                                  Marinho
                                  Hi Thomthom, I checked the link viewtopic.php?f=180&t=17948#p144180 but I dont find nothing about download FredScale 2.0g. Am I wrong? 😠
                                  Tanks,...
                                    At the end of the post, there's a little box saying "Attachments" - In that there's a link "FredoScale 2.0g.zip"
                                      Download link is here:
                                      http://www.sketchucation.com/forums/scf/download/file.php?id=27660
                                        mics_54
                                          Marinho
                                          Hi Thomthom, Hi TIG, tanks... but I am litle craze.... I have password
                                          for the two... forun and site Sketchucation, but when I see "FredoScale
                                          2.gf to download to unzip (via SELECT ALU in Sketchup Plugins folder
                                          (731.49 KB) and I click it, I receive the notice "you are not....." and
                                          in this page, there are not place to login. TIG, tanks you for the
                                          direct link to download, but the same things, I am going to a place
                                          where I dont can log me. I am completly lost. The same with the links of
                                          tutorials in home page of Sketchucation. Links where I dont have
                                          acess to login,even though, I have the passwords. Sorry, but I need nost help.
                                          Tanks
                                          Marinho.
                                          • GaieusG
                                            Hi Marinho,
                                            You need not register/log in on the main site of SketchUcation at all. All tutorials can be freely viewed without logging in.
                                            The only place you need to log in (to se and download attachments) is the forum.Please, let me know if you have problems with that.
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 58
                                            • 59
                                            • 15 / 59
