    [TUTORIAL]: texturing organic form (subsmooth)
    36 Posts 17 Posters 21.2k Views 17 Watching
    • FrederikF Offline
      Frederik
      Thanks, Chris..!! πŸ˜„
      Slightly different from how I project textures, but a very neat way of doing it... πŸ˜‰
      Cheers
      Kim Frederik
        kwistenbiebel
        Thanks.
        I wish Whaats UV-tools would do a better job at texturing things like this , but unfortunately the plugin is unresponsive when trying 'spherical' mapping....
        I am sharing the object on 3Dwarehouse, so people can try to texture it.
        Maybe someone comes up with a method for a non-view-dependant method?
        Here's the link:
        http://sketchup.google.com/3dwarehouse/details?mid=1cfa3f825fd2fcfb4083c414ed3a6752
          Easy method indeed πŸ˜‰
          This wheel has a lot facets (like your subsmooth) for dark reasons because it should be exported to Zbrush πŸ˜’
          (post subdivide in Zb seems problematic so subdivided is made in SU πŸ˜’
          Here podium bump maxi, render with "biebel_settings.xml" who is this guy? πŸ’š
          Model by Orgelf
            Julius
            http://img379.imageshack.us/img379/6339/13474370hn5.jpg
            did i do something wrong?
            and how do you porject them? πŸ’š
            also, is it possible to make such stunning bump maps in KT, like the second image kwist posted?
            • FrederikF Offline
              Frederik
              I import the JPG and once you explode the JPG, it will be available in your "In model" materials as a Projected material ready to be applied on a surface... πŸ˜‰
              To me it doesn't look like Bump mapping... 😐
              I assume that Kwistenbiebel have used Displacement mapping, which isn't availeble in KT2008...
              Cheers
              Kim Frederik
                Daniel Bouchard
                Thanks for this tutorial Kwistenbiebel.
                Very useful for me.
                Daniel
                  kwistenbiebel
                  @frederik said:
                  I assume that Kwistenbiebel have used Displacement mapping...
                  Indeed, I used displacement maps on the object.
                  It works just like adding a bump map ( a Black@White image defining depth).
                  The only difference is that displacement will actually deform the geometry by subdividing it to show depth, while a bump map is only mimicing it.
                  Curently displacement is supported by Vray, Fry, Maxwell and Indigo.
                  For architectural scenes, bump maps most of the times are sufficient, as displacement tends to increase render time considerably. But the results can be convincing.
                  This is an example of displacement on that same form using (SK)indigo:
                  http://i140.photobucket.com/albums/r3/kwistenbiebel1/displ-2a.jpg
                  http://i140.photobucket.com/albums/r3/kwistenbiebel1/displ1c.jpg
                    Macro photography πŸ˜‰
                    • david_hD Offline
                      david_h
                      Biebel . . .you just amaze me. . .. πŸ‘
                        Click Draw
                        I love this forum. I've learned so much more since I joined. Thx to everyone! Great tutorial. I got the material distributing evenly, I just have to learn to texture properly....
                        Jeff
                        Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                        • pbacotP Offline
                          This is amazing. I never saw displacement like this before. Not that I have experience rendering. But I can use the texturing technique right away. Thanks for posting so people like me can get "edicated"! B
                            Click Draw
                            Hi Kwistenbiebel,
                            Any chance of you doing a Tut on the technique of bump mapping or the way you put or change the actual surface texture? Or, is this something done in another program? I got the understanding of evenly patterning a material but you have pics showing that the surface is not smooth. Thanks in advance....
                            Jeff
                              Hi Jeff,
                              SU doesn't support either bupmapping or displacement. That part was done in a 3rd party renderer.
                                Click Draw
                                Thanks Gaieus,
                                Appreciate that. So that would be one like Podium or Vray?
                                Jeff
                                  Yes exactly. Even some of those do not do displacement (like Kerkythea at the moment)
                                    Click Draw
                                    What is your preferrance for a rendering program. I'd like to get as much feedback and opinions as possible before I layout the money.
                                    Jeff
                                      I don't really render too much (no time to learn it well).I used Podium and Kerkythea (a bit more this latter one). It is free and Podium also has a free version with images limited to 500x500 pixels.
                                      Indigo is also free.
                                        Click Draw
                                        Good stuff! Thanks
                                        Jeff
                                        • W Offline
                                          wheay
                                          wow! i want to learn this. since im using vray and loving its rendering capability. i want to learn the grass thing, it really amazed me. hope more tutorials on this.
                                          "i try to learn everyday"
                                          http://designerslandmark.blogspot.com/
                                            Click Draw
                                            Hey wheay,
                                            Do you know of a better tutorial than the one on the Vray site? I'd like to learn what the settings are for and so on. Thanks...
                                            Jeff
