    Tank Museum UPDATE - new renders
    71 Posts 46 Posters 21.4k Views 46 Watching
    • Paul RussamP Offline
      Paul Russam
      shareck, hope you don't mind but I did a bit of mucking around with a couple of styles.
      I think the 3rd and 4th image look fantastic.
      http://lh5.ggpht.com/_Dz6i1AdtgoA/SbZAkO6KuPI/AAAAAAAABok/aPoEdRlUp9w/s800/challenger 2-01.jpg
      http://lh4.ggpht.com/_Dz6i1AdtgoA/SbZAqDG5SEI/AAAAAAAABos/QTO1YdjRj3s/s800/challenger 2-02.jpg
      http://lh3.ggpht.com/_Dz6i1AdtgoA/SbZAuCJYviI/AAAAAAAABo4/gDqAi6DxYik/s800/challenger 2-03.jpg
      http://lh6.ggpht.com/_Dz6i1AdtgoA/SbZAyjxtl9I/AAAAAAAABpA/b5CaJ3Z6IX4/s800/challenger 2-04.jpg
      Here's a link to the Picasa album I've dropped them in : Picasa Album
      Paul Russam
      English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
        mike d
        Mind blowing
        these are amazing images
        The grass is always GREENER on the roof.
        • david_hD Offline
          david_h
          Shareck. . .YOu magnificient B***ard--I love your Tanks! I salute you sir.
          • spenceS Offline
            spence
            This is some incredible work, soooo nice. I want to see more of your work!
            Spence
            • ely862meE Offline
              ely862me
              http://i.smiles2k.net/war_smiles/dyr6uq.gif
              I m impressed...veeery nice!!
              Elisei (sketchupper)
              Come and See EliseiDesign
                paul j
                %(#0080FF)[Hi Paul
                Really impressed with the 4th style in particular.
                Can you advise if that is readily available or what it is called.
                It has the look that really appeals
                Thanks]
                %(#0080BF)[Shareck
                You have done some pretty neat modelling there - well done indeed.]
                  Paul Russam
                  Its one I made by combining 2 that were in the Style Builder Competition Winners set and tweaking the settings a little. All credit to the original authors.
                  Both Image 3 and 4 are the same style but with different face styles (Hiddenline, Shaded, Monochrome etc) and 'Use sun for shading' switched on or off.
                  To be honest I cant remember the exact combination ๐Ÿ˜ณ but you get the idea. ๐Ÿ˜„
                  I've attached the mashed style.
                  Pencil Sketch _ Traced lines _ Boarder1.style
                  Paul Russam
                  • H Offline
                    Huggkruka
                    The threads are so perfect it's making me nervous! Amazingly well done.
                      shareck
                      Hi All. The King Tiger is nearly finished. I'm posting a quick render from kerkythea. i'll be trying to put some textures on it later.
                      the render came out too bright and the reflection shouldn't really be there but i've no patience to run it again.
                      • david_hD Offline
                        david_h
                        ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                          paul j
                          %(#0000BF)[Thanks Paul for posting your style - just downloaded it and will give it a go shortly.
                          A bit of experimenting and hopefully get the same effect
                          Thanks again]
                            tomislavm
                            Only one word Respect!
                            This is the best collection I have ever seen, beautiful!
                              shareck
                              The texturing of King Tiger has started. Here's a sneak preview of what its going to be.
                                Phil Rader AIA
                                Speechless...these tanks are awesome. Sketchup and the talents of it's users never ceases to amaze me.
                                http://www.philrader.com
                                  remus
                                  A quick clay render of the ford 3 ton:
                                  http://farm4.static.flickr.com/3435/3348939773_b0a08878e6.jpg
                                  Im a sucker for clay renders of good models.
                                  • Bryan KB Offline
                                    Uh...uh.... ๐Ÿ˜ฎ
                                      shareck
                                      The King Tiger is now textured completely. I will post some renders later. For the moment have a look at partially finished model rendered in kerkythea. The bump map needs a lot of tweaking cos it looks crappy.
                                        tomislavm
                                        How did You made this texture!
                                          shareck
                                          Hello again. Thanks for the kind words. The texture for king tiger i painted in photoshop. I used the right RAL colours that has been used on these panzers from 1944. Paintbrushed green and red/brown patches over the dark yellow base. Then added some darkening where needed and lots of dirt using some dirt brushes found on deviantart. i made texture for left side, right side, top of the hull, top of the turret, rear of the tank, front of it, bottom hull sides, bottom of the tank and the gun barrel. These textures were projected on to apropriate parts of the tank. the most dificult part was to match the top texture to the side texture. I'm gonna make these proper renders soon but for now you can see some SU renders ๐Ÿ˜„
                                          • O Offline
                                            oalexis
                                            really nice texturing
                                            • 2 / 4
