    [Plugin] Scaling to_cm (UPDATED 15/02/2016)
    27 Posts 17 Posters 34.8k Views 17 Watching
    • Didier BurD
      Didier Bur
      Correct me if I'm wrong, but the resize operation works only for faces in XY,XZ and YZ planes (red,green,blue) ?
      "On all of axes" -> "In every direction" ? English speaking people please help !
      Another enhancement is to encapsulate in an operation for one step undo:
      def mashtabirovanie_create
      Sketchup.active_model.start_operation "Resize"
      ss=Sketchup.active_model.selection
      Sketchup.active_model.select_tool(nil)
      Sketchup.active_model.commit_operation
      DB
        sahi
        > end
        Thank you! Corrected a code.
        Added an icon.
        mashtab_3.zip
        • CadFatherC
          CadFather
          ..growing into a nice little ruby.
            marcosrodrigues
            Simple and very useful. Thank you!
            | menos é mais
            • I
              ilay7k
              Equal "In every direction" is global settings for object of selection(world scaling system in most graphic packages...in attached pic, like cinema4d)
              or about directions of red,green,blue, Didier, you are right/something like object system/
              • FletchF
                Fletch
                I would replace the "on all of axes" line with a checkbox called 'lock aspect ratio' as shown in attached. or just change the name to 'uniform scale'.
                Fletch
                  sahi
                  mashtab_4.zip
                  • unclebimU
                    unclebim
                    I don't get what should I input in the Lock aspect ratio box in order to get the selection scaled proportionally to exact dimension input in one axis?
                    • Z
                      Zacchia
                      I like it. Thanks!
                      • chialiang168C
                        chialiang168
                        尺寸不正確
                        Size is not correct
                        https://dl.dropboxusercontent.com/u/108539326/星野築網頁/004-應用教室/002-sketchup教室/插件應用/線組轉組件/問題插件.png
                        • cottyC
                          cotty
                          Perhaps your bounding box has a different orientation than the box itself?
                          my SketchUp gallery
                          • jujuJ
                            juju
                            that would no sense if the plugin measures the bounding box instead of the geometry
                              sahi
                              Updated the plug-in in the first message
                              • designerbursaD
                                designerbursa
                                alternative svg icon
                                resize.zip
                                • T
                                  TeamCVZ
                                  Should it work with SU19 ?
                                  • 2 / 2
