    [Plugin] Scaling to_cm (UPDATED 15/02/2016)
    27 Posts 17 Posters 28.6k Views 17 Watching
      sahi
      Changes in the size of the selection or groups or components
      Changes in the size of the groups or components
        pav_3j
        sorry i'm confused, is this a scaling ruby?
        pav
        Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
          sahi
          changes a model size.
            pav_3j
            ah i see! i shall have a tinkle and see how i get on.
            pav
            • urgenU Offline
              urgen
              ...it is "resize tool" more.. by axis... Useful idea,SAHI! 😄
              http://img98.imageshack.us/img98/7785/55555aaoz1.jpg
              --pupil forever...------
                stanmarsh
                hi sahi thanks for this ruby! 😍
                is there anyway to change it to meters?
                  sahi
                  meters
                  mashtab.zip
                  • Didier BurD Offline
                    Didier Bur
                    This doesn't work here: it gives weird results, out of range, entities are moved elsewhere. If entities are not grouped at start, there are grouped at the end.
                    Am I missing something ???
                    Before/After a scale of 2:scale.jpg
                    DB
                    • N Offline
                      N Lindenthal
                      On Mac I did not see the scaling tool palette. Is it Menu > Plugins > Scale?
                        sahi
                        changed the names in a script
                        Menu > Plugins > Resizer
                        mashtab_1.zip
                          Didier Bur
                          Dialog is ambiguous: "on all of axes" is not a target size but adds entered size to actual size. The final size would be better IMHO ?
                          Why choosing the bounds center as the center of transformation ?
                          I suggest not to use "to_cm" or "to_m" in the code, but to use only Length type variables. Thus you will suit everyone's unit, no matter what it is.
                          Useful script, though.
                          DB
                            sahi
                            @didier bur said:
                            "on all of axes" ---How to name???
                            corrected all of other as you specified
                            mashtab_2.zip
                              Didier Bur
                              Correct me if I'm wrong, but the resize operation works only for faces in XY,XZ and YZ planes (red,green,blue) ?
                              "On all of axes" -> "In every direction" ? English speaking people please help !
                              Another enhancement is to encapsulate in an operation for one step undo:
                              def mashtabirovanie_create
                              Sketchup.active_model.start_operation "Resize"
                              ss=Sketchup.active_model.selection
                              Sketchup.active_model.select_tool(nil)
                              Sketchup.active_model.commit_operation
                              DB
                                sahi
                                > end
                                Thank you! Corrected a code.
                                Added an icon.
                                mashtab_3.zip
                                • CadFatherC Offline
                                  CadFather
                                  ..growing into a nice little ruby.
                                    marcosrodrigues
                                    Simple and very useful. Thank you!
                                    | menos é mais
                                    • I Offline
                                      ilay7k
                                      Equal "In every direction" is global settings for object of selection(world scaling system in most graphic packages...in attached pic, like cinema4d)
                                      or about directions of red,green,blue, Didier, you are right/something like object system/
                                      • F Offline
                                        Fletch
                                        I would replace the "on all of axes" line with a checkbox called 'lock aspect ratio' as shown in attached. or just change the name to 'uniform scale'.
                                        Fletch
                                        Twilight Render Cross-platform Plugin for SketchUp on PC or Mac
                                          sahi
                                          mashtab_4.zip
                                          • unclebimU Offline
                                            unclebim
                                            I don't get what should I input in the Lock aspect ratio box in order to get the selection scaled proportionally to exact dimension input in one axis?
