KT fast start 4Architects (Kerkythea render engine)
@solo said:
Majid
I was wondering if we can use your interior model for our 'Render this challenge'?
yes for sure dear solo . i think it's composion needs some work . maybe a ceiling light or something vertical at the left part of the view can help the composition to be more balanced. it would be very nice to see what results would be achieved
i can?
this is my version, I made some changes in the textures and lighting, but it is practically the same scene,i can or may be better off?
rcossoli, you encoraged me to do some more renders whit different light settings , your light setting is really good. congrats!
thanks majid
I did was add a few points of light to the left and change the direction of the sun to illuminate more of the scene right and lower values to the point of light in the lamp then this is a more even illumination
and add some more material and reflections on the floor -
as some KT masters awared me , my thin frosty material was tricky ,and maybe the only way to make correct material is using "layered materials" ... and also describing "how to make layered materials" was not easy to write , so i made an wink exe tut, that describes how to make a simple layered material ( also it is a thin frosted glass).it is a bit tricky to , but much much more better than what i've described in "fast start" guide.
cheers
thanks
I guess you can use this method of layer for all materials -
yes, in fact layers and sub layeres are one of the powerful tools of KT, but i've prevent to describe it at "fast start4architects" because of a bit confusing. by the way i guess by seeing the wink tut and after a while you will be familiar enough whit layering system.
and was the wink tut useful and clear enough? -
Yes, clear and simple, thanks again
cheersMind to create this in some other format - flash or what ever platform independent.
Hi Majid,
some feedback on your tutorial (the pdf-one).
I've downloaded it and i am reading it right now. Couldn't wait and downloaded the mat-scene2 also and opened the matscene2.kzx in KT, but he says that he is missing jpg's in the folder 'c:\Program Files\3d\Kerkythea Rendering System\fast start etc.
Which is correct since i've put the download in another file and unzipped it there, but do i really have to create this folder on my c-drive or can i leave them in another one and point to that one?
(sorry if my question is too sone and the answer is in your tut but i was a little unpatient and wanted to give it a try
Regards,
Fr@
many many thanx for feedback and so sorry...
first you must do a right-click over "Diffuse" and select second icon (that is for choosing bitmaps):
and then browse for textures:
here are textures, UNZIP them where you've downloaded the matscene
Okay,
thanks for your reply (and for your tut!), will give it a try -
This is very much appreciated. Thanks for your generosity.
Thank you so much, this is really nice.
Thanks for the tutorial Majid, much more usefull then the Kerky tutorial on their site...
I've got a problem with the light though.
How can I fix this?
@eduardonl said:
... much more usefull then the Kerky tutorial on their site...
In what sense...???
@frederik said:
In what sense...???
Never mind Frederik, I had an old tutorial.
The getting started KT2008 is quite good actually.
Majids tutorials is better suited for a quick start with KT I think.Could you help me out with my lighting problem?
(as mentioned above) -
Without having the model you've used on hand, it's really difficult to say...
It can be the glass material you've used, which is blocking some of the light...
Have you tried applying a sky-portal...??Also - please remember that you can increase the exposure...
I just quickly played a little with the tone mapping in your render...
Hope you don't mind...
Nice render, Pete...
In particular I like the sofa and the material you've applied...
Are you planning to make a furniture pack...??
