    Prince IO Sketchup Game Demo
    42 Posts 26 Posters 34.3k Views 26 Watching
      Daniel S
      Amazing game!!!
      Great work!!
      Thank you,
      Daniel S
        Dhruv
        Thanks Scott, can feel that many more things can be done integrating javascript with sketchup.
        Cheers,
        Dhruv
          Dhruv
          Hey Scott,
          I tried converting 2dimensional game into 3d, like ability to go left and right. I did make some changes and it turns left and right, but does not run in that direction.
          And yes I changed 3rd person view to 1st person and going forward is up key and backward is down key. So before doing that I basically commented jump sword functions.
          • Chris FullmerC
            Thanks for posting that Scott!
            • FletchF
              Fletch
              thanks! I wanted this first time I saw it! ๐Ÿ˜†
              unfortunately I'm at work, and they refuse to give me SU7 for a few more weeks... no way we could get an SU6 version, is there?!
              Fletch
              • L
                linea
                AWESOME SCOTT & TODD! Its fantastic, I had no idea this sort of thing was possible in SU. I want to make one! "How?" is a question I'm sure you'll be asked alot more.
                  Dhruv
                  I made it run along Y axis as well, it was a little change and assigned J and S for jump and Swordhit respectively. Arrow keys for direction. Ill try and add more features.
                  Cheers,
                  Dhruv
                    Dhruv
                    Hey Coen Naninck,
                    I wanted to do something related to Dynamic components, like when you click on an object/model, it brings to some website. Like lets say I have built a Kawasaki motor bike , when I left click on it brings me to some kawasaki website online.
                    Will try out though, see if I can come out with this feature. It would be cool to use it in a game.
                    Cheers,
                    Dhruv
                      • N
                        notareal
                        • H
                          HFM
                          It's pretty simple to make this SU6 compatible. Just save the maps [.skp] as SU6
                            Matt666
                            ๐Ÿ˜ฒ ๐Ÿ˜ฒ ๐Ÿ˜ฒ
                            That's incredible...
                            Frenglish at its best !
                            My scripts
                            • B
                              BTM
                              I have a mac running OSX 10.5.5, and for every frame, I encounter the error
                              %(#808080)["newGroundz:
                              value=>-5000<
                              TypeError: Value undefined (result of expression value.split) is not object."].
                              the error pops up first, i have to click enter, then next frame, same error, this repeat over and over, then the knight falls through the floor, screams, and SU messes up. Any idea why?
                              • scottliningerS
                                scottlininger
                                BTM,
                                Ah, there's a snippet of code in the .rb file that detects if you're on a mac, but it was added back when the mac/su6 had WebDialog errors that are fixed in 7.
                                I'll need to test on my Mac with SU7 and post a fixed version.
                                • Scott Lininger
                                  SketchUp Software Engineer
                                  Have you visited the Ruby API Docs?
                                • plot-parisP
                                  plot-paris
                                  fantastic! thank you so much for posting this game. indeed, a new era is about to begin ๐Ÿ˜
                                  • C
                                    chief1234
                                    Thanks Scott, this is great!!
                                    I'm working on incorporating this into a school project, and I'm wondering if there's a way to load the engine onto any map without it being hardcoded.
                                    IE - if I could download anything from the 3D warehouse, start the Knight plugin and be able to navigate?
                                    Thanks in advance,
                                    Luke J.
                                    • scottliningerS
                                      scottlininger
                                      Well, you could do one of two things.
                                      1. Open one of the .skp files inside Plugins/knightgame and edit the maps directly.
                                      2. Open the knightgame.rb file and modify the code to not load in a new model but simply run on top of the current model.
                                      So yeah... it's doable. Let me know if you have specific questions. ๐Ÿ˜„
                                      • Scott Lininger
                                      • C
                                        chief1234
                                        Right, changing the code to run on top of the current model would be ideal.
                                        Unfortunately, I'm a novice at Ruby so I'm not quite sure how to do this...
                                        I tried removing any direct references to maps in the file_loaded? method at the bottom. This way the engine will run, but only on maps AFTER they have been hardcoded, run, then the code removed again...
                                        Obviously I'm missing a vital part of the puzzle...
                                        Any help out of your busy schedule would be greatly appreciated!
                                        Thanks,
                                        Luke J.
                                        • T
                                          toxic
                                          Thats fantastic
                                          So when do we get worms
                                          • T
                                            trickout
                                            when i try to go to the linked site for the .zip, it says sight unavailable
                                            can someone post it somewhere else?
                                            • 1 / 3
