    [Plugin] follow me rotate
    211 Posts 79 Posters 259.7k Views 79 Watching
    • W Offline
      wikii
      A curve path
        Daniel S
        Wikii
        I attach a video showing what iΒ΄m doing...
        still I get a error in the ruby console.
        Daniel S
        error video.zip
        • soloS Offline
          I cannot seem to get it to work, I see it in the plugin drop down menu, but when I select it it does nada, does it work like follow me tool? if yes then I cannot seem to figure it out.
          • W Offline
            wikii
            Select welded edges as path and a face before using this script.
            • W Offline
              wikii
              Sorry , I modified two classes.
              Please download again
                Daniel S
                Now works..
                thank you Wikii!!
                πŸ‘
                Solo...
                install the latest version, and under Plugins you will see "FollowAndRotate". Select first a curve and a face.
                Daniel S
                • soloS Offline
                  I have tried that without anything happening.
                  • W Offline
                    wikii
                    @daniel s said:
                    Now works..
                    thank you Wikii!!
                    πŸ‘
                    Solo...
                    Daniel S
                      Daniel S
                      Solo...
                      try with the ruby console open like in the video i attach here:
                      http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=12965&start=15#p94900
                      And if it gives error send the error to wikii.
                      For me is working now.
                      Daniel S
                      • soloS Offline
                        hey, It works!
                        http://img407.imageshack.us/img407/2218/imageoftwist1qo2.jpg
                        Thanks mate.
                        • EarthMoverE Offline
                          EarthMover
                          It's working for me also. Thanks sooo much wikii!!
                          Content Creator at Skapeup
                            silver_shadow
                            %(#FFBF00)[Wheeee, thanx a million !!! β˜€]
                            • bigstickB Offline
                              bigstick
                              This is fantastic! Thanks a lot wikii!
                              • plot-parisP Offline
                                plot-paris
                                phantastic plugin Wikii! thanks for sharing 😍
                                however, when I use a welded curve, I get very unexpected results. something doesn't seem to be working with welded paths. everything works fine if I use a bezier curve (no matter how complicated)
                                http://img205.imageshack.us/img205/3448/far01kh7.jpg
                                and I have a suggestion for a future update:
                                if you have a face with it's midpoint not at the starting point of the curve, the cuve will be moved to this centre point.
                                would it be possible to prevent this from happening, so that you can use a shape with an offset, that is twisted arround the path with a certain distance.
                                or even better, could you change the script to allow the use of several seperate faces?
                                http://img87.imageshack.us/img87/8549/far02vh5.jpg
                                • W Offline
                                  watkins
                                  Any chance of making this available as a .zip file? I have problems with files with .rar extensions.
                                    Funny πŸ‘ β˜€ 😎
                                    Done πŸ˜‰
                                    Far.zip
                                    • W Offline
                                      wikii
                                      Try to select one curve , one face and one construction point , then , using FAR. The construction point will be treated as the center of the face.
                                        plot-paris
                                        weird. it only works for me, if I have a curve as a path. it doesn't work with a straight line like in your example (not even the dialog box for rotation/scale input appears)...
                                        but arround a curve it looks really cool! πŸ˜„
                                          marcosrodrigues
                                          Seems very promising, Wikii. Thank you.
                                          | menos Γ© mais
                                            Your are not alone πŸ˜„
                                            And yet some erratic Works for 2 straight lines welded, sometimes yes, sometime no
                                            yesno.skp
                                            • 11
                                            • 1 / 11
