    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.1m Views 183 Watching
    • fredo6F Offline
      Bob,
      The old icons are in IMAGES_Standard, but by default you get CadFather's ones. Unfrotunately, this Plugin is still behind my others, and I don't provide an easy option to switch between icon collections.
      If you have your owns, drop them into the IMAGES_CadFather folder.
      The convention is _24 and _16 for large and small icons.
      • W Offline
        watkins
        Dear Fredo,
        All working fine. Thanks for everything.
        Regards,
        Bob
        • W Offline
          Whaat
          This is quality work Fredo. Thanks very much!
          • CadFatherC Offline
            CadFather
            hats off for Fredo! 😎
              putnik
              Fredo6, much appreciated! Thanks for taking the time to put all the bits and pieces together.
              http://keshas.info
                mateo soletic
                Thank You. πŸ‘
                [Concept Illustrations](http://concept-illustrations.com/)
                  CadFather
                  ...is there a way to divide a curve by an equal number of segments or am i talking a different plug in?
                  • plot-parisP Offline
                    plot-paris
                    thanks a lot fredo. it is great to find everything in one place. now I can be sure to have the latest version πŸ‘
                    interesting question indeed (although I believe we should just read your manual πŸ˜„ )
                    • V Offline
                      viga1978
                      Thank you
                        marne
                        Thanks Fredo, very useful! πŸ‘
                        • U Offline
                          urs0815
                          great tool!
                          great update!
                          thank you!!!
                            CadFather
                            you're right there PlotParis, i do read 'too fast' sometimes.. πŸ’š so i went and reread it but what i am looking for is not the precision parameter (think that's what you mean) - rather a way of dividing the spline.. perhaps like we do for a simple line (right click, divide) or by input box.
                            when i change the precision points and then explode the curve - the split segments do not match the change.
                            the idea is to use the bezier curve for flightpath - the option of changing the division would give a handle on smoother frame transitions etc..
                            am i on a path?
                              plot-paris
                              CadFather, I have to admit, I didn't mean anything. just had the situation several times, that I was looking for some function with fredo's plugins for hours - but everything was explained in detail in his superb manuals πŸ˜„
                              ah, I see, you want to use it for flightpath. I think to have an even distribution of segments is not necessary, for flightpath automatically adjusts each scene transition time to match a constant speed (at least flightpath2 does it).
                              I tend to reset these modified times to default (with the TimeTransitionEditor script of the Presentation bundle (14$ at smustard) so that I can influence the animation speed with differing segment distribution along the curve...
                              but nonetheless I would appreciate a tool that creates an even distribution of segments throughout the whole curve. would come in quite handy sometimes. if you extrude the shape to have a curved wall for example. if all the segments are the same length it is far easier to use the same window component on this wall...
                                johnsenior1973
                                Thanks for this great plugin.
                                For me, one of the huge benefits is that it is now possible to draw much better with Sketchup. The normal Freehand draw tool in Sketchup is, quite frankly, pretty much useless. Now there's no need to use the Freehand tool, the Cubic Bezier Curve works so much better.
                                  CadFather
                                  yes... at the moment i am doing exactly the same with PresBundle - but suppose you have a path with curves, knowing the constant segment of each camera can be useful.. (i'd love the same ease as 'divide')
                                  when you reach the curve, splitting in two gives half transition time without having to try it out first
                                  another use is the copy along path, since it behaves a bit different when copying by spacing and by nodes.. surely more would follow.. interesting.. hope Fredo's loves the idea too.. for now this is all Fredo Grace! β˜€
                                  ..and thanks for the manual! πŸ˜‰
                                  • fredo6F Offline
                                    The answer should be YES.
                                    If you have a curve, generated by BezierSpline or from native Sktechup, you can convert it to a Polyline with equal segments by 2 methods which are delivered as part of BezierSpline (via the contextual menu "Convert to":
                                      1) %(#0000BF)[**Polyline Divider**]: you specify the interval, and the extension computes the number of segments
                                      2) %(#0000FF)[**Polyline Segmentor**]: you specify the number of segments, and the extensions computes the length of segments
                                    Note that all segments will be equal, except possibly the last one (but you can adjust the last vertex anyway).
                                    Here is an example: On the left is a regular B-Spline. On the right, the curve converted by PolyLine Divider. You can modify the interval by typing TAB and setting the value in the dialog box appearing.
                                    Hope this helps
                                      CadFather
                                      Many Thanks Fredo ..that will do just fine for now. πŸ‘ πŸ˜„
                                      (think i'm going to make a request for curve divider)
                                        plot-paris
                                        fantastic, fredo! it is really great. every time I am looking for some function of your bezier curve tool, it already exists.
                                        (and surely we would have found out ourselves, if we read your manual carefully πŸ˜„
                                        what do we learn from that? READ FREDO'S MANUALS!!!)
                                          CadFather
                                          ..and he actualy writes them really well! πŸ˜†
                                            cyan.archnet
                                            THANKS A WHOLE LOT for the update!
                                            • 22
                                            • 23
                                            • 1 / 23
