    KT fast start 4Architects (Kerkythea render engine)
    extensions
    64 Posts 27 Posters 48.3k Views 27 Watching
      rcossoli
      i can?
      this is my version, I made some changes in the textures and lighting, but it is practically the same scene,i can or may be better off?
      THREEDIMENSIONSWEB dot COM
      • majidM
        majid
        rcossoli, you encoraged me to do some more renders whit different light settings , your light setting is really good. congrats!
          rcossoli
          thanks majid
          I did was add a few points of light to the left and change the direction of the sun to illuminate more of the scene right and lower values to the point of light in the lamp then this is a more even illumination
          and add some more material and reflections on the floor
          • majidM
            majid
            as some KT masters awared me , my thin frosty material was tricky ,and maybe the only way to make correct material is using "layered materials" ... and also describing "how to make layered materials" was not easy to write , so i made an wink exe tut, that describes how to make a simple layered material ( also it is a thin frosted glass).it is a bit tricky to , but much much more better than what i've described in "fast start" guide.
            cheers
            unzip, then open files
              rcossoli
              thanks
              I guess you can use this method of layer for all materials
              • majidM
                majid
                yes, in fact layers and sub layeres are one of the powerful tools of KT, but i've prevent to describe it at "fast start4architects" because of a bit confusing. by the way i guess by seeing the wink tut and after a while you will be familiar enough whit layering system.
                and was the wink tut useful and clear enough?
                  rcossoli
                  Yes, clear and simple, thanks again
                  • N
                    notareal
                    cheers
                    Mind to create this in some other format - flash or what ever platform independent.
                    • F
                      FenS
                      Hi Majid,
                      some feedback on your tutorial (the pdf-one).
                      I've downloaded it and i am reading it right now. Couldn't wait and downloaded the mat-scene2 also and opened the matscene2.kzx in KT, but he says that he is missing jpg's in the folder 'c:\Program Files\3d\Kerkythea Rendering System\fast start etc.
                      Which is correct since i've put the download in another file and unzipped it there, but do i really have to create this folder on my c-drive or can i leave them in another one and point to that one?
                      (sorry if my question is too sone and the answer is in your tut but i was a little unpatient and wanted to give it a try ๐Ÿ˜‰
                      Regards,
                      Fr@
                      Quรฉ sais je? there is still so much to be learned...
                      • majidM
                        majid
                        many many thanx for feedback and so sorry...
                        first you must do a right-click over "Diffuse" and select second icon (that is for choosing bitmaps):missed-bitmap.gif
                        and then browse for textures:brows-for-image.gif
                        here are textures, UNZIP them where you've downloaded the matscene
                        • F
                          FenS
                          Okay,
                          thanks for your reply (and for your tut!), will give it a try
                          • H
                            hebrides
                            This is very much appreciated. Thanks for your generosity.
                              Antoine
                              Thank you so much, this is really nice. ๐Ÿ˜
                              • EddyNLE
                                EddyNL
                                Thanks for the tutorial Majid, much more usefull then the Kerky tutorial on their site...
                                I've got a problem with the light though.
                                How can I fix this?
                                viewtopic.php?f=271&t=11903 Modelling my city for Google Earth!
                                • FrederikF
                                  Frederik
                                  @eduardonl said:
                                  ... much more usefull then the Kerky tutorial on their site...
                                  In what sense...??? ๐Ÿ˜•
                                  Cheers
                                  Kim Frederik
                                  • EddyNLE
                                    EddyNL
                                    Never mind Frederik, I had an old tutorial. ๐Ÿ‘Š
                                    The getting started KT2008 is quite good actually.
                                    Majids tutorials is better suited for a quick start with KT I think.
                                    Could you help me out with my lighting problem?
                                    (as mentioned above)
                                    • soloS
                                      Majid, I gave it a go with Vray, unfortunately my quad machine died yesterday so I had to do this with a dual core ๐Ÿ˜‰ , like watching paint dry.
                                      http://img4.imageshack.us/img4/9715/ktroom1.png
                                      • FrederikF
                                        Frederik
                                        Without having the model you've used on hand, it's really difficult to say... ๐Ÿ˜
                                        It can be the glass material you've used, which is blocking some of the light...
                                        Have you tried applying a sky-portal...??
                                        Also - please remember that you can increase the exposure... ๐Ÿ˜‰
                                        I just quickly played a little with the tone mapping in your render...
                                        Hope you don't mind...
                                        Cheers
                                        Kim Frederik
                                        • FrederikF
                                          Frederik
                                          Nice render, Pete... ๐Ÿ‘
                                          In particular I like the sofa and the material you've applied...
                                          Are you planning to make a furniture pack...??
                                          Cheers
                                          Kim Frederik
                                          • soloS
                                            Thanks.
                                            I doubt I'll be completing the furniture pack at this moment, I hoped my Garden pack would buy me time to continue making model packs but it failed to cover the time I put into making it. With the current financial situation and lack of sustainable work (lots of mini projects that are more hassle than help) and recent failure of my work horse I'm actually considering a break from 3D viz for a while and taking on a day job that pays a consistant wage until things get better. ๐Ÿ˜ž
                                            • 2 / 4
