    KT fast start 4Architects (Kerkythea render engine)
    extensions
    64 Posts 27 Posters 48.3k Views 27 Watching
    • majidM
      majid
      dear Edson.which render engine do u use? as i am a freeware user, i've used KT for a long while. ( i tried pov-ray but confused by errors, also it was the same whit indigo). and i think it is fast and easy enough to try it. so pls give it a try .and maybe my tutorial can help you!!!
      • EdsonE
        Edson
        i have been using podium for about a year (run a search under my name in the gallery and you will see a couple of renders i produced with it). it is the one that suits my needs best at the moment. but i have not written KT off. i may give it another try when i have the time.
        http://www.mahfuz.arq.br
        • E
          Ecuadorian
          Master Edson, then you are actually a Kerkythea user. You're just using it with a simplified interface.
          -Miguel Lescano
          • soloS
            Majid
            I was wondering if we can use your interior model for our 'Render this challenge'?
            • majidM
              majid
              @solo said:
              Majid
              yes for sure dear solo . i think it's composion needs some work . maybe a ceiling light or something vertical at the left part of the view can help the composition to be more balanced. it would be very nice to see what results would be achieved
                rcossoli
                i can?
                this is my version, I made some changes in the textures and lighting, but it is practically the same scene,i can or may be better off?
                THREEDIMENSIONSWEB dot COM
                • majidM
                  majid
                  rcossoli, you encoraged me to do some more renders whit different light settings , your light setting is really good. congrats!
                    rcossoli
                    thanks majid
                    I did was add a few points of light to the left and change the direction of the sun to illuminate more of the scene right and lower values to the point of light in the lamp then this is a more even illumination
                    and add some more material and reflections on the floor
                    • majidM
                      majid
                      as some KT masters awared me , my thin frosty material was tricky ,and maybe the only way to make correct material is using "layered materials" ... and also describing "how to make layered materials" was not easy to write , so i made an wink exe tut, that describes how to make a simple layered material ( also it is a thin frosted glass).it is a bit tricky to , but much much more better than what i've described in "fast start" guide.
                      cheers
                      unzip, then open files
                        rcossoli
                        thanks
                        I guess you can use this method of layer for all materials
                        • majidM
                          majid
                          yes, in fact layers and sub layeres are one of the powerful tools of KT, but i've prevent to describe it at "fast start4architects" because of a bit confusing. by the way i guess by seeing the wink tut and after a while you will be familiar enough whit layering system.
                          and was the wink tut useful and clear enough?
                            rcossoli
                            Yes, clear and simple, thanks again
                            • N
                              notareal
                              cheers
                              Mind to create this in some other format - flash or what ever platform independent.
                              • F
                                FenS
                                Hi Majid,
                                some feedback on your tutorial (the pdf-one).
                                I've downloaded it and i am reading it right now. Couldn't wait and downloaded the mat-scene2 also and opened the matscene2.kzx in KT, but he says that he is missing jpg's in the folder 'c:\Program Files\3d\Kerkythea Rendering System\fast start etc.
                                Which is correct since i've put the download in another file and unzipped it there, but do i really have to create this folder on my c-drive or can i leave them in another one and point to that one?
                                (sorry if my question is too sone and the answer is in your tut but i was a little unpatient and wanted to give it a try 😉
                                Regards,
                                Fr@
                                Qué sais je? there is still so much to be learned...
                                • majidM
                                  majid
                                  many many thanx for feedback and so sorry...
                                  first you must do a right-click over "Diffuse" and select second icon (that is for choosing bitmaps):missed-bitmap.gif
                                  and then browse for textures:brows-for-image.gif
                                  here are textures, UNZIP them where you've downloaded the matscene
                                  • F
                                    FenS
                                    Okay,
                                    thanks for your reply (and for your tut!), will give it a try
                                    • H
                                      hebrides
                                      This is very much appreciated. Thanks for your generosity.
                                        Antoine
                                        Thank you so much, this is really nice. 😍
                                        • EddyNLE
                                          EddyNL
                                          Thanks for the tutorial Majid, much more usefull then the Kerky tutorial on their site...
                                          I've got a problem with the light though.
                                          How can I fix this?
                                          viewtopic.php?f=271&t=11903 Modelling my city for Google Earth!
                                          • FrederikF
                                            Frederik
                                            @eduardonl said:
                                            ... much more usefull then the Kerky tutorial on their site...
                                            In what sense...??? 😕
                                            Cheers
                                            Kim Frederik
                                            • 2 / 4
