    KT fast start 4Architects (Kerkythea render engine)
    extensions
    64 Posts 27 Posters 45.3k Views 27 Watching
    • majidM Offline
      majid
      as some KT masters awared me , my thin frosty material was tricky ,and maybe the only way to make correct material is using "layered materials" ... and also describing "how to make layered materials" was not easy to write , so i made an wink exe tut, that describes how to make a simple layered material ( also it is a thin frosted glass).it is a bit tricky to , but much much more better than what i've described in "fast start" guide.
      cheers
      unzip, then open files
        rcossoli
        thanks
        I guess you can use this method of layer for all materials
        THREEDIMENSIONSWEB dot COM
        • majidM Offline
          majid
          yes, in fact layers and sub layeres are one of the powerful tools of KT, but i've prevent to describe it at "fast start4architects" because of a bit confusing. by the way i guess by seeing the wink tut and after a while you will be familiar enough whit layering system.
          and was the wink tut useful and clear enough?
            rcossoli
            Yes, clear and simple, thanks again
            • N Offline
              notareal
              cheers
              Mind to create this in some other format - flash or what ever platform independent.
              Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
              • F Offline
                FenS
                Hi Majid,
                some feedback on your tutorial (the pdf-one).
                I've downloaded it and i am reading it right now. Couldn't wait and downloaded the mat-scene2 also and opened the matscene2.kzx in KT, but he says that he is missing jpg's in the folder 'c:\Program Files\3d\Kerkythea Rendering System\fast start etc.
                Which is correct since i've put the download in another file and unzipped it there, but do i really have to create this folder on my c-drive or can i leave them in another one and point to that one?
                (sorry if my question is too sone and the answer is in your tut but i was a little unpatient and wanted to give it a try ๐Ÿ˜‰
                Regards,
                Fr@
                Quรฉ sais je? there is still so much to be learned...
                • majidM Offline
                  majid
                  many many thanx for feedback and so sorry...
                  first you must do a right-click over "Diffuse" and select second icon (that is for choosing bitmaps):missed-bitmap.gif
                  and then browse for textures:brows-for-image.gif
                  here are textures, UNZIP them where you've downloaded the matscene
                  • F Offline
                    FenS
                    Okay,
                    thanks for your reply (and for your tut!), will give it a try
                    • H Offline
                      hebrides
                      This is very much appreciated. Thanks for your generosity.
                        Antoine
                        Thank you so much, this is really nice. ๐Ÿ˜
                        • EddyNLE Offline
                          EddyNL
                          Thanks for the tutorial Majid, much more usefull then the Kerky tutorial on their site...
                          I've got a problem with the light though.
                          How can I fix this?
                          viewtopic.php?f=271&t=11903 Modelling my city for Google Earth!
                          • FrederikF Offline
                            Frederik
                            @eduardonl said:
                            ... much more usefull then the Kerky tutorial on their site...
                            In what sense...??? ๐Ÿ˜•
                            Cheers
                            Kim Frederik
                            • EddyNLE Offline
                              EddyNL
                              Never mind Frederik, I had an old tutorial. ๐Ÿ‘Š
                              The getting started KT2008 is quite good actually.
                              Majids tutorials is better suited for a quick start with KT I think.
                              Could you help me out with my lighting problem?
                              (as mentioned above)
                              • soloS Offline
                                Majid, I gave it a go with Vray, unfortunately my quad machine died yesterday so I had to do this with a dual core ๐Ÿ˜‰ , like watching paint dry.
                                http://img4.imageshack.us/img4/9715/ktroom1.png
                                • FrederikF Offline
                                  Frederik
                                  Without having the model you've used on hand, it's really difficult to say... ๐Ÿ˜
                                  It can be the glass material you've used, which is blocking some of the light...
                                  Have you tried applying a sky-portal...??
                                  Also - please remember that you can increase the exposure... ๐Ÿ˜‰
                                  I just quickly played a little with the tone mapping in your render...
                                  Hope you don't mind...
                                  Cheers
                                  Kim Frederik
                                  • FrederikF Offline
                                    Frederik
                                    Nice render, Pete... ๐Ÿ‘
                                    In particular I like the sofa and the material you've applied...
                                    Are you planning to make a furniture pack...??
                                    Cheers
                                    Kim Frederik
                                    • soloS Offline
                                      Thanks.
                                      I doubt I'll be completing the furniture pack at this moment, I hoped my Garden pack would buy me time to continue making model packs but it failed to cover the time I put into making it. With the current financial situation and lack of sustainable work (lots of mini projects that are more hassle than help) and recent failure of my work horse I'm actually considering a break from 3D viz for a while and taking on a day job that pays a consistant wage until things get better. ๐Ÿ˜ž
                                      • FrederikF Offline
                                        Frederik
                                        Sorry to hear this...
                                        I would have thought that it would sell like "hot bread"...
                                        Personally I've had GREAT use of it already...!
                                        @solo said:
                                        ...and recent failure of my work horse I'm actually considering a break from 3D viz for a while...
                                        ๐Ÿ˜ฒ I'm shocked to hear this... And really sorry to hear that things have turned this bad... ๐Ÿ˜
                                        Cheers
                                        Kim Frederik
                                          Hope you still will linger around SCF if you should take a break from 3D Viz.
                                          Lets hope for Better Times.
                                            alpro
                                            I'm sorry to hear that too, I was really looking forward to your furniture pack, I get constant use out of your garden pack and am surprised that more people didn't buy it. I also know about how slow it is, the home improvement field has practicualry came to a halt, the only good thing is that I have some more time to to come to better grips with the apps I use and to try some new ones but that doesn't pay the bills.
                                            Mike
                                            • 2 / 4
