    ๐Ÿšจ Skimp | 25% Off until March 30 Buy Now
    [Plugin] Smoothstep Animation
    80 Posts 50 Posters 95.7k Views 50 Watching
    • W Offline
      Whaat
      Sorry for the delay in releasing this plugin. I've been on holidays and working on other projects. This plugin allows you to smooth out the jerky scene transitions in a SketchUp scene-tab animation. It is not intended for object animation, only native SkechUp scene animation. It cannot be used as-is to export to a rendering engine.
      Usage:
      1. Copy 'smoothStepAnim.rb' to 'Plugins' folder as usual.
      2. Notice two new self-explanatory items under 'Plugins' menu
      3. Plugin can export single frames only. The images must be joined into a movie format using other software (eg. VirtualDub)
      Issues:
      • All scene delays must be set to 0.0 seconds
      • likely more lurking...I have not tested very thoroughly. Please post bugs.
      Enjoy!
      Dale
      smoothStepAnim.rb
        remus
        Cheers,another interesting plugin form the great ideas factory (better known as you ๐Ÿ˜„ )
        • spenceS Offline
          spence
          Nice! I did a really quick test and it seems to work pretty good. I used Quicktime to create the image sequence.
          Spence
            princedragoncok
            Been looking forward to this ๐Ÿ˜ Will give it a test tomorrow. Thank you Whaat ๐Ÿ‘
              bianhai
              very good!
              thank you , Whaat. ๐Ÿ‘
              • soloS Offline
                Whaat,
                Thanks mate, that works great, I may now try GSU animation again, as I stopped using it for the exact reason you felt the need to create this great plugin.
                • MALAISEM Offline
                  MALAISE
                  Thanks a lot, Whaat. I've just made simple test, pretty well smooth transitions. ๐Ÿ‘ ๐Ÿ‘
                  MALAISE
                  La Connaissance n'a de valeur que partagรฉe
                    matt77
                    thank you so much!!
                    this has been much needed in SU.
                    Many,Many Thanks
                    Matt
                      What is the file format of images exported?
                        matt77
                        Either Jpeg or PNG..
                          Ben Ritter
                          Whaat,
                          Thank you so very much,
                          Ben
                          • jcdbJ Offline
                            jcdb
                            How do you set all scene delays to 0.0 seconds? ๐Ÿ˜•
                            http://www.acustombuilder.com
                            • spenceS Offline
                              spence
                              jcdb,
                              Go to Model Info, under window, and then Animation, scene delay.
                              Spence
                              • PixeroP Offline
                                Pixero
                                Thanks for a great script. ๐Ÿ˜„
                                Would it be possible to add an attribute to all the existing scenes in the model that they are "keyframes" and then add scenes for every frame in the animation with an attibute that they are "inbetweens" and add scene transition times according to your smoothstep script.
                                The script should then be able to delete all the "inbetweens" if you want to change the animation but leave the "keyframes" intact.
                                I believe this would make it work with external renderers.
                                What do you think, is it doable?
                                • jcdbJ Offline
                                  jcdb
                                  @spence said:
                                  jcdb,
                                  Thanks spence ๐Ÿ‘
                                  • W Offline
                                    Whaat
                                    That's a cool idea and definitely doable! ๐Ÿ‘ I'll do some experimenting.
                                      Jon
                                      Thanks again, Whaat!
                                      Jon
                                      KT Team member
                                        RickW
                                        Unfortunately, there's currently no way to delete pages/scenes in ruby... ๐Ÿ˜ž
                                        RickW
                                        www.smustard.com
                                        • PixeroP Offline
                                          Pixero
                                          Here's what Todd said at the Google Group:
                                          Sketchup.active_model.entities.erase_entities(page) should work, but
                                          it hangs SketchUp. It's a known and reported bug.
                                          To get around this bug, do this:
                                          First, make the page you want to delete the active page. Then, issue
                                          this from Ruby:
                                          Sketchup.send_action "pageDelete:"
                                          That means it can be done even if its a work around.
                                          If not we could save the model prior to using the script and then saving it after, under another name or with a "_anim" after.
                                          Not the best way but it would still mean we could render a smooth animation.
                                          • erikBE Offline
                                            erikB
                                            Thanks from me to Whaat, very much needed script !
                                            greetings erikB
                                            • 1 / 4
