    [Plugin] Proper Animation V1.08 Beta(Updated 14/11/10)
    246 Posts 108 Posters 241.6k Views 108 Watching
      morisdov
      quick solution is to use the following line in the ruby console to set the current selected scene -
      Sketchup.active_model.pages.selected_page.transition_time = 4
        One tricky solution indeed 😉
          sambort
          nice work!
          but can someone upload one example with differents Scene Transition Times and/or Scene Delay Times? or can anybody explain what its wrong?
          because mys examples don't seems to work, some times the object arrive to position before the scene to it. it's not clear to me.
          thanks a lot!
          • C
            Chris-69
            Thanks for the quick response!
            It Works! Many, many thanks!
            Dulish new language? :smile:
            • E
              evgenia
              How to fix the animation picture in the body of mail? When i try to send the mail with animation picture attachment, picture link only found in the recipient end. How to fix the picture in the composer body itself?
              keyword research ~ keyword tool ~ keyword tracking ~ affiliate elite
              • V
                Vially
                Hi guys, and sorry to bother you.
                I was wondering, has anyone found a way to animate object assembly/disassembly (not just scenes, but moving objects inside) while at the same having a photo realistic effect like the ones you get for static pictures in kerkythea ?
                I have seen in an older thread at some point on this forum that someone made a very nice animation of a robot with SU2KT and it looked extremely nice. However, I cannot find any tutorial or any kind of advice on how to achieve this. Could anyone please shed some light on the issue ?
                • T
                  tomasz
                  I am preparing a compilation of few proposed by users modifications to the SU2KT. It includes option to export 'proper_animation' for rendering in the Kerkythea. When finished I will make a post here at SCF, KT and on my website.
                  Tomasz
                    miikka1978
                    That sounds great Tomasz!
                    By the way, is there any simple way or script that could be used with proper animation Plugin when trying to get vehicles to drive/turn smoothly along curves? Or, is the only way to make it step by step (move the vehicle and then rotate it with rotate tool, move the vehicle and then rotate...)?
                    • ashscottA
                      ashscott
                      This has sort of been covered but the previous conversations don't cover my issue, I'm trying to animate a log on a conveyor going into a sawmill with this plugin, however, every time the log moves it tilts about the green axis by about 15 degrees and its geometry distorts slightly. I obviously have the latest version of the plugin from the googlepages site but the issue persists.
                      Any suggestions are much appreciated.
                      Just some stuff I do with Sketchup.
                        Maybe try to see where is the Internal Axis x,y,z of the component?
                        • ashscottA
                          ashscott
                          It seems some setting was mixed up within the group that made up the log, I exploded the group and reset the scenes and the problem was solved.
                          • H
                            hkgiordano
                            THANKS!!!
                            • mariochaM
                              mariocha
                              @tim danaher said:
                              Any way to get continuous movement across changing scenes?
                              Yeah that would be great ! What is the smallest delay time that will still work?
                              Oh, one more thing. Have you noticed, when in Animation Play mode, how the "shadows on Ground", (set in the Shadows dialog) do not follow well on the "virtual ground", meaning when there is no real surface? But if a surface is added then all is well. 😄
                              Shadow settings = On ground
                              %(#008000)[Mario C.
                              • T
                                Tekelwriter
                                Tomasz
                                I look forward to it. 😄
                                • FletchF
                                  Fletch
                                  @vially said:
                                  ... has anyone found a way to animate object assembly/disassembly (not just scenes, but moving objects inside) while at the same having a photo realistic effect like the ones you get for static pictures in kerkythea ?
                                  Twilight Render will render Proper Animation photorealistically in multiple methods of rendering (biased and unbiased methods)
                                  Check it out on the features page for animation in Twilight Render.
                                  see also this animation rendered.
                                  Now both of those are examples of SketchyPhysics, but it is the same for Proper Animations (I LOVE this Proper Animation plugin)
                                  Fletch
                                  • majidM
                                    majid
                                    woww ..it is really great development Fletch ,thanx again
                                    • FletchF
                                      Fletch
                                      Another SketchyPhysics animation, of a TANK driving over a bumpy surface, but turned out great...
                                      http://twilightrender.com/phpBB3/viewtopic.php?p=2363#p2363
                                      again, it will render Proper Animation as well... if I find time, I will do an example... but am swamped at the moment. 😕
                                      Fletch
                                      • B
                                        bulbucila
                                        Thank you!, amazing plugin. Can it export the animations into an avi file?
                                        • E
                                          Ecuadorian
                                          Render plug-ins usually don't export a video file, but a JPG sequence. I use VideoMach to convert that sequence to video, but Fletch posted a tip on how to do the same thing using only freeware:
                                          http://twilightrender.com/phpBB3/viewtopic.php?f=12&t=455
                                          -Miguel Lescano
                                            markozeta
                                            @dave r said:
                                            I saw a post in the SketchUp forum about making a paper airplane animation. I was curious and thought I'd play with it. In the attached model, I've got two components. The triangular one is supposed to fold up. As it does, though, it moves away from the other component. When I rotated it, I rotated along the edge common to both. Is there a way to make the component "hinge" on the edge?
                                            [attachment=1:wt057bzy]<!-- ia1 -->Folding Paper.skp<!-- ia1 -->[/attachment:wt057bzy]
                                            This seems to be an issue with the transformation.interpolate - interpolate only works by interpolating the movements, but rotations of multiple axis are not linear functions - and therefore cannot be interpolated.
                                            Instead, to obtain the full information about the object, information about a second point must be known.
                                            Imagine rotating a ball counterclockwise 90 degrees about the x axis and then 90 degrees CCW about the y axis, v. rotating a ball 90 degrees CCW about the y axis and then 90 degrees CCW about the x axis. It's not the same! The point (0,1,0) would be moved to (1,0,0) in the first instance, and it would be at (0,0,1) in the second instance!
                                            With a little bit of effort, I think I can fix this (yay for paying attention in my dynamics course!) assuming the author does not mind? It would just take a bit of direct manipulation on the transformation matrix. (and a better understanding from myself of Ruby, it seems I can read ruby but can never write it).
                                            BSME - Cal Poly Pomona
                                            Sketchup Pipe Maniac
                                            • 12
                                            • 13
                                            • 5 / 13
