    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.2m Views 329 Watching
    • W Offline
      wolfy
      Chris, this is a very impressive and useful new tool to your already impressive line of tools. Thanks for all the hard work, dedication and generosity...again! ☀
        Chris, this is way cool!
        One thing that may be a bug (and perhaps you know about it already) is some softening of edges at one end of the bent geometry. I did a few simple tests with a long rectangular box and a curved line for the result. The start end gets softened. Easily fixed by just tracing over the lines but maybe it shouldn't do it?
        • jeff hammondJ Offline
          yeah dave, i noticed that too.. one workaround for now is to make your straight line a little bit shorter than the object you're trying to bend (ie - if you're trying to bend a 24' long wall, make the straight line 23' with 6" in on both sides)
          that's probably not the best workaround but in the little amount of time i've spent with the ruby so far, that's what i came up with to stop the edge from collapsing.
            linea
            Fantastic script Chris. Thanks.
            • MALAISEM Offline
              MALAISE
              Let's make tests... Thanks a lot Chris 😄
              MALAISE
                silver_shadow
                they should give out awards for those rubie developers...
                like the oscar rubie awards for each year !!! well done!! 😍
                  Thanks Jeff. That'll work just fine.
                  • MarianM Offline
                    Marian
                    AWESOME
                    Thanks you Chris!!!
                      derryatlanta
                      Thanks so much for all the effort and time invested into this amazing ruby, Chris.
                      This will save me so much time and actually raise up my level of modeling, so I am indebted.
                      I second the ruby Oscar awards idea!
                      Cheers,
                      Nigel
                      Stop your grinnin' and drop your linen
                        AcesHigh
                        Chris, Ive run into trouble at my first try to bend something. I have this vertical X shaped lattice of triangular beams. I am not able to bend it in no way 😞
                        It was composed of a group with subgroups inside. I exploded everything inside, so its just meshes inside a group. Still, it doesnt work 😞
                          how about a sketchy..
                          http://en.wordpress.com/tag/sketchy-winner/
                            Explode all of the sub-groups etc and finally the main group. Its contents remain highlighted - immediately regroup these - it should work now...
                            • david_hD Offline
                              david_h
                              I concur . .. however the term "Oscar" is copywrighted either by those people that make the movie awards or by the people that make the hot dogs and baloney (which are probably the same people)
                              so We need to come up with a different award name. . ..how about. .
                              oh I dunno. .. .
                              THE RUBY!!!
                              • david_hD Offline
                                david_h
                                Yup . ..this is a much easier way to bend steel.
                                • tinanneT Offline
                                  tinanne
                                  Chris AWESOME script and thank you for the videos! Watching someone work with the ruby really helps me to understand how to use it and where it will apply to my needs. Great job and thank you again!
                                  Executive Director : American Society of Architectural Illustrators
                                  AIP 30 Competition opens soon. ASAI.org
                                  Architectural Rendering
                                  • free agentF Offline
                                    free agent
                                    very cool thank you 😎
                                    http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
                                      boilingsnow
                                      But the model you pasted can also be created easily without shape bender.
                                      • david_hD Offline
                                        david_h
                                        Very true, But not as fun.
                                        • Chris FullmerC Offline
                                          All right, thanks for the comments so far! I've got lots to think about. That bug where it smooths the end faces if your shape lines ep exactly with the line......I'll have to think about that. Its sort of done on purpose, but that is an exception where it is not desireable. I'll see if I can think of a way for it to be smarter.
                                          I'm working on groups and components as we speak. That is my #1 frustration with the script is that it explodes everything and it won't take components. I'd like to get that fixed and updated tonight. We'll see 😄 Thanks everyone, seriously!
                                            BTM
                                            Great!! 2 things: 1, why do a few random lines appear when I use it?
                                            also, sketchup said that there were problems, and when I agreed to let it fix them, this was the message:
                                            Results of Validity Check.
                                            CLoop (39755) for CFace (39754) has zero area
                                            Loop 0 of CFace (39754) is an invalid outer loop
                                            Entity CFace (39754) should be erased - done
                                            CLoop (39760) for CFace (39759) has zero area
                                            Loop 0 of CFace (39759) is an invalid outer loop
                                            Entity CFace (39759) should be erased - done
                                            CLoop (40274) for CFace (40273) has zero area
                                            Loop 0 of CFace (40273) is an invalid outer loop
                                            Entity CFace (40273) should be erased - done
                                            CLoop (40279) for CFace (40278) has zero area
                                            Loop 0 of CFace (40278) is an invalid outer loop
                                            Entity CFace (40278) should be erased - done
                                            CLoop (43115) for CFace (43114) has zero area
                                            Loop 0 of CFace (43114) is an invalid outer loop
                                            Entity CFace (43114) should be erased - done
                                            CLoop (43500) for CFace (43499) has zero area
                                            Loop 0 of CFace (43499) is an invalid outer loop
                                            Entity CFace (43499) should be erased - done
                                            • 63
                                            • 64
                                            • 2 / 64
