    [Plugin] Scaling to_cm (UPDATED 15/02/2016)
    27 Posts 17 Posters 34.8k Views 17 Watching
      sahi
      @stanmarsh said:
      is there anyway to change it to meters?
      meters
      mashtab.zip
      • Didier BurD
        Didier Bur
        This doesn't work here: it gives weird results, out of range, entities are moved elsewhere. If entities are not grouped at start, there are grouped at the end.
        Am I missing something ???
        Before/After a scale of 2:scale.jpg
        DB
        • N
          N Lindenthal
          On Mac I did not see the scaling tool palette. Is it Menu > Plugins > Scale?
            sahi
            changed the names in a script
            Menu > Plugins > Resizer
            mashtab_1.zip
            • Didier BurD
              Didier Bur
              Dialog is ambiguous: "on all of axes" is not a target size but adds entered size to actual size. The final size would be better IMHO ?
              Why choosing the bounds center as the center of transformation ?
              I suggest not to use "to_cm" or "to_m" in the code, but to use only Length type variables. Thus you will suit everyone's unit, no matter what it is.
              Useful script, though.
              DB
                sahi
                @didier bur said:
                "on all of axes" ---How to name???
                corrected all of other as you specified
                mashtab_2.zip
                • Didier BurD
                  Didier Bur
                  Correct me if I'm wrong, but the resize operation works only for faces in XY,XZ and YZ planes (red,green,blue) ?
                  "On all of axes" -> "In every direction" ? English speaking people please help !
                  Another enhancement is to encapsulate in an operation for one step undo:
                  def mashtabirovanie_create
                  Sketchup.active_model.start_operation "Resize"
                  ss=Sketchup.active_model.selection
                  Sketchup.active_model.select_tool(nil)
                  Sketchup.active_model.commit_operation
                  DB
                    sahi
                    > end
                    Thank you! Corrected a code.
                    Added an icon.
                    mashtab_3.zip
                    • CadFatherC
                      CadFather
                      ..growing into a nice little ruby.
                        marcosrodrigues
                        Simple and very useful. Thank you!
                        | menos é mais
                        • I
                          ilay7k
                          Equal "In every direction" is global settings for object of selection(world scaling system in most graphic packages...in attached pic, like cinema4d)
                          or about directions of red,green,blue, Didier, you are right/something like object system/
                          • FletchF
                            Fletch
                            I would replace the "on all of axes" line with a checkbox called 'lock aspect ratio' as shown in attached. or just change the name to 'uniform scale'.
                            Fletch
                              sahi
                              mashtab_4.zip
                              • unclebimU
                                unclebim
                                I don't get what should I input in the Lock aspect ratio box in order to get the selection scaled proportionally to exact dimension input in one axis?
                                • Z
                                  Zacchia
                                  I like it. Thanks!
                                  • chialiang168C
                                    chialiang168
                                    尺寸不正確
                                    Size is not correct
                                    https://dl.dropboxusercontent.com/u/108539326/星野築網頁/004-應用教室/002-sketchup教室/插件應用/線組轉組件/問題插件.png
                                    • cottyC
                                      cotty
                                      Perhaps your bounding box has a different orientation than the box itself?
                                      my SketchUp gallery
                                      • jujuJ
                                        juju
                                        that would no sense if the plugin measures the bounding box instead of the geometry
                                          sahi
                                          Updated the plug-in in the first message
                                          • designerbursaD
                                            designerbursa
                                            alternative svg icon
                                            resize.zip
