    [Plugin] follow me rotate
    211 Posts 79 Posters 280.0k Views 79 Watching
    • soloS
      I have tried that without anything happening.
      • W
        wikii
        @daniel s said:
        Now works..
        thank you Wikii!!
        πŸ‘
        Solo...
        install the latest version, and under Plugins you will see "FollowAndRotate". Select first a curve and a face.
        Daniel S
          Daniel S
          Solo...
          try with the ruby console open like in the video i attach here:
          http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=12965&start=15#p94900
          And if it gives error send the error to wikii.
          For me is working now.
          Daniel S
          • soloS
            hey, It works!
            http://img407.imageshack.us/img407/2218/imageoftwist1qo2.jpg
            Thanks mate.
            • EarthMoverE
              EarthMover
              It's working for me also. Thanks sooo much wikii!!
              Content Creator at Skapeup
                silver_shadow
                %(#FFBF00)[Wheeee, thanx a million !!! β˜€]
                • bigstickB
                  bigstick
                  This is fantastic! Thanks a lot wikii!
                  • plot-parisP
                    plot-paris
                    phantastic plugin Wikii! thanks for sharing 😍
                    however, when I use a welded curve, I get very unexpected results. something doesn't seem to be working with welded paths. everything works fine if I use a bezier curve (no matter how complicated)
                    http://img205.imageshack.us/img205/3448/far01kh7.jpg
                    and I have a suggestion for a future update:
                    if you have a face with it's midpoint not at the starting point of the curve, the cuve will be moved to this centre point.
                    would it be possible to prevent this from happening, so that you can use a shape with an offset, that is twisted arround the path with a certain distance.
                    or even better, could you change the script to allow the use of several seperate faces?
                    http://img87.imageshack.us/img87/8549/far02vh5.jpg
                    • W
                      watkins
                      Any chance of making this available as a .zip file? I have problems with files with .rar extensions.
                        Funny πŸ‘ β˜€ 😎
                        Done πŸ˜‰
                        Far.zip
                        • W
                          wikii
                          Try to select one curve , one face and one construction point , then , using FAR. The construction point will be treated as the center of the face.
                          • plot-parisP
                            plot-paris
                            weird. it only works for me, if I have a curve as a path. it doesn't work with a straight line like in your example (not even the dialog box for rotation/scale input appears)...
                            but arround a curve it looks really cool! πŸ˜„
                              marcosrodrigues
                              Seems very promising, Wikii. Thank you.
                              | menos Γ© mais
                                Your are not alone πŸ˜„
                                And yet some erratic Works for 2 straight lines welded, sometimes yes, sometime no
                                yesno.skp
                                  Interesting plugin but this is what I get.
                                  http://img.photobucket.com/albums/v506/weekender410/669479e4.jpg
                                  http://img.photobucket.com/albums/v506/weekender410/99a1dcc5.jpg
                                  http://img.photobucket.com/albums/v506/weekender410/915bea9b.jpg
                                  http://img.photobucket.com/albums/v506/weekender410/0f17c9f7.jpg
                                  • W
                                    wikii
                                    select a face without it's border
                                      thank you. that works.
                                      • W
                                        watkins
                                        Dear Pilou,
                                        Thanks for posting the .zip file.
                                        Regards,
                                        Bob
                                        • free agentF
                                          free agent
                                          hey wow awsome plugin, thanx for posting, is there any way to reverse the triangulation of the faces, i noticed that once smoothed the and as you rotate the form it gets very jaggy at the edges and you have to go in there with the flip edge tool to smooth it out... any way around this within the coding?
                                          http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
                                          • jujuJ
                                            juju
                                            We have some very gifted people here, only surpassed by their generosity. Thank you (all the ruby programmers, both free and commercial) so much for SU so much than it was.
                                            • 11
                                            • 1 / 11
