    [Obsolete] Component Spray Tool
    88 Posts 32 Posters 27.3k Views 32 Watching
    • jujuJ Offline
      juju
      @rv1974 said:
      Hi Didier!
      May be it was discussed earlier ..
      1.There are 2 bugs: the plug-in limits drop-down list of components (for example 290 in model is reduced to 10 in dialog).
      2.drop-down list is not stable: drop-down list of components is visible only if down arrow
      is continually pressed.
      Thanks for attention.
      For the some or other reason the grass component I want isn't showing up in the drop-down list for components to spray. I've renamed the component so the name starts with a "#" as well as with a "01" in an attempt to get it to surface to the top of the list, but it still isn't showing up.
      Does anybody have any idea how to get components onto the list that isn't showing up?
      Didier, I'm still having trouble with components not showing up. I have 30+ components in a model, yet the plugin only recognises 5, excluding the component I want to use to spray!
        rv1974
        Workaround:
        Take the host surface and cut&paste to a new blank file and complete your dirty deeds there.
        There's other problem- the script is highly buggy (of course may be my hands simply are growing from the @ss)
        1/In most cases I can't complete circle\rectangle input.Simply can't.
        2/Even if I have luck it tries to spray 809234803924789789798 components (with lowest pressure and normal radius).
        The only reason I didn't throw it away is the point mode.It's pretty predictable and stable.
        • Didier BurD Offline
          Didier Bur
          What's the difference between the 2 kinds ? (imports, DXF/DWG, own library vs SU library, etc ?)
          Check out the surface of your components. If it's a grass sprig, you're likely to get millions of them...
          Of course.
          DB
          • jujuJ Offline
            juju
            @didier bur said:
            Hi Didier, maybe I didn't express myself clearly. It shows only 5 of the 30+ components, did not mean SU version 5 components. In the meantime, I'm using the workaround suggested.
              Didier Bur
              Hi Juju,
              yes , I've understand that. Could you send me the file with the components, so I can see which one is shown and which one is'nt, because there MUST be a difference between such compos.
              Regards,
              DB
              • jujuJ Offline
                juju
                The file seem to be 10MB large already. I could try to shave some stuff off to leave you with the basics... Let me have a look. I'll send you a PM.
                  rv1974
                  @didier bur said:
                  Of course.
                  I'd be happy if you Didier could help me straighten my hands a little )
                  Here's spray.skp
                  http://www.mediafire.com/?ozzdmv9cplx
                  I can't spray component#2 at all.
                  With component#3 I get notice about zillion iterations.
                  What do I wrong?
                  P.S. After posting I finally understood πŸ˜› The plug simply doesn't work with 2d stuff (no matter linework or faces)- 3d only. Could it be fixed? 2d dummy components are good for keeping the file size light in modeling stage.
                  • plot-parisP Offline
                    plot-paris
                    it happened to me several times too, that the script only allowed you to select some of the components in the model.
                    when I made the components unique, these new comps where shown in the component spray window.
                    ps: didier, have you seen this? πŸ˜‰
                      Didier Bur
                      Sure: density is based on bounds calculations, and 2D components have a depth of zero and a height of zero. This give either a floating domain error (when dividing by zero) or zillions of instances to drop.
                      This can be fixed. Next release will accept 2d components.
                      I'm still searching why some components don't appear in the dropdown lists. I cannot reproduce the error for now.
                      And for the "too-big-list-of-50+-components-that-goes beyond-the-screen", there's no slider options for such lists. We need to ask for sliders for version 7 ( πŸ˜• ) of the API, OR use webdialogs.
                      @plot-paris: interesting, this is what Majid asked for.
                      DB
                      • jujuJ Offline
                        juju
                        Hear ya' on the sliders request Didier. How abbout if we could be able to type in the name of the component if it doesn't appear on the list. Currently that functionality isn't supported, but could be another workaround... Just trying to think a little laterally.
                        • jujuJ Offline
                          juju
                          Wow Didier, tlk about a quick turnaround time! MANY thanks, I really appreciate the trouble.
                            Didier Bur
                            Hi Juju,
                            Thancks for the SKP. It DID help me to find why some components didn't appear in the list and why some other did.
                            You know, when you take a look at the "In model" tab of your components browser, you see say, 38 components. But in fact there are much more components loaded in the model definitions list: groups, images, and internal components. In your file there are 184 of them ! Fortunately I discovered a ruby method to distinguish which component is shown or not in the browser. What's shown is what you must have in the list. I replaced my old buggy function with this method and (drumroll) all went well: 38 components in list.
                            So I've some good news for you: version 1.12 has been uploaded at the top of this thread.
                            I've also corrected the "zillions of comps" bug when using flat 2D components. Now the scripts supports wire components either in X,Y,orZ.
                            Webdialogs to come in version 1.13 ... And maybe proxies too.
                            Regards,
                            DB
                              plot-paris
                              Didier, this is great news! thanks a lot for the uptate! πŸ‘
                              • ToboboT Offline
                                Tobobo
                                Didier,
                                You are a true legend!
                                Toby
                                Philippians 4:13
                                  Just a quick workaround idea for 2D components:
                                  Modify the component definition by adding a vertical line to the face on the red%green plane (to give it more than 0 depth) and use the script. Afterwards you can always delete this line (and of course it will be deleted from all instances).
                                    rv1974
                                    http://img65.imageshack.us/img65/4219/screenshot055ns0.jpg
                                    http://img65.imageshack.us/img65/4219/screenshot055ns0.8ee385c8ed.jpg
                                      Didier Bur
                                      Hi Gaieus,
                                      No need to do that now. Component with a single line in it will work, either a XY line,XZ line or YZ line, or a flat surface, whatever you like.
                                      DB
                                      • david_hD Offline
                                        david_h
                                        I have a 2D flower comp (Always face camera) and I can't seem to get this to do anything. It goes thru the dialogues, etc, but then after I click okay .. .nothing. . . .I even added the little line to make it a 3D comp. Nuthin'!!!
                                        help please. .. .
                                          plot-paris
                                          did you specify a layer? everytime I left this one blank, it did'nt work for me
                                            j_forrester
                                            Anyone seen this warning dialoge before?
                                            Cant seem to get the plugin to work.
                                            Many thanks
                                            • 3 / 5
