    KT fast start 4Architects (Kerkythea render engine)
    extensions
    64 Posts 27 Posters 48.3k Views 27 Watching
    • E
      Ecuadorian
      Master Edson, then you are actually a Kerkythea user. You're just using it with a simplified interface.
      -Miguel Lescano
      • soloS
        Majid
        I was wondering if we can use your interior model for our 'Render this challenge'?
        • majidM
          majid
          @solo said:
          Majid
          yes for sure dear solo . i think it's composion needs some work . maybe a ceiling light or something vertical at the left part of the view can help the composition to be more balanced. it would be very nice to see what results would be achieved
            rcossoli
            i can?
            this is my version, I made some changes in the textures and lighting, but it is practically the same scene,i can or may be better off?
            THREEDIMENSIONSWEB dot COM
            • majidM
              majid
              rcossoli, you encoraged me to do some more renders whit different light settings , your light setting is really good. congrats!
                rcossoli
                thanks majid
                I did was add a few points of light to the left and change the direction of the sun to illuminate more of the scene right and lower values to the point of light in the lamp then this is a more even illumination
                and add some more material and reflections on the floor
                • majidM
                  majid
                  as some KT masters awared me , my thin frosty material was tricky ,and maybe the only way to make correct material is using "layered materials" ... and also describing "how to make layered materials" was not easy to write , so i made an wink exe tut, that describes how to make a simple layered material ( also it is a thin frosted glass).it is a bit tricky to , but much much more better than what i've described in "fast start" guide.
                  cheers
                  unzip, then open files
                    rcossoli
                    thanks
                    I guess you can use this method of layer for all materials
                    • majidM
                      majid
                      yes, in fact layers and sub layeres are one of the powerful tools of KT, but i've prevent to describe it at "fast start4architects" because of a bit confusing. by the way i guess by seeing the wink tut and after a while you will be familiar enough whit layering system.
                      and was the wink tut useful and clear enough?
                        rcossoli
                        Yes, clear and simple, thanks again
                        • N
                          notareal
                          cheers
                          Mind to create this in some other format - flash or what ever platform independent.
                          • F
                            FenS
                            Hi Majid,
                            some feedback on your tutorial (the pdf-one).
                            I've downloaded it and i am reading it right now. Couldn't wait and downloaded the mat-scene2 also and opened the matscene2.kzx in KT, but he says that he is missing jpg's in the folder 'c:\Program Files\3d\Kerkythea Rendering System\fast start etc.
                            Which is correct since i've put the download in another file and unzipped it there, but do i really have to create this folder on my c-drive or can i leave them in another one and point to that one?
                            (sorry if my question is too sone and the answer is in your tut but i was a little unpatient and wanted to give it a try 😉
                            Regards,
                            Fr@
                            Qué sais je? there is still so much to be learned...
                            • majidM
                              majid
                              many many thanx for feedback and so sorry...
                              first you must do a right-click over "Diffuse" and select second icon (that is for choosing bitmaps):missed-bitmap.gif
                              and then browse for textures:brows-for-image.gif
                              here are textures, UNZIP them where you've downloaded the matscene
                              • F
                                FenS
                                Okay,
                                thanks for your reply (and for your tut!), will give it a try
                                • H
                                  hebrides
                                  This is very much appreciated. Thanks for your generosity.
                                    Antoine
                                    Thank you so much, this is really nice. 😍
                                    • EddyNLE
                                      EddyNL
                                      Thanks for the tutorial Majid, much more usefull then the Kerky tutorial on their site...
                                      I've got a problem with the light though.
                                      How can I fix this?
                                      viewtopic.php?f=271&t=11903 Modelling my city for Google Earth!
                                      • FrederikF
                                        Frederik
                                        @eduardonl said:
                                        ... much more usefull then the Kerky tutorial on their site...
                                        In what sense...??? 😕
                                        Cheers
                                        Kim Frederik
                                        • EddyNLE
                                          EddyNL
                                          Never mind Frederik, I had an old tutorial. 👊
                                          The getting started KT2008 is quite good actually.
                                          Majids tutorials is better suited for a quick start with KT I think.
                                          Could you help me out with my lighting problem?
                                          (as mentioned above)
                                          • soloS
                                            Majid, I gave it a go with Vray, unfortunately my quad machine died yesterday so I had to do this with a dual core 😉 , like watching paint dry.
                                            http://img4.imageshack.us/img4/9715/ktroom1.png
                                            • 2 / 4
