    [TUTORIAL]: texturing organic form (subsmooth)
    36 Posts 17 Posters 22.2k Views 17 Watching
    • GaieusG
      Hi Jeff,
      SU doesn't support either bupmapping or displacement. That part was done in a 3rd party renderer.
      • C
        Click Draw
        Thanks Gaieus,
        Appreciate that. So that would be one like Podium or Vray?
        Jeff
        Have I mentioned how much of a laugh I get out of some of the Signatures on here!
        • GaieusG
          Yes exactly. Even some of those do not do displacement (like Kerkythea at the moment)
          • C
            Click Draw
            What is your preferrance for a rendering program. I'd like to get as much feedback and opinions as possible before I layout the money.
            Jeff
            • GaieusG
              I don't really render too much (no time to learn it well).I used Podium and Kerkythea (a bit more this latter one). It is free and Podium also has a free version with images limited to 500x500 pixels.
              Indigo is also free.
              • C
                Click Draw
                Good stuff! Thanks
                Jeff
                • W
                  wheay
                  wow! i want to learn this. since im using vray and loving its rendering capability. i want to learn the grass thing, it really amazed me. hope more tutorials on this.
                  "i try to learn everyday"
                  http://designerslandmark.blogspot.com/
                  • C
                    Click Draw
                    Hey wheay,
                    Do you know of a better tutorial than the one on the Vray site? I'd like to learn what the settings are for and so on. Thanks...
                    Jeff
                    • K
                      krowka_smieszka
                      kwistenbiebel how did u make this organic shape? I know that may be silly question but I am still learning how to use sketchup...
                      • soloS
                        Krowka, hope this helps, it's a very crude and fast example, Biebel's shape is cleaner.
                        [flash=600,400:3gn1ftdy]http://vimeo.com/moogaloop.swf?clip_id=2335698&server=vimeo.com&show_title=1&show_byline=1&show_portrait=0&color=00ADEF&fullscreen=1[/flash:3gn1ftdy]
                        Displaced with ecosystem in Vue:
                        http://img81.imageshack.us/img81/938/biebelshapefu4.jpg
                        • C
                          Click Draw
                          Very cool Solo....how about doing a tut to show how to displace with Vray? Don't make me bag....cause I will! 😄
                          • soloS
                            Jeff, I would like to help with V-ray but my trial has ended and I had a choice between v-ray and Vue and I'm sure you know who won. I am sure once Kwistenbiebel gets settled into Oz he will get one going, after all this is his turf. 😉
                            • C
                              Click Draw
                              No worries....I'm sure he'll show us mower 🤣
                              • T
                                tulacong
                                thank you very much.I wan it
                                • K
                                  krowka_smieszka
                                  Thank u for video solo... i see that i need get some plugins 😒
                                  • B
                                    berbay
                                    How do you scale the texture that you have applied on that surface?? anyone can help me?
                                    • massimoM
                                      massimo Moderator
                                      Right click on the surface-->entity info-->click on the material's thumbnail-->edit. Or pick the material with the eyedropper, then go to the material panel-->edit.
                                        Aerilius
                                        you can (unfortunately) only edit a projected texture's positioning on the same face from where you projected it or from a parallel face.
                                        That means:
                                        Either you have to remember where the red-dashed triangle (second image) was - or, better, you project the texture from a face outside of that organic shape (like an image) and then you just hide this "helper face" and don't delete it. Keep it in the same group like the organic shape. Later you can right-click on that "helper face" and move, rotate and skew the texture; then project it again on the organic shape.
                                        • B
                                          berbay
                                          oh ok it works like that!! thank you…. but i could do it if the material is not from sketchup. for vismat materials I couldnt do.
                                          and Aerilius thanks for your reply, it seemed pretty advanced for me, but I will try…
                                          i opened a new post for the scene i am working on… the materials I use are vismats and i dont know how to control them yet... 😕
                                          http://forums.sketchucation.com/viewtopic.php?f=18&t=40824
                                          • andrea.biancoA
                                            andrea.bianco
                                            Thanks a lot for the tip, it's very useful indeed.
                                            Andrea A. Bianco
                                            http://www.andreabianco.eu
                                            HW: i7 3.8GHz | nVidia GTX590 3GB | 8GB RAM
                                            SW: SketchUp, Octane, Adobe CC, Painter, Windows 8.1 64
                                            • 2 / 2
