    [TUTORIAL]: texturing organic form (subsmooth)
    36 Posts 17 Posters 20.8k Views 17 Watching
    • pbacotP Offline
      This is amazing. I never saw displacement like this before. Not that I have experience rendering. But I can use the texturing technique right away. Thanks for posting so people like me can get "edicated"! B
        Click Draw
        Hi Kwistenbiebel,
        Any chance of you doing a Tut on the technique of bump mapping or the way you put or change the actual surface texture? Or, is this something done in another program? I got the understanding of evenly patterning a material but you have pics showing that the surface is not smooth. Thanks in advance....
        Jeff
        Have I mentioned how much of a laugh I get out of some of the Signatures on here!
          Hi Jeff,
          SU doesn't support either bupmapping or displacement. That part was done in a 3rd party renderer.
            Click Draw
            Thanks Gaieus,
            Appreciate that. So that would be one like Podium or Vray?
            Jeff
              Yes exactly. Even some of those do not do displacement (like Kerkythea at the moment)
                Click Draw
                What is your preferrance for a rendering program. I'd like to get as much feedback and opinions as possible before I layout the money.
                Jeff
                  I don't really render too much (no time to learn it well).I used Podium and Kerkythea (a bit more this latter one). It is free and Podium also has a free version with images limited to 500x500 pixels.
                  Indigo is also free.
                    Click Draw
                    Good stuff! Thanks
                    Jeff
                    • W Offline
                      wheay
                      wow! i want to learn this. since im using vray and loving its rendering capability. i want to learn the grass thing, it really amazed me. hope more tutorials on this.
                      "i try to learn everyday"
                      http://designerslandmark.blogspot.com/
                        Click Draw
                        Hey wheay,
                        Do you know of a better tutorial than the one on the Vray site? I'd like to learn what the settings are for and so on. Thanks...
                        Jeff
                          krowka_smieszka
                          kwistenbiebel how did u make this organic shape? I know that may be silly question but I am still learning how to use sketchup...
                          • soloS Offline
                            Krowka, hope this helps, it's a very crude and fast example, Biebel's shape is cleaner.
                            [flash=600,400:3gn1ftdy]http://vimeo.com/moogaloop.swf?clip_id=2335698&server=vimeo.com&show_title=1&show_byline=1&show_portrait=0&color=00ADEF&fullscreen=1[/flash:3gn1ftdy]
                            Displaced with ecosystem in Vue:
                            http://img81.imageshack.us/img81/938/biebelshapefu4.jpg
                              Click Draw
                              Very cool Solo....how about doing a tut to show how to displace with Vray? Don't make me bag....cause I will! πŸ˜„
                              • soloS Offline
                                Jeff, I would like to help with V-ray but my trial has ended and I had a choice between v-ray and Vue and I'm sure you know who won. I am sure once Kwistenbiebel gets settled into Oz he will get one going, after all this is his turf. πŸ˜‰
                                  Click Draw
                                  No worries....I'm sure he'll show us mower 🀣
                                    tulacong
                                    thank you very much.I wan it
                                      krowka_smieszka
                                      Thank u for video solo... i see that i need get some plugins πŸ˜’
                                        berbay
                                        How do you scale the texture that you have applied on that surface?? anyone can help me?
                                        • massimoM Offline
                                          massimo Moderator
                                          Right click on the surface-->entity info-->click on the material's thumbnail-->edit. Or pick the material with the eyedropper, then go to the material panel-->edit.
                                            Aerilius
                                            you can (unfortunately) only edit a projected texture's positioning on the same face from where you projected it or from a parallel face.
                                            That means:
                                            Either you have to remember where the red-dashed triangle (second image) was - or, better, you project the texture from a face outside of that organic shape (like an image) and then you just hide this "helper face" and don't delete it. Keep it in the same group like the organic shape. Later you can right-click on that "helper face" and move, rotate and skew the texture; then project it again on the organic shape.
                                            • 2 / 2
