    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.2m Views 329 Watching
    • MarianM Offline
      Marian
      AWESOME
      Thanks you Chris!!!
        derryatlanta
        Thanks so much for all the effort and time invested into this amazing ruby, Chris.
        This will save me so much time and actually raise up my level of modeling, so I am indebted.
        I second the ruby Oscar awards idea!
        Cheers,
        Nigel
        Stop your grinnin' and drop your linen
          AcesHigh
          Chris, Ive run into trouble at my first try to bend something. I have this vertical X shaped lattice of triangular beams. I am not able to bend it in no way 😞
          It was composed of a group with subgroups inside. I exploded everything inside, so its just meshes inside a group. Still, it doesnt work 😞
          • jeff hammondJ Offline
            how about a sketchy..
            http://en.wordpress.com/tag/sketchy-winner/
              Explode all of the sub-groups etc and finally the main group. Its contents remain highlighted - immediately regroup these - it should work now...
              • david_hD Offline
                david_h
                I concur . .. however the term "Oscar" is copywrighted either by those people that make the movie awards or by the people that make the hot dogs and baloney (which are probably the same people)
                so We need to come up with a different award name. . ..how about. .
                oh I dunno. .. .
                THE RUBY!!!
                • david_hD Offline
                  david_h
                  Yup . ..this is a much easier way to bend steel.
                  • tinanneT Offline
                    tinanne
                    Chris AWESOME script and thank you for the videos! Watching someone work with the ruby really helps me to understand how to use it and where it will apply to my needs. Great job and thank you again!
                    Executive Director : American Society of Architectural Illustrators
                    AIP 30 Competition opens soon. ASAI.org
                    Architectural Rendering
                    • free agentF Offline
                      free agent
                      very cool thank you 😎
                      http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
                        boilingsnow
                        But the model you pasted can also be created easily without shape bender.
                        • david_hD Offline
                          david_h
                          Very true, But not as fun.
                          • Chris FullmerC Offline
                            All right, thanks for the comments so far! I've got lots to think about. That bug where it smooths the end faces if your shape lines ep exactly with the line......I'll have to think about that. Its sort of done on purpose, but that is an exception where it is not desireable. I'll see if I can think of a way for it to be smarter.
                            I'm working on groups and components as we speak. That is my #1 frustration with the script is that it explodes everything and it won't take components. I'd like to get that fixed and updated tonight. We'll see πŸ˜„ Thanks everyone, seriously!
                              BTM
                              Great!! 2 things: 1, why do a few random lines appear when I use it?
                              also, sketchup said that there were problems, and when I agreed to let it fix them, this was the message:
                              Results of Validity Check.
                              CLoop (39755) for CFace (39754) has zero area
                              Loop 0 of CFace (39754) is an invalid outer loop
                              Entity CFace (39754) should be erased - done
                              CLoop (39760) for CFace (39759) has zero area
                              Loop 0 of CFace (39759) is an invalid outer loop
                              Entity CFace (39759) should be erased - done
                              CLoop (40274) for CFace (40273) has zero area
                              Loop 0 of CFace (40273) is an invalid outer loop
                              Entity CFace (40273) should be erased - done
                              CLoop (40279) for CFace (40278) has zero area
                              Loop 0 of CFace (40278) is an invalid outer loop
                              Entity CFace (40278) should be erased - done
                              CLoop (43115) for CFace (43114) has zero area
                              Loop 0 of CFace (43114) is an invalid outer loop
                              Entity CFace (43114) should be erased - done
                              CLoop (43500) for CFace (43499) has zero area
                              Loop 0 of CFace (43499) is an invalid outer loop
                              Entity CFace (43499) should be erased - done
                                Hmmm, very interesting.
                                Well, the lines appear because a face is being bent in a way that it is not able to do, so SketchUp steps in and adds the extra lines so that it can bend as needed. I'd be interested if anyone out there has a method for determining what faces are going to need that extra geometry so I can add the lines myself beforehand.
                                The invalid geometry actually probably has a lot to do with problem above. Invalid geometry can be fixed automatically, the worst that can happen is that it will delete a few bad faces. Ok, thats not really ideal. So hopefully I'll get it fixed πŸ˜„
                                On a happier note, I got the script to work with groups and components. I've got a few other things I want to try to implement tonight before I post the update though. So far so good.
                                  BTM
                                  And up arrow isn't toggling orientation.
                                    Really? Thats too bad. If the model is complex, it will take a second or two to "toggle". Its not necessarily immediate. It might need to think about it for a bit.
                                    So if you've waited patiently and its still not working, that is no good. Could you open the Ruby Console and see if it gives any errors when you press the up arrow key?
                                      just a by-the-way going back to the perpendicular face/mac osx
                                      the up arrow does work with this script on macs so it's probably something to do with the gear's geometry.
                                        BTM
                                        Actually, I tried it with a simple rectangle as well. It give no errors in the console, nothing happens at all. πŸ˜• With the console opened, I selected the (rectangle) group, then shape bend, then the straight line, then curved. after I selected the curved line, I pressed the up arrow. Nothing happens at all. Am I doing something wrong?
                                          it sounds like you're doing it properly.. that did happen to me once yesterday (didn't get any response from the up arrow and i wasn't getting the green outline showing a preview bend.. (it was after i tried a super complex shape being bent to a weird 3d curve -- i was trying to break the ruby πŸ˜„ and succeeded)
                                          i quit sketchup and relaunched and it worked again.
                                          try that.
                                            Hmm, here's the order of operations:
                                            Select a group (must be a group, not a component in the current version of the script)
                                            Activate the script
                                            Select a straight line - must be drawn on the red axis. It will add "start" and "end" tags to it if it was selected correctly.
                                            Select the curve. Now the grids should appear and you should be able to press the up arrow.
                                            Hope that helps,
                                            Jeff, I found a better method for the up arrow key. I still need to implement it in the perpendicular face tools script though - I probably will have time for that tomorrow.
                                            • 63
                                            • 64
                                            • 2 / 64
