    [Obsolete] BZ__Arc for BezierSpline 1.2
    54 Posts 31 Posters 25.8k Views 31 Watching
    • fredo6F Offline
      This extension is now included in BezierSpline 1.4
      BZ__Arc is an extension of BezierSpline which will draw a Polyline with round corners. You can specify the offset (distance to the corners) and the number of segments as the Precision parameter (based on the number of segments for a full circle). It also manages closed polylines (loop mode).
      As the polylines remains parametric as long as it is a curve, you can later change the parameters, and move, add or remove vertices.
      Finally, as for other extensions of Bezierspline, you can convert any Sketchup curve into a Polyline with Round corners.
      Here is a small video about it.
      [flash=425,344:1cmsigfz]http://www.youtube.com/v/XpLcAusWYV0&hl=fr&fs=1[/flash:1cmsigfz]
      Indeed you need to install BezierSpline 1.21 beforehands. If not already done, just refer to the post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=13563#p100509.
      For installation of BZ__Arc, you just need to
      • drop the attached file BZ__Arc.rbin your BZ_Dir_12folder
      • drop the two icon files into the subfolders IMAGES_CadFather and IMAGES_Standard which are located in BZ_Dir_12 folder
      I am interested to know if it is useful in practice.
      This extension is integrated in the main release of BezierSpline 1.4. See this [url=http://forums.sketchucation.com/viewtopic.php?f=323&t=13563#p100509:1cmsigfz]this post[/url:1cmsigfz] for download
      • X Offline
        xrok1
        i think you're just showing off now 😆
        • E Offline
          Ecuadorian
          Let me be the first to say Thank You, Fredo, for all the time you've devoted to helping the SketchUp community! 👍
          -Miguel Lescano
          • X Offline
            xrok1
            yes thankyou. now how do i get it to show up in the toolbar? 😛
              jmmad
              Incredible Usefull tool
              Good for maiking street layouts among others.
              You have save me like a month of hard modeling with your "plugins". Or i should say for the realese of sketcup 7.9?.
              Thxs a again
              Get Upa !
                boilingsnow
                Great!!!
                Maybe even better if one can define the segment number by himself.
                • X Offline
                  xrok1
                  😳 sorry, i was so busy copying the icons i forgot to copy the .rb
                    It was dangerous to post something the 1 April 😄
                    • I Offline
                      idraft
                      Thanks a lot Fredo cant wait to try it. Youre comment about what it could be used for in practice? This one looks pretty diverse for all users, so I imagine it could used for anything, including modeling your own dentures 💚 Personally I would probably use it to create accurate site plans where the site boundaries have curves to them. 👍
                      For some reason when I downloaded the attachments i couldnt find the two image icons? they were missing. can someone please post them here, thanks Jeff.
                      • X Offline
                        xrok1
                        right click on them here and choose save as.
                        • I Offline
                          idraft
                          • MALAISEM Offline
                            MALAISE
                            An another helpful plugin made in Fr(edo6)! 😆
                            MALAISE 👍 👍
                            • W Offline
                              watkins
                              Dear Frodo,
                              Can your Plugin be used used in X, Y and Z? This is just the type of Plugin that one would use for pipe and wiring runs. An option to draw the lines by inputting the X,Y and Z co-ordinates as well as drawing the lines free-style would be great.
                              Like all those that have replied, I greatly appreciate your skill and generosity.
                              Kind regards,
                              Bob
                              • fredo6F Offline
                                @boilingsnow said:
                                Great!!!
                                Just type the number followed by 'S' in the VCB.
                                This of course is by refreence to a full circle, because there is no need to use a lot of segment for a very open angle.
                                By default this 'Precision parameter' is set to 24, which is the usual default for Sketchup circles.
                                • fredo6F Offline
                                  @watkins said:
                                  Dear Frodo,
                                  Kind regards,
                                  Bob
                                  The plugin works in 3D, as all the BezierSpline extensions.
                                  For drawing the polyline, I think you have full freedom to use the tool you like, then make it a Sketchup curve (by Weld), and then convert it to a Round Corner polyline.
                                    "Sketchup Fredo Edition" 👍 😄 👍
                                    • BurkhardB Offline
                                      Burkhard
                                      It is great and usefull, even for filet. Just draw the rectangle , weld it et voilà
                                      [http://www.ia-plus.de(http://www.ia-plus.de)]
                                      • Chris FullmerC Offline
                                        I like that Fredo is now making plugins for his plugins 😄
                                        • W Offline
                                          watkins
                                          Dear Fredo,
                                          I just tried your plugin. Brilliant! It does pipe runs beautifully when used with pipe along path.
                                          Thanks once again!
                                          Kind regards,
                                          Bob
                                            gaganraj
                                            everytime i try to leave SU....i just get dragged back.
                                            i'm unable to download the icons. For some reason there is no download link?
                                            • 1 / 3
