    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.3m Views 329 Watching
      Very, very good - well done.
      After you bend the group's contents couldn't you re-group all of the bits and give this new group the same name/description/material/layer etc as the original ? That way it'd look like you "just moved and bent the original group"...
      It's also quite easy to run it on a component-instance - simply make a group of the instance [ groupp=model.active_entities-add_group(instance) ], later you'll explode it, you might also want to mine through the group's entities for any other groups or instances and explode them back to basics. Now you'll have a group of the geometry just as you do with your 'group-only' version... After bending etc you can re-group bits as outlined above - you could even make that group back into a new component instance (ins=group.to_component) and give it the same defname(made- unique >>#2)/name/description/materials/layer etc as the original instance, so then it looks like you simply bent the instance and made it unique. See my ComponentInstance-add_entities.rb for some ideas on how easy it is to do that...
      You've done the difficult geometry/transformation stuff etc - it just needs a little tidying up so that it appears to do its stuff effortlessly in a twinkling of an eye, as if by magic...
      Well done...
      • X
        xrok1
        1 more thing chris i was wondering if you couldn't group the line before exploding the group to be bent, then you could avoid the sticking while allowing the object to be placed directly in contact with the straight guide.
        also i noticed that construction lines don't stick to geometry so maybe you could convert it to constuction lines as another option.
        • fredo6F
          Chris,
          I am really impressed by what you achieved. This is a master transformation
          I played a little bit with it, and I think you got the essentials. The rest is just about adjustments in UI and options. And indeed to extend it to embedded components.
          Well done!
          • utilerU
            utiler
            Ditto from all said above, Chris!!!! This is fantasitc!!!
            Just Curious...
            • P
              Phil Rader AIA
              Supercalafragelisticexpialadocious
              That's one cool plugin...you are making a legacy for you children to follow.
              Maybe you should change your last name to "SU"llmer...hehe.
              http://www.philrader.com
              • Chris FullmerC
                @daniel s said:
                Chris:
                I attach my first .skp test using shape bender. 😍 😍
                Thank you!!!
                Daniel S
                My plugin did that? Was that in ultiple pieces??
                  Daniel S
                  Yes, your plugin do that... but not works everytime... it depends where you put the first line. It`s easy to have unexpected results.
                  Here i attach a working example. Just select the text, run your plugin, select firt line and then the helix. It takes some time but it works.
                  And i attach an example to make a double bend... In your video you make a lot of operations to get the result when you can apply directly on a 3d curve (you don´t get the exactly same result). In the model you will see that i have to move the 3d curve because you can´t use it if the endline is directly into the surface (here using Fredo´s Arc On Surface).
                  Daniel S
                  Helix working.skp
                  double bend.skp
                  • W
                    wolfy
                    Chris, this is a very impressive and useful new tool to your already impressive line of tools. Thanks for all the hard work, dedication and generosity...again! ☀
                      Chris, this is way cool!
                      One thing that may be a bug (and perhaps you know about it already) is some softening of edges at one end of the bent geometry. I did a few simple tests with a long rectangular box and a curved line for the result. The start end gets softened. Easily fixed by just tracing over the lines but maybe it shouldn't do it?
                      • jeff hammondJ
                        yeah dave, i noticed that too.. one workaround for now is to make your straight line a little bit shorter than the object you're trying to bend (ie - if you're trying to bend a 24' long wall, make the straight line 23' with 6" in on both sides)
                        that's probably not the best workaround but in the little amount of time i've spent with the ruby so far, that's what i came up with to stop the edge from collapsing.
                        • L
                          linea
                          Fantastic script Chris. Thanks.
                          • MALAISEM
                            MALAISE
                            Let's make tests... Thanks a lot Chris 😄
                            MALAISE
                              silver_shadow
                              they should give out awards for those rubie developers...
                              like the oscar rubie awards for each year !!! well done!! 😍
                                Thanks Jeff. That'll work just fine.
                                • MarianM
                                  Marian
                                  AWESOME
                                  Thanks you Chris!!!
                                    derryatlanta
                                    Thanks so much for all the effort and time invested into this amazing ruby, Chris.
                                    This will save me so much time and actually raise up my level of modeling, so I am indebted.
                                    I second the ruby Oscar awards idea!
                                    Cheers,
                                    Nigel
                                    Stop your grinnin' and drop your linen
                                      AcesHigh
                                      Chris, Ive run into trouble at my first try to bend something. I have this vertical X shaped lattice of triangular beams. I am not able to bend it in no way 😞
                                      It was composed of a group with subgroups inside. I exploded everything inside, so its just meshes inside a group. Still, it doesnt work 😞
                                      • jeff hammondJ
                                        how about a sketchy..
                                        http://en.wordpress.com/tag/sketchy-winner/
                                          Explode all of the sub-groups etc and finally the main group. Its contents remain highlighted - immediately regroup these - it should work now...
                                          • david_hD
                                            david_h
                                            I concur . .. however the term "Oscar" is copywrighted either by those people that make the movie awards or by the people that make the hot dogs and baloney (which are probably the same people)
                                            so We need to come up with a different award name. . ..how about. .
                                            oh I dunno. .. .
                                            THE RUBY!!!
                                            • 63
                                            • 64
                                            • 1 / 64
