    [Plugin] Smoothstep Animation
    80 Posts 50 Posters 98.6k Views 50 Watching
      princedragoncok
      Been looking forward to this 😍 Will give it a test tomorrow. Thank you Whaat 👍
        bianhai
        very good!
        thank you , Whaat. 👍
        • soloS Offline
          Whaat,
          Thanks mate, that works great, I may now try GSU animation again, as I stopped using it for the exact reason you felt the need to create this great plugin.
          • MALAISEM Offline
            MALAISE
            Thanks a lot, Whaat. I've just made simple test, pretty well smooth transitions. 👍 👍
            MALAISE
              matt77
              thank you so much!!
              this has been much needed in SU.
              Many,Many Thanks
              Matt
                What is the file format of images exported?
                  matt77
                  Either Jpeg or PNG..
                    Ben Ritter
                    Whaat,
                    Thank you so very much,
                    Ben
                    • jcdbJ Offline
                      jcdb
                      How do you set all scene delays to 0.0 seconds? 😕
                      http://www.acustombuilder.com
                      • spenceS Offline
                        spence
                        jcdb,
                        Go to Model Info, under window, and then Animation, scene delay.
                        Spence
                        • PixeroP Offline
                          Pixero
                          Thanks for a great script. 😄
                          Would it be possible to add an attribute to all the existing scenes in the model that they are "keyframes" and then add scenes for every frame in the animation with an attibute that they are "inbetweens" and add scene transition times according to your smoothstep script.
                          The script should then be able to delete all the "inbetweens" if you want to change the animation but leave the "keyframes" intact.
                          I believe this would make it work with external renderers.
                          What do you think, is it doable?
                          • jcdbJ Offline
                            jcdb
                            @spence said:
                            jcdb,
                            Thanks spence 👍
                            • W Offline
                              Whaat
                              That's a cool idea and definitely doable! 👍 I'll do some experimenting.
                                Jon
                                Thanks again, Whaat!
                                Jon
                                KT Team member
                                  RickW
                                  Unfortunately, there's currently no way to delete pages/scenes in ruby... 😞
                                  RickW
                                  www.smustard.com
                                  • PixeroP Offline
                                    Pixero
                                    Here's what Todd said at the Google Group:
                                    Sketchup.active_model.entities.erase_entities(page) should work, but
                                    it hangs SketchUp. It's a known and reported bug.
                                    To get around this bug, do this:
                                    First, make the page you want to delete the active page. Then, issue
                                    this from Ruby:
                                    Sketchup.send_action "pageDelete:"
                                    That means it can be done even if its a work around.
                                    If not we could save the model prior to using the script and then saving it after, under another name or with a "_anim" after.
                                    Not the best way but it would still mean we could render a smooth animation.
                                    • erikBE Offline
                                      erikB
                                      Thanks from me to Whaat, very much needed script !
                                      greetings erikB
                                        kwistenbiebel
                                        Thank you Whaat!
                                        I hope you get the 'to scene tabs' method working, so we can use external render software on the animation.
                                        Great job! 👍
                                          Matt666
                                          A confirmation message box opens every attempt to delete a scene...
                                          Frenglish at its best !
                                          My scripts
                                          • PixeroP Offline
                                            Pixero
                                            Well...lets hope Whaat finds a trick to fool SU to delete the scenes without SU knowing what happened... 😒
                                            Is
                                            entities.clear!
                                            not working either?
                                            • 1 / 4
