    [Plugin] Smoothstep Animation
    80 Posts 50 Posters 104.0k Views 50 Watching
    • soloS
      Whaat,
      Thanks mate, that works great, I may now try GSU animation again, as I stopped using it for the exact reason you felt the need to create this great plugin.
      • MALAISEM
        MALAISE
        Thanks a lot, Whaat. I've just made simple test, pretty well smooth transitions. 👍 👍
        MALAISE
          matt77
          thank you so much!!
          this has been much needed in SU.
          Many,Many Thanks
          Matt
            What is the file format of images exported?
              matt77
              Either Jpeg or PNG..
              • B
                Ben Ritter
                Whaat,
                Thank you so very much,
                Ben
                • jcdbJ
                  jcdb
                  How do you set all scene delays to 0.0 seconds? 😕
                  http://www.acustombuilder.com
                  • spenceS
                    spence
                    jcdb,
                    Go to Model Info, under window, and then Animation, scene delay.
                    Spence
                    • PixeroP
                      Pixero
                      Thanks for a great script. 😄
                      Would it be possible to add an attribute to all the existing scenes in the model that they are "keyframes" and then add scenes for every frame in the animation with an attibute that they are "inbetweens" and add scene transition times according to your smoothstep script.
                      The script should then be able to delete all the "inbetweens" if you want to change the animation but leave the "keyframes" intact.
                      I believe this would make it work with external renderers.
                      What do you think, is it doable?
                      • jcdbJ
                        jcdb
                        @spence said:
                        jcdb,
                        Thanks spence 👍
                        • W
                          Whaat
                          That's a cool idea and definitely doable! 👍 I'll do some experimenting.
                            Jon
                            Thanks again, Whaat!
                            Jon
                            KT Team member
                              RickW
                              Unfortunately, there's currently no way to delete pages/scenes in ruby... 😞
                              RickW
                              www.smustard.com
                              • PixeroP
                                Pixero
                                Here's what Todd said at the Google Group:
                                Sketchup.active_model.entities.erase_entities(page) should work, but
                                it hangs SketchUp. It's a known and reported bug.
                                To get around this bug, do this:
                                First, make the page you want to delete the active page. Then, issue
                                this from Ruby:
                                Sketchup.send_action "pageDelete:"
                                That means it can be done even if its a work around.
                                If not we could save the model prior to using the script and then saving it after, under another name or with a "_anim" after.
                                Not the best way but it would still mean we could render a smooth animation.
                                • erikBE
                                  erikB
                                  Thanks from me to Whaat, very much needed script !
                                  greetings erikB
                                  • K
                                    kwistenbiebel
                                    Thank you Whaat!
                                    I hope you get the 'to scene tabs' method working, so we can use external render software on the animation.
                                    Great job! 👍
                                      Matt666
                                      A confirmation message box opens every attempt to delete a scene...
                                      Frenglish at its best !
                                      My scripts
                                      • PixeroP
                                        Pixero
                                        Well...lets hope Whaat finds a trick to fool SU to delete the scenes without SU knowing what happened... 😒
                                        Is
                                        entities.clear!
                                        not working either?
                                        • K
                                          kwistenbiebel
                                          Hi Whaat,
                                          Would it be a sh*tload of work for you to have this plugin make default scene tabs after smoothing the animation ? (needed for render engines)
                                          The current method (cameralines.rb,F-Spline bezier,Flightpath (or SU-animate) is kind of tedious.
                                          Your smoothstep animation ruby would be an easier 'out of the box solution' when it can create a scene tab animation.
                                          If it is a lot of work...maybe commercial?
                                          • W
                                            Whaat
                                            @kwistenbiebel said:
                                            Hi Whaat,
                                            I am curious. Which render engines are able to automatically render all scene tabs? I assume you are not manually rendering each scene tab when you are creating these types of animations.
                                            • 1 / 4
