    Tank Museum UPDATE - new renders
    71 Posts 46 Posters 21.2k Views 46 Watching
    • ely862meE Offline
      ely862me
      http://i.smiles2k.net/war_smiles/dyr6uq.gif
      I m impressed...veeery nice!!
      Elisei (sketchupper)
      Come and See EliseiDesign
        paul j
        %(#0080FF)[Hi Paul
        Really impressed with the 4th style in particular.
        Can you advise if that is readily available or what it is called.
        It has the look that really appeals
        Thanks]
        %(#0080BF)[Shareck
        You have done some pretty neat modelling there - well done indeed.]
        • Paul RussamP Offline
          Paul Russam
          Its one I made by combining 2 that were in the Style Builder Competition Winners set and tweaking the settings a little. All credit to the original authors.
          Both Image 3 and 4 are the same style but with different face styles (Hiddenline, Shaded, Monochrome etc) and 'Use sun for shading' switched on or off.
          To be honest I cant remember the exact combination ๐Ÿ˜ณ but you get the idea. ๐Ÿ˜„
          I've attached the mashed style.
          Pencil Sketch _ Traced lines _ Boarder1.style
          Paul Russam
          English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
          • H Offline
            Huggkruka
            The threads are so perfect it's making me nervous! Amazingly well done.
              shareck
              Hi All. The King Tiger is nearly finished. I'm posting a quick render from kerkythea. i'll be trying to put some textures on it later.
              the render came out too bright and the reflection shouldn't really be there but i've no patience to run it again.
              • david_hD Offline
                david_h
                ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                  paul j
                  %(#0000BF)[Thanks Paul for posting your style - just downloaded it and will give it a go shortly.
                  A bit of experimenting and hopefully get the same effect
                  Thanks again]
                    tomislavm
                    Only one word Respect!
                    This is the best collection I have ever seen, beautiful!
                      shareck
                      The texturing of King Tiger has started. Here's a sneak preview of what its going to be.
                        Phil Rader AIA
                        Speechless...these tanks are awesome. Sketchup and the talents of it's users never ceases to amaze me.
                        http://www.philrader.com
                          remus
                          A quick clay render of the ford 3 ton:
                          http://farm4.static.flickr.com/3435/3348939773_b0a08878e6.jpg
                          Im a sucker for clay renders of good models.
                          • Bryan KB Offline
                            Uh...uh.... ๐Ÿ˜ฎ
                              shareck
                              The King Tiger is now textured completely. I will post some renders later. For the moment have a look at partially finished model rendered in kerkythea. The bump map needs a lot of tweaking cos it looks crappy.
                                tomislavm
                                How did You made this texture!
                                  shareck
                                  Hello again. Thanks for the kind words. The texture for king tiger i painted in photoshop. I used the right RAL colours that has been used on these panzers from 1944. Paintbrushed green and red/brown patches over the dark yellow base. Then added some darkening where needed and lots of dirt using some dirt brushes found on deviantart. i made texture for left side, right side, top of the hull, top of the turret, rear of the tank, front of it, bottom hull sides, bottom of the tank and the gun barrel. These textures were projected on to apropriate parts of the tank. the most dificult part was to match the top texture to the side texture. I'm gonna make these proper renders soon but for now you can see some SU renders ๐Ÿ˜„
                                  • O Offline
                                    oalexis
                                    really nice texturing
                                      Teezer
                                      You're a man with a lot of patience and an eye for detail, sir. I salute you!Salute.gifNot Worthy.gif
                                      Real life is just another website, albeit a rather boring one.
                                        tomislavm
                                        Me again!
                                        How big texture You use?
                                        How big tank model is?
                                          shareck
                                          texture size ranged from 1200 pixels wide to 2400 pixels wide. the model without textures with copied components weights 7mb. with the textures and many of the components exploded its 26 mb.
                                          • E Offline
                                            edmund
                                            Opened and just hit the render button using Podium.
                                            • 2 / 4
