    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.0m Views 183 Watching
    • fredo6F Offline
      **%(#008000)[# Permission to use this software for any purpose and without fee is hereby granted
      Distribution of this software for any purpose is subject to:
      - the expressed, written consent of the author
      - the inclusion of the present copyright notice in all copies.]**
      Please UPGRADE to this latest version 2.2 if you run SU 2017 (for certification) and above.
      http://forums.sketchucation.com/download/file.php?id=49290
      BezierSpline draws a variety of Polylines, Bezier and Spline curves, all in 3D. The present release gathers all extensions, including those published recently (Courbette, Catmull, F-Spline, DogBone, T_Bone, Polyline for Animation, etc…).
      • All curves are based on a sequence of control points, which is entered by the user in interactive mode.
      • A Precision parameter allows to adjust the number of segments when the curve is generated.
      • For some curves, there may be extra parameters, accessible via the TAB key.
      • All curves can be later edited. You can move, delete, add control points
      • As of version 1.4, you can also transform a curve of one type into a curve of another type, both sharing the same control points.
      Here is a comparison between the different Splines, based on the same Control points:
      http://forums.sketchucation.com/download/file.php?id=49286
      Note: The doc is slightly outdated, but gives an overview of the essential features. All PDF files are also available from the menu "Draw > BezierSpline curves > Documentation..."
      Quickcard BezierSpline - English - v1.2.pdf
      Quickcard BezierSpline - French - v1.2.pdf
      Quickcard BezierSpline - Portuguese - v1.2.pdf
      Tutorial BezierSpline - English - v1.2.pdf
      • Language: English, French, Portuguese, Hungarian, German, Spanish (thanks to all kind translators).
      • Menus: by default, it is installed in Draw > BezierSpline curves…
      • Icon toolbar: Most of the tools are present on the toolbar (unfortunately, not adjustable unless you remove the icon files in BZ_Dir_14/IMAGES_CadFather)
      http://forums.sketchucation.com/download/file.php?id=49287
      There are now multiple ways to install scripts
      • SCF Plugin Store (SU8 and SU13) - recommended method
      • Unzip (all SU versions and for installations in an alternate Plugins directory)
      • Extension Manager with RBZ files (SU8 and SU13)
      If you run SU8, SU13, SU14, SU2015, or SU2016 the strongly recommended installation method is to Autoinstall with the SCF Plugin Store tool.
      Otherwise, you can download the BezierSpline.rbzfile from the Plugin Store page for BezierSpline.
      Whatever way you install, you must end up with the following footprint:
      **Note for SU6 and SU7 users, download the rbz file from the plugin store page, and change its extension from .rbz to .zip
      Then:
      1. Open the zip archive
      2. Select All (Ctrl A)
      3. Extract into the Sketchup Plugin Directory
      4. Answer YES to OVERWRITE all existing files if any
      5. Make sure you get the correct footprint (one rb file and one folder)**
        The standard SU Plugins root directories are:
        Windows SU8: C:\Program Files\Google\Google SketchUp 8\Plugins
        Windows SU13: C:\Program Files\SketchUp\SketchUp 2013/Plugins
        Windows SU14: C:\Users<username>\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
        Windows SU15: C:\Users<username>\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins
      Mac SU8: Macintosh HD/Library/Application Support/Google SketchUp 8/SketchUp/Plugins
      Mac SU13: ~/Library/Application Support/SketchUp 2013/SketchUp/Plugins
      Mac SU14: ~/Library/Application Support/SketchUp 2014/SketchUp/Plugins
      Mac SU15: ~/Library/Application Support/SketchUp 2015/SketchUp/Plugins
      CAUTION: NEVER rename or move files from their folders. If you are unsure of your unzip operation, do it in a neutral folder and check that you reconstruct the right footprint. Then transfer the folders and files to the SU Plugin Directory.
      http://forums.sketchucation.com/download/file.php?id=49284
      http://forums.sketchucation.com/download/file.php?id=49288
      Curves are created by entering the control points. By default, all curves, except Classic Bezier requires to enter control points in sequence. Classic Bezier requires entering the first and last points, and then the other middle points.
      You can later Edit a selected curve via the contextual menu β€œBZ - Edit <name of curve>….”
      You can also Convert or Transform a curve via the contextual menu β€œBZ – Convert….” and β€œBZ – Transform (control points)….”
      • You can enter the precision in the VCB as a number followed by β€˜s’
      • For loops, you can specify the number of segments as a number followed by β€˜c’
      • Type F8 to close the curve by a segment
      • Type F9 to close the curve by a nice curve (based on Bezier)
      • Type TAB to access a dialog box for extra parameters when applicable
      • Type F5 to toggle the visibility of vertex (displayed as small blue points)
      • It is always a good idea to check the contextual menu to see which options are available
      http://forums.sketchucation.com/download/file.php?id=49289
      BezierSpline 2.2a – 22 Apr 21:
      Performance contextual menu
      BezierSpline 2.1b – 14 Apr 21:
      Prevent a conflict with offset.rb (by RickW)
      BezierSpline 2.1a – 01 Nov 18:
      Fix for size of toolbar icons
      BezierSpline 2.0a – 01 Aug 18:
      Fix for non-ascii Windows username and repackaging
      BezierSpline 1.9b – 25 Feb 18:
      Increased the number of poinst and control points
      Here is the start post for this release
      BezierSpline 1.9c – 31 Jul 18:
      BezierSpline 1.9a – 12 Feb 17:
      Release certified for SU2017
      BezierSpline 1.8a – 13 Nov 15:
      Maintenance release
      BezierSpline 1.7c – 23 Mar 15:
      Remove traces at startup of Sketchup - second trial
      BezierSpline 1.7b – 22 Mar 15:
      BezierSpline 1.7a – 19 Oct 14:
      Fixes when the username contains non-ascii characters (SU14).
      BezierSpline 1.6d – 04 Mar 14:
      Fixes another bug in Dog Bone curves (radius was not respected), as signaled by Robert Wan
      BezierSpline 1.6c – 03 Mar 14:
      Fixes a bug in Dog Bone curves (radius was not respected), as signaled by Robert Wan
      BezierSpline 1.6b – 12 Nov 13:
      Technical release for future Sketchup compatibility.
      It also seems to fix the crash encountered on some Mac with SU13
      BezierSpline 1.6a – 11 Nov 13:
      BezierSpline 1.4f – 23 Jan 11:
      • Improve performance for contextual menu when selection is big (thanks to ThomThom and Jim for signaling)
      BezierSpline 1.4e – 10 Nov 10:
      • Integrated the Spanish translation by Oxer
      BezierSpline 1.4 – 07 Nov 10: bug fixing
      • Fix an issue concerning contextual menu performance for huge models
      BezierSpline 1.4 – 02 Sep 10: Important update
      • Fix a bug for state of the toolbar on Mac
      • Added a menu to check for updates on Sketchucation (it links to this post)
      • Integrated updated icons by CadFather
      BezierSpline 1.4 – 16 Aug 10: Important update
      • Several bugs fixed
      • Transformation of curves based on sharing control points
      BezierSpline 1.3 – 31 Jan 10: Stable version
        tomasz
        Thanks a lot Fredo! πŸ‘
        Tomasz
        Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
          AndriyG81
          thank you very much, amazin update
          http://andriyg.com
          • W Offline
            watkins
            Dear Frodo,
            Many thanks for all your hard work. I have downloaded your files for a fresh install, but note that LibTraductor.rb is not there in the unzipped folder. This is not a problem for those who already have your plugin as they can use the existing file, but it might be a problem for new users unless LibTraductor.rb is a native SU file (is it?).
            Does one leave the desired icons inside their folder or move them up one to the BZ_Dir folder?
            Kind regards,
            Bob
            • fredo6F Offline
              You are right, thanks. I completely forgot LibTraductor.rb (which not Sketchup native, but mine). Actually, for those using my other plugins, it is present anyway, but for newcomers, it wouldbe missing.
              I updated the archive in the main message of this post.
              For the cions, I don't understand what you mean. Can you clarify.
                sepo
                Thanks Fredo...your efforts to help comunity is really great.
                • W Offline
                  watkins
                  Dear Frodo,
                  Inside the BZ_Dir folder you have two folders: IMAGES_CADFather and IMAGES_ Standard.
                  Does one leave the icons inside these folders or does one move the icons of choice into the BZ-Dir folder?
                  Kind regards,
                  Bob
                  • fredo6F Offline
                    Bob,
                    The old icons are in IMAGES_Standard, but by default you get CadFather's ones. Unfrotunately, this Plugin is still behind my others, and I don't provide an easy option to switch between icon collections.
                    If you have your owns, drop them into the IMAGES_CadFather folder.
                    The convention is _24 and _16 for large and small icons.
                    • W Offline
                      watkins
                      Dear Fredo,
                      All working fine. Thanks for everything.
                      Regards,
                      Bob
                      • W Offline
                        Whaat
                        This is quality work Fredo. Thanks very much!
                        • CadFatherC Offline
                          CadFather
                          hats off for Fredo! 😎
                            putnik
                            Fredo6, much appreciated! Thanks for taking the time to put all the bits and pieces together.
                            http://keshas.info
                              mateo soletic
                              Thank You. πŸ‘
                              [Concept Illustrations](http://concept-illustrations.com/)
                                CadFather
                                ...is there a way to divide a curve by an equal number of segments or am i talking a different plug in?
                                • plot-parisP Offline
                                  plot-paris
                                  thanks a lot fredo. it is great to find everything in one place. now I can be sure to have the latest version πŸ‘
                                  interesting question indeed (although I believe we should just read your manual πŸ˜„ )
                                  • V Offline
                                    viga1978
                                    Thank you
                                      marne
                                      Thanks Fredo, very useful! πŸ‘
                                      • U Offline
                                        urs0815
                                        great tool!
                                        great update!
                                        thank you!!!
                                          CadFather
                                          you're right there PlotParis, i do read 'too fast' sometimes.. πŸ’š so i went and reread it but what i am looking for is not the precision parameter (think that's what you mean) - rather a way of dividing the spline.. perhaps like we do for a simple line (right click, divide) or by input box.
                                          when i change the precision points and then explode the curve - the split segments do not match the change.
                                          the idea is to use the bezier curve for flightpath - the option of changing the division would give a handle on smoother frame transitions etc..
                                          am i on a path?
                                            plot-paris
                                            CadFather, I have to admit, I didn't mean anything. just had the situation several times, that I was looking for some function with fredo's plugins for hours - but everything was explained in detail in his superb manuals πŸ˜„
                                            ah, I see, you want to use it for flightpath. I think to have an even distribution of segments is not necessary, for flightpath automatically adjusts each scene transition time to match a constant speed (at least flightpath2 does it).
                                            I tend to reset these modified times to default (with the TimeTransitionEditor script of the Presentation bundle (14$ at smustard) so that I can influence the animation speed with differing segment distribution along the curve...
                                            but nonetheless I would appreciate a tool that creates an even distribution of segments throughout the whole curve. would come in quite handy sometimes. if you extrude the shape to have a curved wall for example. if all the segments are the same length it is far easier to use the same window component on this wall...
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 22
                                            • 23
                                            • 13 / 23
