    [Plugin] Scaling to_cm (UPDATED 15/02/2016)
    27 Posts 17 Posters 33.3k Views 17 Watching
      sahi
      changed the names in a script
      Menu > Plugins > Resizer
      mashtab_1.zip
      • Didier BurD Offline
        Didier Bur
        Dialog is ambiguous: "on all of axes" is not a target size but adds entered size to actual size. The final size would be better IMHO ?
        Why choosing the bounds center as the center of transformation ?
        I suggest not to use "to_cm" or "to_m" in the code, but to use only Length type variables. Thus you will suit everyone's unit, no matter what it is.
        Useful script, though.
        DB
          sahi
          @didier bur said:
          "on all of axes" ---How to name???
          corrected all of other as you specified
          mashtab_2.zip
            Didier Bur
            Correct me if I'm wrong, but the resize operation works only for faces in XY,XZ and YZ planes (red,green,blue) ?
            "On all of axes" -> "In every direction" ? English speaking people please help !
            Another enhancement is to encapsulate in an operation for one step undo:
            def mashtabirovanie_create
            Sketchup.active_model.start_operation "Resize"
            ss=Sketchup.active_model.selection
            Sketchup.active_model.select_tool(nil)
            Sketchup.active_model.commit_operation
            DB
              sahi
              > end
              Thank you! Corrected a code.
              Added an icon.
              mashtab_3.zip
              • CadFatherC Offline
                CadFather
                ..growing into a nice little ruby.
                  marcosrodrigues
                  Simple and very useful. Thank you!
                  | menos é mais
                  • I Offline
                    ilay7k
                    Equal "In every direction" is global settings for object of selection(world scaling system in most graphic packages...in attached pic, like cinema4d)
                    or about directions of red,green,blue, Didier, you are right/something like object system/
                    • FletchF Offline
                      Fletch
                      I would replace the "on all of axes" line with a checkbox called 'lock aspect ratio' as shown in attached. or just change the name to 'uniform scale'.
                      Fletch
                        sahi
                        mashtab_4.zip
                        • unclebimU Offline
                          unclebim
                          I don't get what should I input in the Lock aspect ratio box in order to get the selection scaled proportionally to exact dimension input in one axis?
                          • Z Offline
                            Zacchia
                            I like it. Thanks!
                            • chialiang168C Offline
                              chialiang168
                              尺寸不正確
                              Size is not correct
                              https://dl.dropboxusercontent.com/u/108539326/星野築網頁/004-應用教室/002-sketchup教室/插件應用/線組轉組件/問題插件.png
                              • cottyC Offline
                                cotty
                                Perhaps your bounding box has a different orientation than the box itself?
                                my SketchUp gallery
                                • jujuJ Offline
                                  juju
                                  that would no sense if the plugin measures the bounding box instead of the geometry
                                    sahi
                                    Updated the plug-in in the first message
                                    • designerbursaD Offline
                                      designerbursa
                                      alternative svg icon
                                      resize.zip
                                        TeamCVZ
                                        Should it work with SU19 ?
