    Prince IO Sketchup Game Demo
    42 Posts 26 Posters 34.7k Views 26 Watching
    • L
      linea
      AWESOME SCOTT & TODD! Its fantastic, I had no idea this sort of thing was possible in SU. I want to make one! "How?" is a question I'm sure you'll be asked alot more.
        Dhruv
        I made it run along Y axis as well, it was a little change and assigned J and S for jump and Swordhit respectively. Arrow keys for direction. Ill try and add more features.
        Cheers,
        Dhruv
          Dhruv
          Hey Coen Naninck,
          I wanted to do something related to Dynamic components, like when you click on an object/model, it brings to some website. Like lets say I have built a Kawasaki motor bike , when I left click on it brings me to some kawasaki website online.
          Will try out though, see if I can come out with this feature. It would be cool to use it in a game.
          Cheers,
          Dhruv
            • N
              notareal
              • H
                HFM
                @fletch said:
                thanks! I wanted this first time I saw it! πŸ˜†
                unfortunately I'm at work, and they refuse to give me SU7 for a few more weeks... no way we could get an SU6 version, is there?!
                It's pretty simple to make this SU6 compatible. Just save the maps [.skp] as SU6
                  Matt666
                  That's incredible...
                  Frenglish at its best !
                  My scripts
                  • B
                    BTM
                    I have a mac running OSX 10.5.5, and for every frame, I encounter the error
                    %(#808080)["newGroundz:
                    value=>-5000<
                    TypeError: Value undefined (result of expression value.split) is not object."].
                    the error pops up first, i have to click enter, then next frame, same error, this repeat over and over, then the knight falls through the floor, screams, and SU messes up. Any idea why?
                    • scottliningerS
                      scottlininger
                      BTM,
                      Ah, there's a snippet of code in the .rb file that detects if you're on a mac, but it was added back when the mac/su6 had WebDialog errors that are fixed in 7.
                      I'll need to test on my Mac with SU7 and post a fixed version.
                      • Scott Lininger
                        SketchUp Software Engineer
                        Have you visited the Ruby API Docs?
                      • plot-parisP
                        plot-paris
                        fantastic! thank you so much for posting this game. indeed, a new era is about to begin 😍
                        • C
                          chief1234
                          Thanks Scott, this is great!!
                          I'm working on incorporating this into a school project, and I'm wondering if there's a way to load the engine onto any map without it being hardcoded.
                          IE - if I could download anything from the 3D warehouse, start the Knight plugin and be able to navigate?
                          Thanks in advance,
                          Luke J.
                          • scottliningerS
                            scottlininger
                            Well, you could do one of two things.
                            1. Open one of the .skp files inside Plugins/knightgame and edit the maps directly.
                            2. Open the knightgame.rb file and modify the code to not load in a new model but simply run on top of the current model.
                            So yeah... it's doable. Let me know if you have specific questions. πŸ˜„
                            • Scott Lininger
                            • C
                              chief1234
                              Right, changing the code to run on top of the current model would be ideal.
                              Unfortunately, I'm a novice at Ruby so I'm not quite sure how to do this...
                              I tried removing any direct references to maps in the file_loaded? method at the bottom. This way the engine will run, but only on maps AFTER they have been hardcoded, run, then the code removed again...
                              Obviously I'm missing a vital part of the puzzle...
                              Any help out of your busy schedule would be greatly appreciated!
                              Thanks,
                              Luke J.
                              • T
                                toxic
                                Thats fantastic
                                So when do we get worms
                                • T
                                  trickout
                                  when i try to go to the linked site for the .zip, it says sight unavailable
                                  can someone post it somewhere else?
                                  • scottliningerS
                                    scottlininger
                                    Hello trickout. Terribly sorry for the broken link. Please try again.
                                    Cheers,
                                    • Scott Lininger
                                    • T
                                      trickout
                                      Thank you for fixing the link. How can I edit the code, for instance make it move in 3 dimensions instead of just on a plane? I've tried to find a .rb editor but no success. 😞
                                      • T
                                        todd burch
                                        .rb files are merely text files. Notepad, Textedit, lots of editors will work. Always save as plain text.
                                          August
                                          ... You can hear more details from the original preso: http://www.youtube.com/watch?v=FALvwBN5-hc
                                          YouTube says: "We're sorry, this video is no longer available."
                                          Any alternate sources?
                                          Thanks,
                                          August
                                          β€œAn idea, like a ghost, must be spoken to a little before it will explain itself.”
                                          [floatr:v1mcbde2]-- Charles Dickens[/floatr:v1mcbde2]
                                          • scottliningerS
                                            scottlininger
                                            Hey August,
                                            I've sent a query to the code site folks asking what happened to the video.
                                            • Scott Lininger
                                            • 1 / 3
