    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.3m Views 329 Watching
      Chris, this is way cool!
      One thing that may be a bug (and perhaps you know about it already) is some softening of edges at one end of the bent geometry. I did a few simple tests with a long rectangular box and a curved line for the result. The start end gets softened. Easily fixed by just tracing over the lines but maybe it shouldn't do it?
      • jeff hammondJ
        yeah dave, i noticed that too.. one workaround for now is to make your straight line a little bit shorter than the object you're trying to bend (ie - if you're trying to bend a 24' long wall, make the straight line 23' with 6" in on both sides)
        that's probably not the best workaround but in the little amount of time i've spent with the ruby so far, that's what i came up with to stop the edge from collapsing.
        • L
          linea
          Fantastic script Chris. Thanks.
          • MALAISEM
            MALAISE
            Let's make tests... Thanks a lot Chris 😄
            MALAISE
              silver_shadow
              they should give out awards for those rubie developers...
              like the oscar rubie awards for each year !!! well done!! 😍
                Thanks Jeff. That'll work just fine.
                • MarianM
                  Marian
                  AWESOME
                  Thanks you Chris!!!
                    derryatlanta
                    Thanks so much for all the effort and time invested into this amazing ruby, Chris.
                    This will save me so much time and actually raise up my level of modeling, so I am indebted.
                    I second the ruby Oscar awards idea!
                    Cheers,
                    Nigel
                    Stop your grinnin' and drop your linen
                      AcesHigh
                      Chris, Ive run into trouble at my first try to bend something. I have this vertical X shaped lattice of triangular beams. I am not able to bend it in no way 😞
                      It was composed of a group with subgroups inside. I exploded everything inside, so its just meshes inside a group. Still, it doesnt work 😞
                      • jeff hammondJ
                        how about a sketchy..
                        http://en.wordpress.com/tag/sketchy-winner/
                          Explode all of the sub-groups etc and finally the main group. Its contents remain highlighted - immediately regroup these - it should work now...
                          • david_hD
                            david_h
                            I concur . .. however the term "Oscar" is copywrighted either by those people that make the movie awards or by the people that make the hot dogs and baloney (which are probably the same people)
                            so We need to come up with a different award name. . ..how about. .
                            oh I dunno. .. .
                            THE RUBY!!!
                            • david_hD
                              david_h
                              Yup . ..this is a much easier way to bend steel.
                              • tinanneT
                                tinanne
                                Chris AWESOME script and thank you for the videos! Watching someone work with the ruby really helps me to understand how to use it and where it will apply to my needs. Great job and thank you again!
                                Executive Director : American Society of Architectural Illustrators
                                AIP 30 Competition opens soon. ASAI.org
                                Architectural Rendering
                                • free agentF
                                  free agent
                                  very cool thank you 😎
                                  http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
                                  • B
                                    boilingsnow
                                    But the model you pasted can also be created easily without shape bender.
                                    • david_hD
                                      david_h
                                      Very true, But not as fun.
                                      • Chris FullmerC
                                        All right, thanks for the comments so far! I've got lots to think about. That bug where it smooths the end faces if your shape lines ep exactly with the line......I'll have to think about that. Its sort of done on purpose, but that is an exception where it is not desireable. I'll see if I can think of a way for it to be smarter.
                                        I'm working on groups and components as we speak. That is my #1 frustration with the script is that it explodes everything and it won't take components. I'd like to get that fixed and updated tonight. We'll see 😄 Thanks everyone, seriously!
                                        • B
                                          BTM
                                          Great!! 2 things: 1, why do a few random lines appear when I use it?
                                          also, sketchup said that there were problems, and when I agreed to let it fix them, this was the message:
                                          Results of Validity Check.
                                          CLoop (39755) for CFace (39754) has zero area
                                          Loop 0 of CFace (39754) is an invalid outer loop
                                          Entity CFace (39754) should be erased - done
                                          CLoop (39760) for CFace (39759) has zero area
                                          Loop 0 of CFace (39759) is an invalid outer loop
                                          Entity CFace (39759) should be erased - done
                                          CLoop (40274) for CFace (40273) has zero area
                                          Loop 0 of CFace (40273) is an invalid outer loop
                                          Entity CFace (40273) should be erased - done
                                          CLoop (40279) for CFace (40278) has zero area
                                          Loop 0 of CFace (40278) is an invalid outer loop
                                          Entity CFace (40278) should be erased - done
                                          CLoop (43115) for CFace (43114) has zero area
                                          Loop 0 of CFace (43114) is an invalid outer loop
                                          Entity CFace (43114) should be erased - done
                                          CLoop (43500) for CFace (43499) has zero area
                                          Loop 0 of CFace (43499) is an invalid outer loop
                                          Entity CFace (43499) should be erased - done
                                          • Chris FullmerC
                                            Hmmm, very interesting.
                                            Well, the lines appear because a face is being bent in a way that it is not able to do, so SketchUp steps in and adds the extra lines so that it can bend as needed. I'd be interested if anyone out there has a method for determining what faces are going to need that extra geometry so I can add the lines myself beforehand.
                                            The invalid geometry actually probably has a lot to do with problem above. Invalid geometry can be fixed automatically, the worst that can happen is that it will delete a few bad faces. Ok, thats not really ideal. So hopefully I'll get it fixed 😄
                                            On a happier note, I got the script to work with groups and components. I've got a few other things I want to try to implement tonight before I post the update though. So far so good.
                                            • 63
                                            • 64
                                            • 2 / 64
