    [Obsolete] BZ__Arc for BezierSpline 1.2
    54 Posts 31 Posters 28.7k Views 31 Watching
    • X
      xrok1
      ๐Ÿ˜ณ sorry, i was so busy copying the icons i forgot to copy the .rb
      โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
        It was dangerous to post something the 1 April ๐Ÿ˜„
        • I
          idraft
          Thanks a lot Fredo cant wait to try it. Youre comment about what it could be used for in practice? This one looks pretty diverse for all users, so I imagine it could used for anything, including modeling your own dentures ๐Ÿ’š Personally I would probably use it to create accurate site plans where the site boundaries have curves to them. ๐Ÿ‘
          For some reason when I downloaded the attachments i couldnt find the two image icons? they were missing. can someone please post them here, thanks Jeff.
          • X
            xrok1
            right click on them here and choose save as.
            • I
              idraft
              ๐Ÿ˜ณ ๐Ÿ˜„
              • MALAISEM
                MALAISE
                An another helpful plugin made in Fr(edo6)! ๐Ÿ˜†
                MALAISE ๐Ÿ‘ ๐Ÿ‘
                La Connaissance n'a de valeur que partagรฉe
                • W
                  watkins
                  Dear Frodo,
                  Can your Plugin be used used in X, Y and Z? This is just the type of Plugin that one would use for pipe and wiring runs. An option to draw the lines by inputting the X,Y and Z co-ordinates as well as drawing the lines free-style would be great.
                  Like all those that have replied, I greatly appreciate your skill and generosity.
                  Kind regards,
                  Bob
                  • fredo6F
                    @boilingsnow said:
                    Great!!!
                    Maybe even better if one can define the segment number by himself.
                    Just type the number followed by 'S' in the VCB.
                    This of course is by refreence to a full circle, because there is no need to use a lot of segment for a very open angle.
                    By default this 'Precision parameter' is set to 24, which is the usual default for Sketchup circles.
                    • fredo6F
                      @watkins said:
                      Dear Frodo,
                      Kind regards,
                      Bob
                      The plugin works in 3D, as all the BezierSpline extensions.
                      For drawing the polyline, I think you have full freedom to use the tool you like, then make it a Sketchup curve (by Weld), and then convert it to a Round Corner polyline.
                        "Sketchup Fredo Edition" ๐Ÿ‘ ๐Ÿ˜„ ๐Ÿ‘
                        • BurkhardB
                          Burkhard
                          It is great and usefull, even for filet. Just draw the rectangle , weld it et voilร
                          http://www.ia-plus.de
                          • Chris FullmerC
                            I like that Fredo is now making plugins for his plugins ๐Ÿ˜„
                            • W
                              watkins
                              Dear Fredo,
                              I just tried your plugin. Brilliant! It does pipe runs beautifully when used with pipe along path.
                              Thanks once again!
                              Kind regards,
                              Bob
                              • G
                                gaganraj
                                everytime i try to leave SU....i just get dragged back.
                                i'm unable to download the icons. For some reason there is no download link?
                                • boofredlayB
                                  boofredlay
                                  Context click on the image itself and save as...
                                    jmmad
                                    Fredo6
                                    what i like most of your script BezierSpilne is that the endpoints are intelligent and editable, you can move those points and the equation result for the geometry is auto updated, you can set the number of edges etc...
                                    So i have 3 request that i think it would be very useful.
                                    1.-Would it be possible to transform a normal set of SU lines to an editble polyline or bezier?
                                    2.-And to transform a BZ polyline to BZ Arc or any other Bezier and back?
                                    EDITED: ive notice you had those 2 option ๐Ÿ˜„. I should go to my oculist.
                                    When i go from BZ arc to Polyline would it be possible to get the primitive geometry and nont the points that make the arc?
                                    Ill try to explain this request...this i think it's more complex.
                                    Ive notice in your BZ plug in when you PushPull a closed BZ Spline or polyline surface, the BZ lines are copy, then you can edit the top and the bottom and edit somehow the geometry of the volume with the BZ edit command.
                                    But if i move a point in the top BZ polyline the point on the bottom polyline does not follow because its not related to the bottom spline.
                                    3.-Could it be posible to relate points between 2 or more "BZ polylines" maybe by an invisible vertex? So when you drag that vertex the the 2 or more beziers are modified at the same time. So if you have a volume made of an extruded BZ_Arc or spline you move this vertex and the geometry follows and not only the lines but the volume itself is updated. This will give more control over volumes just as you did with the 2d lines. With your talent you gave endpoints in SU properties that can be edited. Maibe that could be done with volumes.
                                    So this "inteligent vertex and endpoints could tell how the visible geometry should be.
                                    Uff... this is hard to explain for me.
                                    I hope you can follow mi idea.
                                    Get Upa !
                                    • CadFatherC
                                      CadFather
                                      ..and icons if needed.
                                      EDIT: strange my bezier tools have completely stopped working on SU7
                                        dtrarch
                                        Super useful and thanks a bunch. โ˜€
                                        A really helpful road layout tool that will be used a lot.
                                        Question please. ๐Ÿ˜•
                                        What does offset reference ?
                                        Arc radius ? Arc segment ? or ?
                                        Thx again
                                        dtr
                                        • fredo6F
                                          Offset is the distance from the corner to the start of the arc.
                                          You will notice that when the length of one of the segments defining the corner is not superior to twice the offset value, no round corner is generated.
                                            dtrarch
                                            Thanks for the reply and again the really useful tool.
                                            dtr
                                            • 1 / 3
