    [Plugin] Smoothstep Animation
    80 Posts 50 Posters 103.2k Views 50 Watching
      bianhai
      very good!
      thank you , Whaat. 👍
      • soloS Offline
        Whaat,
        Thanks mate, that works great, I may now try GSU animation again, as I stopped using it for the exact reason you felt the need to create this great plugin.
        • MALAISEM Offline
          MALAISE
          Thanks a lot, Whaat. I've just made simple test, pretty well smooth transitions. 👍 👍
          MALAISE
            matt77
            thank you so much!!
            this has been much needed in SU.
            Many,Many Thanks
            Matt
              What is the file format of images exported?
                matt77
                Either Jpeg or PNG..
                  Ben Ritter
                  Whaat,
                  Thank you so very much,
                  Ben
                  • jcdbJ Offline
                    jcdb
                    How do you set all scene delays to 0.0 seconds? 😕
                    http://www.acustombuilder.com
                    • spenceS Offline
                      spence
                      jcdb,
                      Go to Model Info, under window, and then Animation, scene delay.
                      Spence
                      • PixeroP Offline
                        Pixero
                        Thanks for a great script. 😄
                        Would it be possible to add an attribute to all the existing scenes in the model that they are "keyframes" and then add scenes for every frame in the animation with an attibute that they are "inbetweens" and add scene transition times according to your smoothstep script.
                        The script should then be able to delete all the "inbetweens" if you want to change the animation but leave the "keyframes" intact.
                        I believe this would make it work with external renderers.
                        What do you think, is it doable?
                        • jcdbJ Offline
                          jcdb
                          @spence said:
                          jcdb,
                          Thanks spence 👍
                          • W Offline
                            Whaat
                            That's a cool idea and definitely doable! 👍 I'll do some experimenting.
                              Jon
                              Thanks again, Whaat!
                              Jon
                              KT Team member
                                RickW
                                Unfortunately, there's currently no way to delete pages/scenes in ruby... 😞
                                RickW
                                www.smustard.com
                                • PixeroP Offline
                                  Pixero
                                  Here's what Todd said at the Google Group:
                                  Sketchup.active_model.entities.erase_entities(page) should work, but
                                  it hangs SketchUp. It's a known and reported bug.
                                  To get around this bug, do this:
                                  First, make the page you want to delete the active page. Then, issue
                                  this from Ruby:
                                  Sketchup.send_action "pageDelete:"
                                  That means it can be done even if its a work around.
                                  If not we could save the model prior to using the script and then saving it after, under another name or with a "_anim" after.
                                  Not the best way but it would still mean we could render a smooth animation.
                                  • erikBE Offline
                                    erikB
                                    Thanks from me to Whaat, very much needed script !
                                    greetings erikB
                                      kwistenbiebel
                                      Thank you Whaat!
                                      I hope you get the 'to scene tabs' method working, so we can use external render software on the animation.
                                      Great job! 👍
                                        Matt666
                                        A confirmation message box opens every attempt to delete a scene...
                                        Frenglish at its best !
                                        My scripts
                                        • PixeroP Offline
                                          Pixero
                                          Well...lets hope Whaat finds a trick to fool SU to delete the scenes without SU knowing what happened... 😒
                                          Is
                                          entities.clear!
                                          not working either?
                                            kwistenbiebel
                                            Hi Whaat,
                                            Would it be a sh*tload of work for you to have this plugin make default scene tabs after smoothing the animation ? (needed for render engines)
                                            The current method (cameralines.rb,F-Spline bezier,Flightpath (or SU-animate) is kind of tedious.
                                            Your smoothstep animation ruby would be an easier 'out of the box solution' when it can create a scene tab animation.
                                            If it is a lot of work...maybe commercial?
                                            • 1 / 4
