    [TUTORIAL]: texturing organic form (subsmooth)
    36 Posts 17 Posters 22.2k Views 17 Watching
    • FrederikF
      Frederik
      @julius said:
      and how do you porject them? πŸ’š
      I import the JPG and once you explode the JPG, it will be available in your "In model" materials as a Projected material ready to be applied on a surface... πŸ˜‰
      @julius said:
      also, is it possible to make such stunning bump maps in KT, like the second image kwist posted?
      To me it doesn't look like Bump mapping... 😐
      I assume that Kwistenbiebel have used Displacement mapping, which isn't availeble in KT2008...
      Cheers
      Kim Frederik
        Daniel Bouchard
        Thanks for this tutorial Kwistenbiebel.
        Very useful for me.
        Daniel
        • K
          kwistenbiebel
          @frederik said:
          I assume that Kwistenbiebel have used Displacement mapping...
          Indeed, I used displacement maps on the object.
          It works just like adding a bump map ( a Black@White image defining depth).
          The only difference is that displacement will actually deform the geometry by subdividing it to show depth, while a bump map is only mimicing it.
          Curently displacement is supported by Vray, Fry, Maxwell and Indigo.
          For architectural scenes, bump maps most of the times are sufficient, as displacement tends to increase render time considerably. But the results can be convincing.
          This is an example of displacement on that same form using (SK)indigo:
          http://i140.photobucket.com/albums/r3/kwistenbiebel1/displ-2a.jpg
          http://i140.photobucket.com/albums/r3/kwistenbiebel1/displ1c.jpg
            Macro photography πŸ˜‰
            • david_hD
              david_h
              Biebel . . .you just amaze me. . .. πŸ‘
              • C
                Click Draw
                I love this forum. I've learned so much more since I joined. Thx to everyone! Great tutorial. I got the material distributing evenly, I just have to learn to texture properly....
                Jeff
                Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                • pbacotP
                  This is amazing. I never saw displacement like this before. Not that I have experience rendering. But I can use the texturing technique right away. Thanks for posting so people like me can get "edicated"! B
                  • C
                    Click Draw
                    Hi Kwistenbiebel,
                    Any chance of you doing a Tut on the technique of bump mapping or the way you put or change the actual surface texture? Or, is this something done in another program? I got the understanding of evenly patterning a material but you have pics showing that the surface is not smooth. Thanks in advance....
                    Jeff
                    • GaieusG
                      Hi Jeff,
                      SU doesn't support either bupmapping or displacement. That part was done in a 3rd party renderer.
                      • C
                        Click Draw
                        Thanks Gaieus,
                        Appreciate that. So that would be one like Podium or Vray?
                        Jeff
                        • GaieusG
                          Yes exactly. Even some of those do not do displacement (like Kerkythea at the moment)
                          • C
                            Click Draw
                            What is your preferrance for a rendering program. I'd like to get as much feedback and opinions as possible before I layout the money.
                            Jeff
                            • GaieusG
                              I don't really render too much (no time to learn it well).I used Podium and Kerkythea (a bit more this latter one). It is free and Podium also has a free version with images limited to 500x500 pixels.
                              Indigo is also free.
                              • C
                                Click Draw
                                Good stuff! Thanks
                                Jeff
                                • W
                                  wheay
                                  wow! i want to learn this. since im using vray and loving its rendering capability. i want to learn the grass thing, it really amazed me. hope more tutorials on this.
                                  "i try to learn everyday"
                                  http://designerslandmark.blogspot.com/
                                  • C
                                    Click Draw
                                    Hey wheay,
                                    Do you know of a better tutorial than the one on the Vray site? I'd like to learn what the settings are for and so on. Thanks...
                                    Jeff
                                    • K
                                      krowka_smieszka
                                      kwistenbiebel how did u make this organic shape? I know that may be silly question but I am still learning how to use sketchup...
                                      • soloS
                                        Krowka, hope this helps, it's a very crude and fast example, Biebel's shape is cleaner.
                                        [flash=600,400:3gn1ftdy]http://vimeo.com/moogaloop.swf?clip_id=2335698&server=vimeo.com&show_title=1&show_byline=1&show_portrait=0&color=00ADEF&fullscreen=1[/flash:3gn1ftdy]
                                        Displaced with ecosystem in Vue:
                                        http://img81.imageshack.us/img81/938/biebelshapefu4.jpg
                                        • C
                                          Click Draw
                                          Very cool Solo....how about doing a tut to show how to displace with Vray? Don't make me bag....cause I will! πŸ˜„
                                          • soloS
                                            Jeff, I would like to help with V-ray but my trial has ended and I had a choice between v-ray and Vue and I'm sure you know who won. I am sure once Kwistenbiebel gets settled into Oz he will get one going, after all this is his turf. πŸ˜‰
