    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.1m Views 183 Watching
    • T
      tomasz
      Thanks a lot Fredo! πŸ‘
      Tomasz
        AndriyG81
        thank you very much, amazin update
        http://andriyg.com
        • W
          watkins
          Dear Frodo,
          Many thanks for all your hard work. I have downloaded your files for a fresh install, but note that LibTraductor.rb is not there in the unzipped folder. This is not a problem for those who already have your plugin as they can use the existing file, but it might be a problem for new users unless LibTraductor.rb is a native SU file (is it?).
          Does one leave the desired icons inside their folder or move them up one to the BZ_Dir folder?
          Kind regards,
          Bob
          • fredo6F
            You are right, thanks. I completely forgot LibTraductor.rb (which not Sketchup native, but mine). Actually, for those using my other plugins, it is present anyway, but for newcomers, it wouldbe missing.
            I updated the archive in the main message of this post.
            For the cions, I don't understand what you mean. Can you clarify.
              sepo
              Thanks Fredo...your efforts to help comunity is really great.
              • W
                watkins
                Dear Frodo,
                Inside the BZ_Dir folder you have two folders: IMAGES_CADFather and IMAGES_ Standard.
                Does one leave the icons inside these folders or does one move the icons of choice into the BZ-Dir folder?
                Kind regards,
                Bob
                1 Reply Last reply πŸ‘
                • fredo6F
                  Bob,
                  The old icons are in IMAGES_Standard, but by default you get CadFather's ones. Unfrotunately, this Plugin is still behind my others, and I don't provide an easy option to switch between icon collections.
                  If you have your owns, drop them into the IMAGES_CadFather folder.
                  The convention is _24 and _16 for large and small icons.
                  • W
                    watkins
                    Dear Fredo,
                    All working fine. Thanks for everything.
                    Regards,
                    Bob
                    • W
                      Whaat
                      This is quality work Fredo. Thanks very much!
                      • CadFatherC
                        CadFather
                        hats off for Fredo! 😎
                        • P
                          putnik
                          Fredo6, much appreciated! Thanks for taking the time to put all the bits and pieces together.
                          http://keshas.info
                            mateo soletic
                            Thank You. πŸ‘
                            Concept Illustrations
                            • CadFatherC
                              CadFather
                              ...is there a way to divide a curve by an equal number of segments or am i talking a different plug in?
                              • plot-parisP
                                plot-paris
                                thanks a lot fredo. it is great to find everything in one place. now I can be sure to have the latest version πŸ‘
                                interesting question indeed (although I believe we should just read your manual πŸ˜„ )
                                • V
                                  viga1978
                                  Thank you
                                    marne
                                    Thanks Fredo, very useful! πŸ‘
                                    • U
                                      urs0815
                                      great tool!
                                      great update!
                                      thank you!!!
                                      • CadFatherC
                                        CadFather
                                        you're right there PlotParis, i do read 'too fast' sometimes.. πŸ’š so i went and reread it but what i am looking for is not the precision parameter (think that's what you mean) - rather a way of dividing the spline.. perhaps like we do for a simple line (right click, divide) or by input box.
                                        when i change the precision points and then explode the curve - the split segments do not match the change.
                                        the idea is to use the bezier curve for flightpath - the option of changing the division would give a handle on smoother frame transitions etc..
                                        am i on a path?
                                        • plot-parisP
                                          plot-paris
                                          CadFather, I have to admit, I didn't mean anything. just had the situation several times, that I was looking for some function with fredo's plugins for hours - but everything was explained in detail in his superb manuals πŸ˜„
                                          ah, I see, you want to use it for flightpath. I think to have an even distribution of segments is not necessary, for flightpath automatically adjusts each scene transition time to match a constant speed (at least flightpath2 does it).
                                          I tend to reset these modified times to default (with the TimeTransitionEditor script of the Presentation bundle (14$ at smustard) so that I can influence the animation speed with differing segment distribution along the curve...
                                          but nonetheless I would appreciate a tool that creates an even distribution of segments throughout the whole curve. would come in quite handy sometimes. if you extrude the shape to have a curved wall for example. if all the segments are the same length it is far easier to use the same window component on this wall...
                                            johnsenior1973
                                            Thanks for this great plugin.
                                            For me, one of the huge benefits is that it is now possible to draw much better with Sketchup. The normal Freehand draw tool in Sketchup is, quite frankly, pretty much useless. Now there's no need to use the Freehand tool, the Cubic Bezier Curve works so much better.
                                            • 22
                                            • 23
                                            • 1 / 23
