    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.3m Views 345 Watching
    • CadFatherC
      CadFather
      Thank you Fredo - class act (as always) πŸ˜„
        silver_shadow
        Hi Fredo
        I like your tool. I want to know if you can re make the stretch tool so that you if stretch 4 or more objects, it calculates the spaces between and re position all if them and not only have one cut face but several depending the amount of objects between it
        pretty please.
        Like if you do a palacade fence, you can stretch it and all those poles will be re spaced.
        • fredo6F
          @silver_shadow said:
          Hi Fredo
          pretty please.
          I thought about that of course. There is no major geometrical issues except the GUI to help you decide, because in some instances, it won't do what you wish it would do.
          By the way, what you describe is pretty much what Dynamic Components have been made for.
          • W
            watkins
            Dear Fredo,
            Further to a previous post, what settings should I use to remove the blank icon boxes from the tool bar, or are these unused boxes earmarked for future tool?
            A fantastic and generous contribution to the SU community. Thank you.
            Kind regards,
            Bob
            • romboutR
              rombout
              Hi fredo... I had it working. But it stopped today. It wont show anymore. I tried downloading the 31f today and the link worked, only it is still not working. I dont know what happened. I thought of a different ruby but that was not the cause. It was working on my pc and wanted it on my imac. I got this error that it only worked with 31 and not 30. Tonight i wanted to work with it on the pc but it didnt show up anymore. I just copied the files from the pluggin folder to a mem stick
              • fredo6F
                In general, for installation and upgrades, just unzip the files provided (select All and extract, to make sure you transfer the folder hierarchy) and answer YES to any prompt dialog box to replace existing files.
                Do not worry with previous versions. By unzipping the files, it will replace the ones that have to be replaced. Also never rename or move yourself the files outside of their folder.
                Finally, it may help if you tell me whether you:
                • get a message at Sketchup startup
                • see the menus and toolbar
                • get errors at run time
                  and anything that may guide me to help you
                • romboutR
                  rombout
                  well ad first i had this error on the mac that i had to upgrade from 30 > 31. Did that and it worked... aslo upgraded on the pc but it doesnt work now!!! ad first it worked with the libfredo 30e but now it doesnt! so any suggestions any one πŸ‘Ώ
                  i dont see any menu's both of them no freescale and no libfredo settings
                  • fredo6F
                    Maybe you should refer to the following post, which indicates the exact footprint of the plugin in the Sketchup directory.
                    http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947&p=158341#p158225
                      steelers05
                      I am running the most recent version on a pc and all of the tools work except the bend tool....half the time it wont even activate when I click the icon and when it does work, it only rotates the object and doesnt bend it. Any ideas what I could be doing wrong?
                      • CadFatherC
                        CadFather
                        Hi Fredo - just to let you know, after replacing the file 'FreeScale_Common.rb' the tool stops working
                        it's not a big deal though - whenever you stumble upon it..
                        • fredo6F
                          Two remarks
                          • For the rotation (instead of bend), you need to activate the slicer (toggle F4). This creates intermediate points and make the bending smoother.
                          • Before you do any transformation, make sure that your current selection is correct. If you move directly from one tool to another one like Bend, then all geometry at model level may not be selected. This is why it's always better to encapsulate the geometry within groups.
                          • CadFatherC
                            CadFather
                            Thanks Fredo.. strange, it doesn't work - tried changing the toolbar name..
                            it doesn't matter - shall i try to find the separators in the files themselves or would i just waste time?
                            • fredo6F
                              Strange. It works for me. Do you at least see the option in the Default Parameters dialog box?
                              Please do not change the code. You won't find where the separators are (I am even lost myself).
                              • CadFatherC
                                CadFather
                                sorry Fredo, should have been clearer - the update does remove the separators.. so the toolbar looks great - it just doesn't work! : )
                                ..don't worry about it Fredo, i'll leave it as it is.. i will try and find out if there's some clashing etc.. (Thanks)
                                • fredo6F
                                  Is it the whole set of tools not working?
                                  Did you try with the version attached in my previous post, just in case?
                                  I'd better know, because I checked that 44 people have downloaded the file.
                                  • fredo6F
                                    @cadfather said:
                                    yes, the whole toolset stops - with both versions,
                                    i also tried with an empty plugins folder as below, same result..
                                    I suggest you then reinstall the standard version 2.0f (and 3.1f for LibFredo6, we never know). I need to investigate.
                                    By the way, when you say 'Stops' what does that mean. For instance, if you open the Ruby console, do you see any message when launching the tools?
                                    PS: Nice icon for the folders!
                                    • CadFatherC
                                      CadFather
                                      forgot to mention:
                                      xp pro sp3
                                      sketchup 7 pro
                                      • CadFatherC
                                        CadFather
                                        with the clean latest install (i had it but retried it again now) the toolset works - if i change the 'common' file, it stops..
                                        here's the folder icons - i do need some visual clues as to what swims in this folder!
                                        Folders.rar
                                        • fredo6F
                                          I think I found the issue. I have inadvertedly included a statement that only works with another version of LibFredo6.
                                          Here is a version that should work hopefully
                                          to drop into FREESCALE_Dir_20 folder
                                          • fredo6F
                                            @cadfather said:
                                            Hi Fredo
                                            what are the chances i can remove the separators from the icons toolbar?
                                            Drop the attached file into the FREESCALE_Dir_20 folder.
                                            Then restart Sketchup, set the option in the Default Parameters dialog box, and then restart sketchup again.
                                            to drop into FREESCALE_Dir_20 subfolder
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 58
                                            • 59
                                            • 14 / 59
