    [Plugin] Proper Animation V1.08 Beta(Updated 14/11/10)
    246 Posts 108 Posters 229.6k Views 108 Watching
      morisdov
      Thanks for the support guys
      To Clarify usage below are some details
      Each Position number X, corrsponds to the X'th sketchup Scene/Page
      Position 1 will be for the FIRST scene tab
      Position 3 will correspond to the THIRD tab etc
      1) to begin with Set position number X, and Get position number X, you dont care about scenes or number of them. just make object selections, and Set their positions, move them and set additional positions, Get positions manually to see how things paly out
      2) after you finished Setting the positions of various objects you may add scenes/pages as many as positions as you have or more
      3) only now you should START the ANIMATION OBSERVER
      this will make all objects that have position 2 set, to ANIMATE (move) to position 2 when you clickon the SECOND scene tab.
      click FOURTH tab, objects with position 4 will animate to position 4
      4) STARTing Animation Observer automates the objects animation by using scene tabs instead of manual right click command GET position X - via corresponding click on SCENE X in the order of scenes
      5) to modify object positions and scene view angles youd want to STOP ANIMATION OBSERVER, otherwise the objects keep on moving disturbing your adjustments of new positions etc
      so STOP ANIMATION OBSERVER, make adjustments
      START ANIMATION OBSERVER again to use scenes tab clicks instead of GET position X
      6) not all objects need to have all position numbers set, just those few you want to move on X'th scenes tab click
      7) you can select multiple objects and SET their position X in one command click
      8) to "enable" the command of "GET to position X" those objects currently selected should have "Position X" set or otherwise - the right click menu command "GET position X" will be grayed out ("disabled")
      this way you can find out if an object has position X set or not, or groups of selected objects have position X set or not πŸ˜‰
        Thx for precisions 😎 πŸ˜„
        • Tim DanaherT
          Tim Danaher
          Cheers Moris...
          And thanks for the link, Pilou -- that's some crazy sh1t!
          Cheers,
          Tim
          http://vizarch.blogspot.com
            skyscraper100
            hi πŸ˜‰
            if ive made an animation with this plugin, can i export and render it in kerkythea?
            thanks πŸ˜„
            The way you think Creates reality for yourself.
            • E
              Ecuadorian
              You can "render" it inside SketchUp if you install Whaat's "Smooth Animation" plug-in and use the "export smooth animation" command.
              BTW, Thank you very much, Morisdov.
              -Miguel Lescano
              • C
                Chris-69
                Most of the time i can solve most of the problems by reading the forums... πŸ˜„ (Thanks for that)
                But i have a problem by using the "scenes transition times". I have more than 27 scenes.
                I can't see more scenes when i want to set the times in this plug-in. Using the "tab", i can "blind" set the times, but i can't see it. Is there a solution?
                ❓ Thanks!
                Dulish new language? :smile:
                  ❓ Thanks!
                  Use the Scene manager window?
                    Yes you right, there is a little problem πŸ˜„
                    We must send a PM to Morrisdov!
                    Done Wait and see πŸ˜„
                    Till that you can move your sketchup window to the bottom screen and call the Scene transition, with that you can see 38 scenes πŸ˜‰
                      morisdov
                      quick solution is to use the following line in the ruby console to set the current selected scene -
                      Sketchup.active_model.pages.selected_page.transition_time = 4
                        One tricky solution indeed πŸ˜‰
                          sambort
                          nice work!
                          but can someone upload one example with differents Scene Transition Times and/or Scene Delay Times? or can anybody explain what its wrong?
                          because mys examples don't seems to work, some times the object arrive to position before the scene to it. it's not clear to me.
                          thanks a lot!
                          • C
                            Chris-69
                            Thanks for the quick response!
                            It Works! Many, many thanks!
                            • E
                              evgenia
                              How to fix the animation picture in the body of mail? When i try to send the mail with animation picture attachment, picture link only found in the recipient end. How to fix the picture in the composer body itself?
                              keyword research ~ keyword tool ~ keyword tracking ~ affiliate elite
                              • V
                                Vially
                                Hi guys, and sorry to bother you.
                                I was wondering, has anyone found a way to animate object assembly/disassembly (not just scenes, but moving objects inside) while at the same having a photo realistic effect like the ones you get for static pictures in kerkythea ?
                                I have seen in an older thread at some point on this forum that someone made a very nice animation of a robot with SU2KT and it looked extremely nice. However, I cannot find any tutorial or any kind of advice on how to achieve this. Could anyone please shed some light on the issue ?
                                • T
                                  tomasz
                                  I am preparing a compilation of few proposed by users modifications to the SU2KT. It includes option to export 'proper_animation' for rendering in the Kerkythea. When finished I will make a post here at SCF, KT and on my website.
                                  Tomasz
                                    miikka1978
                                    That sounds great Tomasz!
                                    By the way, is there any simple way or script that could be used with proper animation Plugin when trying to get vehicles to drive/turn smoothly along curves? Or, is the only way to make it step by step (move the vehicle and then rotate it with rotate tool, move the vehicle and then rotate...)?
                                    • ashscottA
                                      ashscott
                                      This has sort of been covered but the previous conversations don't cover my issue, I'm trying to animate a log on a conveyor going into a sawmill with this plugin, however, every time the log moves it tilts about the green axis by about 15 degrees and its geometry distorts slightly. I obviously have the latest version of the plugin from the googlepages site but the issue persists.
                                      Any suggestions are much appreciated.
                                      Just some stuff I do with Sketchup.
                                        Maybe try to see where is the Internal Axis x,y,z of the component?
                                        • ashscottA
                                          ashscott
                                          It seems some setting was mixed up within the group that made up the log, I exploded the group and reset the scenes and the problem was solved.
                                          • H
                                            hkgiordano
                                            THANKS!!!
                                            • 12
                                            • 13
                                            • 5 / 13
