    Lock toolbars
    97 Posts 52 Posters 210.9k Views 52 Watching
    • dazzaD Offline
      dazza
      All people have the right to stupidity but some abuse the privilege.
        chango70
        Has anyone been working with really small buttons? I mean when you untick the View - Toolbars - Large Button? I haven't had problems with unsticking icons since i started using small (tiny) buttons which admittedly is a bit of a strain on one's eyes.
        • ToboboT Offline
          Tobobo
          Photoshop and CAD for that matter have the ability to save profiles for different users. This would solve the issues of toolbars and also templates, and the profile could include Rubys as well.
          Toby
          Philippians 4:13
          • boofredlayB Offline
            boofredlay
            I cannot say how many times I have mentioned that I want locking toolbars but here I go again...
            Please!
            • BurkhardB Offline
              Burkhard
              It doesn't make sense if in my profile the toolbars are unlocked again 👊
              http://www.ia-plus.de
              • ToboboT Offline
                Tobobo
                Its more of a seperate issue, but if you could take your work space with you, those who Hotdesk or travel to different offices would not have to spend 5 mins setting up the toolbars. If SU 7 had lockable toolbars and the profile system they would work together really well.
                Toby
                Philippians 4:13
                  boofredlay
                  Bump.
                  I added a couple new ruby scripts today and what do you know... all my toolbars were flung all over my screen. And then I had to fix it all over again at home.
                  Please fix this Google.
                    @jim said:
                    I made this video back in February. It gets less funny every time it happens. There's a lot of talk about V7 features, but if all it does is fix the toolbars, I'd be happy.
                    Error 404 (Not Found)!!1
                    (sketchuptips.blogspot.com)
                    🤣 Been there, done that!
                      Another thing in regards to toolbars. Whenever I need for whatever reason to resize the SketchUp window, toolbar mayhem occurs. I wish they would not re arrange themself automatically. I prefer getting a drop down menu with the off-screen tools appearing instead as with many other application with toolbars.
                      This is another example where SketchUp tried to sort things out for you without actually succeeding. (Ref: http://www.sketchucation.com/forums/scf/viewtopic.php?f=10&t=14839)
                      • EdsonE Offline
                        Edson
                        i found a way to lock my toobars on mac. i am not sure it works on windows.
                        1. in a new file i enable all the extensions i want (sketchup-->preferences-->extensions), open the toolbars not open (view-->tool palettes) and place them where i want them to stay.
                        2. then i save the file as a new template.
                        in my case, when i opened a new file only some of the toolbars opened, although they where in the right spot. if this is the case for you, go to the next step.
                        1. open the template file directly (file-->open) from the templates folder.
                        2. enable the toolbars that did not show up. save the file.
                        3. open a new file (file-->new). all you toolbars should be there, on the correct spot too.
                        http://www.mahfuz.arq.br
                          TriciaS
                          Now, start on the toolbar problem
                          Ken
                          Hi Ken,
                          We do have some bugs recorded regarding toolbar issues. But I want to make sure we have the issue you are talking about. Can you give a quick description of it? Or maybe add it to the Bugs section?
                          Thanks in advance,
                          Tricia
                          • X Offline
                            xrok1
                            do you guys use SU?
                            the toolbars are crazy. their never in the same place twice, when you add or remove a plugin. they stack, restack, something left across the top (horizontal)will be at the bottom (vertical) the next time; you can group them logically and then they get spread-out. very frustrating to have to get used to a different (random)interface all the time. 👊 THere should be a way to lock them, or a .ini file to keep their positions or something.
                            • jeff hammondJ Offline
                              The status bar no longer updates on the Mac. When performing actions on the Mac that show progress in the status bar (e.g. Sandbox actions), the status bar did not update. The status bar should now show progress for lengthy tool actions.
                              oh, nice.
                                l.frisken
                                i've also found that if I move the toolbars and then don't save before i exit it looses the position. And with all the scf toolbars i can't put more than one toolbar on a certain level. It just bumps them to different levels.
                                oh yeh and I'm sure that everyone wants the back button back on the component and material browser!! 😞
                                  boofredlay
                                  Thanks in advance,
                                  Tricia
                                  Have a look here:
                                  http://www.sketchucation.com/forums/scf/viewtopic.php?f=10&t=9117&st=0&sk=t&sd=a
                                    Ken
                                    Hi Ken,
                                    Thanks in advance,
                                    Tricia
                                    http://www.sketchucation.com/forums/scf/viewtopic.php?f=79&t=15752&p=125765&hilit=toolbar+problem#p122260
                                    http://www.sketchucation.com/forums/scf/viewtopic.php?f=10&t=9117&hilit=+toolbar
                                    http://sketchuptips.blogspot.com/2008/02/sketchup-annoyances-toolbars.html <- Excellent illustration of the problem
                                    • And if you should accidentally click the Restore button in the SU window title bar, the toolbars are scattered all over the place.
                                    • If you add a new plugin which adds a new toolbar you risk it blowing up your entire toolbar setup.
                                    • I can't seem to some free floating toolbar to remain free floating between sessions, they reattach themself to the top edge. (V-Ray toolbar)
                                    • Freefloating toolbar's window are too small when you start up SU, it's like their size is initally calculated as if the icons where small. It restores itself when you click the toolbar though.
                                      BUDLA
                                      I dondt remember where i download it,but it working in SU 6!
                                      Maybe working in 7 too!
                                      Budla
                                      SKETCHUP_TOOLBARS_SETTINGS.pdf
                                        BUDLA
                                        Budla
                                          kwistenbiebel
                                          Any roadmap for future updates concerning the polycount bug,slowdown bug and shadow bug?
                                          I guess not 😉
                                            "Ceterum ceseo Carthaginem delendam esse..."
                                            • 2 / 5
