πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
[Obsolete] BZ__Arc for BezierSpline 1.2
54 Posts 31 Posters 25.2k Views 31 Watching
  • F Offline
    This extension is now included in BezierSpline 1.4
    BZ__Arc is an extension of BezierSpline which will draw a Polyline with round corners. You can specify the offset (distance to the corners) and the number of segments as the Precision parameter (based on the number of segments for a full circle). It also manages closed polylines (loop mode).
    As the polylines remains parametric as long as it is a curve, you can later change the parameters, and move, add or remove vertices.
    Finally, as for other extensions of Bezierspline, you can convert any Sketchup curve into a Polyline with Round corners.
    Here is a small video about it.
    [flash=425,344:1cmsigfz]http://www.youtube.com/v/XpLcAusWYV0&hl=fr&fs=1[/flash:1cmsigfz]
    Indeed you need to install BezierSpline 1.21 beforehands. If not already done, just refer to the post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=13563#p100509 .
    For installation of BZ__Arc, you just need to
    • drop the attached file BZ__Arc.rbin your BZ_Dir_12folder
    • drop the two icon files into the subfolders IMAGES_CadFather and IMAGES_Standard which are located in BZ_Dir_12 folder
    I am interested to know if it is useful in practice.
    This extension is integrated in the main release of BezierSpline 1.4. See this [url=http://forums.sketchucation.com/viewtopic.php?f=323&t=13563#p100509:1cmsigfz ]this post[/url:1cmsigfz] for download
    • X Offline
      xrok1
      i think you're just showing off now πŸ˜†
      • E Offline
        Ecuadorian
        Let me be the first to say Thank You, Fredo, for all the time you've devoted to helping the SketchUp community! πŸ‘
        -Miguel Lescano
        • X Offline
          xrok1
          yes thankyou. now how do i get it to show up in the toolbar? πŸ˜›
            jmmad
            Incredible Usefull tool
            Good for maiking street layouts among others.
            You have save me like a month of hard modeling with your "plugins". Or i should say for the realese of sketcup 7.9?.
            Thxs a again
            Get Upa !
              boilingsnow
              Great!!!
              Maybe even better if one can define the segment number by himself.
              • X Offline
                xrok1
                😳 sorry, i was so busy copying the icons i forgot to copy the .rb
                  It was dangerous to post something the 1 April πŸ˜„
                  • I Offline
                    idraft
                    Thanks a lot Fredo cant wait to try it. Youre comment about what it could be used for in practice? This one looks pretty diverse for all users, so I imagine it could used for anything, including modeling your own dentures πŸ’š Personally I would probably use it to create accurate site plans where the site boundaries have curves to them. πŸ‘
                    For some reason when I downloaded the attachments i couldnt find the two image icons? they were missing. can someone please post them here, thanks Jeff.
                    • X Offline
                      xrok1
                      right click on them here and choose save as.
                      • I Offline
                        idraft
                        😳 πŸ˜„
                        • MALAISEM Offline
                          MALAISE
                          An another helpful plugin made in Fr(edo6)! πŸ˜†
                          MALAISE πŸ‘ πŸ‘
                          La Connaissance n'a de valeur que partagΓ©e
                          • W Offline
                            watkins
                            Dear Frodo,
                            Can your Plugin be used used in X, Y and Z? This is just the type of Plugin that one would use for pipe and wiring runs. An option to draw the lines by inputting the X,Y and Z co-ordinates as well as drawing the lines free-style would be great.
                            Like all those that have replied, I greatly appreciate your skill and generosity.
                            Kind regards,
                            Bob
                            • F Offline
                              @boilingsnow said:
                              Great!!!
                              Just type the number followed by 'S' in the VCB.
                              This of course is by refreence to a full circle, because there is no need to use a lot of segment for a very open angle.
                              By default this 'Precision parameter' is set to 24, which is the usual default for Sketchup circles.
                              • F Offline
                                @watkins said:
                                Dear Frodo,
                                Kind regards,
                                Bob
                                The plugin works in 3D, as all the BezierSpline extensions.
                                For drawing the polyline, I think you have full freedom to use the tool you like, then make it a Sketchup curve (by Weld), and then convert it to a Round Corner polyline.
                                  "Sketchup Fredo Edition" πŸ‘ πŸ˜„ πŸ‘
                                  • BurkhardB Offline
                                    Burkhard
                                    It is great and usefull, even for filet. Just draw the rectangle , weld it et voilΓ
                                    [http://www.ia-plus.de(http://www.ia-plus.de)]
                                    • Chris FullmerC Offline
                                      I like that Fredo is now making plugins for his plugins πŸ˜„
                                      • W Offline
                                        watkins
                                        Dear Fredo,
                                        I just tried your plugin. Brilliant! It does pipe runs beautifully when used with pipe along path.
                                        Thanks once again!
                                        Kind regards,
                                        Bob
                                          gaganraj
                                          everytime i try to leave SU....i just get dragged back.
                                          i'm unable to download the icons. For some reason there is no download link?
                                          • 1 / 3
                                          1 / 3
