    Prince IO Sketchup Game Demo
    42 Posts 26 Posters 34.7k Views 26 Watching
    • H
      HFM
      @fletch said:
      thanks! I wanted this first time I saw it! πŸ˜†
      unfortunately I'm at work, and they refuse to give me SU7 for a few more weeks... no way we could get an SU6 version, is there?!
      It's pretty simple to make this SU6 compatible. Just save the maps [.skp] as SU6
        Matt666
        That's incredible...
        Frenglish at its best !
        My scripts
        • B
          BTM
          I have a mac running OSX 10.5.5, and for every frame, I encounter the error
          %(#808080)["newGroundz:
          value=>-5000<
          TypeError: Value undefined (result of expression value.split) is not object."].
          the error pops up first, i have to click enter, then next frame, same error, this repeat over and over, then the knight falls through the floor, screams, and SU messes up. Any idea why?
          • scottliningerS
            scottlininger
            BTM,
            Ah, there's a snippet of code in the .rb file that detects if you're on a mac, but it was added back when the mac/su6 had WebDialog errors that are fixed in 7.
            I'll need to test on my Mac with SU7 and post a fixed version.
            • Scott Lininger
              SketchUp Software Engineer
              Have you visited the Ruby API Docs?
            • plot-parisP
              plot-paris
              fantastic! thank you so much for posting this game. indeed, a new era is about to begin 😍
              • C
                chief1234
                Thanks Scott, this is great!!
                I'm working on incorporating this into a school project, and I'm wondering if there's a way to load the engine onto any map without it being hardcoded.
                IE - if I could download anything from the 3D warehouse, start the Knight plugin and be able to navigate?
                Thanks in advance,
                Luke J.
                • scottliningerS
                  scottlininger
                  Well, you could do one of two things.
                  1. Open one of the .skp files inside Plugins/knightgame and edit the maps directly.
                  2. Open the knightgame.rb file and modify the code to not load in a new model but simply run on top of the current model.
                  So yeah... it's doable. Let me know if you have specific questions. πŸ˜„
                  • Scott Lininger
                  • C
                    chief1234
                    Right, changing the code to run on top of the current model would be ideal.
                    Unfortunately, I'm a novice at Ruby so I'm not quite sure how to do this...
                    I tried removing any direct references to maps in the file_loaded? method at the bottom. This way the engine will run, but only on maps AFTER they have been hardcoded, run, then the code removed again...
                    Obviously I'm missing a vital part of the puzzle...
                    Any help out of your busy schedule would be greatly appreciated!
                    Thanks,
                    Luke J.
                    • T
                      toxic
                      Thats fantastic
                      So when do we get worms
                      • T
                        trickout
                        when i try to go to the linked site for the .zip, it says sight unavailable
                        can someone post it somewhere else?
                        • scottliningerS
                          scottlininger
                          Hello trickout. Terribly sorry for the broken link. Please try again.
                          Cheers,
                          • Scott Lininger
                          • T
                            trickout
                            Thank you for fixing the link. How can I edit the code, for instance make it move in 3 dimensions instead of just on a plane? I've tried to find a .rb editor but no success. 😞
                            • T
                              todd burch
                              .rb files are merely text files. Notepad, Textedit, lots of editors will work. Always save as plain text.
                                August
                                ... You can hear more details from the original preso: http://www.youtube.com/watch?v=FALvwBN5-hc
                                YouTube says: "We're sorry, this video is no longer available."
                                Any alternate sources?
                                Thanks,
                                August
                                β€œAn idea, like a ghost, must be spoken to a little before it will explain itself.”
                                [floatr:v1mcbde2]-- Charles Dickens[/floatr:v1mcbde2]
                                • scottliningerS
                                  scottlininger
                                  Hey August,
                                  I've sent a query to the code site folks asking what happened to the video.
                                  • Scott Lininger
                                  • T
                                    Trimmer
                                    Hi Scott,
                                    I'm Having the same problem BTM did back in Nov:
                                    I have a mac running OSX 10.5.6, and for every frame, I encounter the error
                                    value=>-5000<
                                    Have you found a way to correct this?
                                      driven
                                      Hi All,
                                      did anyone ever get this running on a Mac? can something be changed to make it run?
                                      • T
                                        todd burch
                                        This was working on a Mac back when Scott posted this thread. Did someone or SU break it since then?
                                          driven
                                          hi Todd,
                                          I only downloaded it recently and it appears to have the same symptoms as BTM's early post described, so I thought it had not been fixed....
                                          or the solution had moved on to a different thread, as sometimes happens...
                                          so, it's not currently working on 7.1 on a Mac and although I'm happy to modify the code, I'd need some instructions.
                                          cheers
                                          • scottliningerS
                                            scottlininger
                                            Hmm. Todd's cleaned up version was working on mac. I'll take a look...
                                            • Scott Lininger
                                            • 2 / 3
