    Tank Museum UPDATE - new renders
    71 Posts 46 Posters 20.3k Views 46 Watching
    • soloS Offline
      HOLY CR#P!!
      These are mind blowing.
      I just wanna play with them, animate them, dirty them, pose them.
      Excellent work, I'm truly humbled by you skills, eye for detail and your abundance of patience.
      • urgenU Offline
        urgen
        ๐Ÿ˜ฒ ๐Ÿ˜ฎ
        http://i.smiles2k.net/war_smiles/dyr6uq.gif
        .... BRAVO! ๐Ÿคฃ ๐Ÿ˜„
        --pupil forever...------
          Gjenio
          Gorgeous!
          Just another little question:
          What plugins did you use most frequently during this astonishing modelling work?
            shareck
            Thanks for all the comments.
            The lowest poly model here would be the T-34 with 290175 edges and 113783 faces. I was aiming at small file size which is only 2,8mb. The king tiger so far has 850214 edges and 338435 faces.
            It's not difficult to make these track links. Each link is quite simple in shape and than you just need to copy it along a path.
            I only use standard SU tools. Only plugins i have installed are Sketchyphysics and Kerkythea exporter. The only plugin i'd wish to use is subdivide&smooth by smustard.
            All these models are done by me just as a hobby. I'm not a military enthusiast, i was just learning sketchup and i couldn't find an interesting topic. I came across some tank model in the 3d warehouse and wanted to do a tank myself. Before i finished my first one i already knew that i'll be doing another one. I find some strange joy in these machines.
            If anyone wants to use these models for rendering, animations, texturing or anything they're in the 3d warehouse (all except KV1 and King Tiger). Just search for the tag "shareck".
            There is only one pic of Abrams in the first post so i'm posting some more below:
            • Paul RussamP Offline
              Paul Russam
              shareck, hope you don't mind but I did a bit of mucking around with a couple of styles.
              I think the 3rd and 4th image look fantastic.
              http://lh5.ggpht.com/_Dz6i1AdtgoA/SbZAkO6KuPI/AAAAAAAABok/aPoEdRlUp9w/s800/challenger 2-01.jpg
              http://lh4.ggpht.com/_Dz6i1AdtgoA/SbZAqDG5SEI/AAAAAAAABos/QTO1YdjRj3s/s800/challenger 2-02.jpg
              http://lh3.ggpht.com/_Dz6i1AdtgoA/SbZAuCJYviI/AAAAAAAABo4/gDqAi6DxYik/s800/challenger 2-03.jpg
              http://lh6.ggpht.com/_Dz6i1AdtgoA/SbZAyjxtl9I/AAAAAAAABpA/b5CaJ3Z6IX4/s800/challenger 2-04.jpg
              Here's a link to the Picasa album I've dropped them in : Picasa Album
              Paul Russam
              English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
                mike d
                Mind blowing
                these are amazing images
                The grass is always GREENER on the roof.
                • david_hD Offline
                  david_h
                  Shareck. . .YOu magnificient B***ard--I love your Tanks! I salute you sir.
                  • spenceS Offline
                    spence
                    This is some incredible work, soooo nice. I want to see more of your work!
                    Spence
                    • ely862meE Offline
                      ely862me
                      I m impressed...veeery nice!!
                      Elisei (sketchupper)
                      Come and See EliseiDesign
                        paul j
                        %(#0080FF)[Hi Paul
                        Really impressed with the 4th style in particular.
                        Can you advise if that is readily available or what it is called.
                        It has the look that really appeals
                        Thanks]
                        %(#0080BF)[Shareck
                        You have done some pretty neat modelling there - well done indeed.]
                          Paul Russam
                          Its one I made by combining 2 that were in the Style Builder Competition Winners set and tweaking the settings a little. All credit to the original authors.
                          Both Image 3 and 4 are the same style but with different face styles (Hiddenline, Shaded, Monochrome etc) and 'Use sun for shading' switched on or off.
                          To be honest I cant remember the exact combination ๐Ÿ˜ณ but you get the idea. ๐Ÿ˜„
                          I've attached the mashed style.
                          Pencil Sketch _ Traced lines _ Boarder1.style
                          Paul Russam
                          • H Offline
                            Huggkruka
                            The threads are so perfect it's making me nervous! Amazingly well done.
                              shareck
                              Hi All. The King Tiger is nearly finished. I'm posting a quick render from kerkythea. i'll be trying to put some textures on it later.
                              the render came out too bright and the reflection shouldn't really be there but i've no patience to run it again.
                              • david_hD Offline
                                david_h
                                ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                                  paul j
                                  %(#0000BF)[Thanks Paul for posting your style - just downloaded it and will give it a go shortly.
                                  A bit of experimenting and hopefully get the same effect
                                  Thanks again]
                                    tomislavm
                                    Only one word Respect!
                                    This is the best collection I have ever seen, beautiful!
                                      shareck
                                      The texturing of King Tiger has started. Here's a sneak preview of what its going to be.
                                        Phil Rader AIA
                                        Speechless...these tanks are awesome. Sketchup and the talents of it's users never ceases to amaze me.
                                        http://www.philrader.com
                                          remus
                                          A quick clay render of the ford 3 ton:
                                          http://farm4.static.flickr.com/3435/3348939773_b0a08878e6.jpg
                                          Im a sucker for clay renders of good models.
                                          • Bryan KB Offline
                                            Uh...uh.... ๐Ÿ˜ฎ
                                            • 2 / 4
