    [Plugin] Scaling to_cm (UPDATED 15/02/2016)
    27 Posts 17 Posters 34.0k Views 17 Watching
    • CadFatherC Offline
      CadFather
      ..growing into a nice little ruby.
        marcosrodrigues
        Simple and very useful. Thank you!
        | menos é mais
        • I Offline
          ilay7k
          Correct me if I'm wrong, but the resize operation works only for faces in XY,XZ and YZ planes (red,green,blue) ?
          "On all of axes" -> "In every direction" ? English speaking people please help !
          Equal "In every direction" is global settings for object of selection(world scaling system in most graphic packages...in attached pic, like cinema4d)
          or about directions of red,green,blue, Didier, you are right/something like object system/
          • FletchF Offline
            Fletch
            I would replace the "on all of axes" line with a checkbox called 'lock aspect ratio' as shown in attached. or just change the name to 'uniform scale'.
            Fletch
              sahi
              mashtab_4.zip
              • unclebimU Offline
                unclebim
                I don't get what should I input in the Lock aspect ratio box in order to get the selection scaled proportionally to exact dimension input in one axis?
                • Z Offline
                  Zacchia
                  I like it. Thanks!
                  • chialiang168C Offline
                    chialiang168
                    尺寸不正確
                    Size is not correct
                    https://dl.dropboxusercontent.com/u/108539326/星野築網頁/004-應用教室/002-sketchup教室/插件應用/線組轉組件/問題插件.png
                    • cottyC Offline
                      cotty
                      Perhaps your bounding box has a different orientation than the box itself?
                      my SketchUp gallery
                      • jujuJ Offline
                        juju
                        that would no sense if the plugin measures the bounding box instead of the geometry
                          sahi
                          Updated the plug-in in the first message
                          • designerbursaD Offline
                            designerbursa
                            alternative svg icon
                            resize.zip
                              TeamCVZ
                              Should it work with SU19 ?
                              • 2 / 2
