    [Plugin] UVTools v0.1
    180 Posts 71 Posters 122.4k Views 71 Watching
      kwistenbiebel
      Oh cool!
      You weren't referring to the projected method are you?
      ...but to the method to texture a cilinder, right? (as in the video tuorials that once were on the official SU site).
      • StinkieS Offline
        Stinkie
        Like, turning on "hidden geometry", then sample the texture, and paint it on the faces that have appeared due to turning on "hidden geo"? ❓
        • soloS Offline
          If you smooth the corners (bevel) and apply that awesome arroway texture, would it not work?
          • StinkieS Offline
            Stinkie
            Maybe. Another way, I guess, might be drawing vertical lines between the corner (which would have to be, errrr, "arc-ular" 😄 )and the walls it connects. Then use cylindrical mapping on the "corner part". You'd have to sample the texture from the "corner" part prior to painting it to the rest of the walls, I think, as Whaat's plugin seems to mess alittle with the scale of the textures. Hope this makes sense.
            • soloS Offline
              I do not have the right texture, however the one I used should do, I used standard SU mapping (not projected) and got the following result.
              http://img242.imageshack.us/img242/6005/smoothtextestok7.jpg
              http://img518.imageshack.us/img518/7982/2008062116515420spx5.jpg
              • StinkieS Offline
                Stinkie
                Looks good. Another problem solved. 👍
                  kwistenbiebel
                  Thanks my friends.
                  So the easiest texturing tool of all takes care of this. Sometimes Sketchup surprises me 😄
                  • W Offline
                    Whaat
                    Here's the test I promised.
                    I only used the built-in SU texture tools as I described in previous post.
                    Rendered in Indigo 1.1.5 using displacement mapping. Current beta version of SkIndigo may not produce this same result. (This is my unreleased working version)
                    One extra step that I had to do to keep the edge from 'ripping' apart with the displacement mapping was to 'soften' the edges first in SU.
                    EDIT: I also should point out that I did not bevel or round the edges at all to get this result.
                    • StinkieS Offline
                      Stinkie
                      Cool. The "soften" thing's a good tip! Thanks.
                        kwistenbiebel
                        • soloS Offline
                          Another moon wrap.
                          http://img48.imageshack.us/img48/9475/moon1dl7.jpg
                          http://img48.imageshack.us/img48/8757/moon2ju7.jpg
                          Displacement added and quick animation.
                          http://img48.imageshack.us/img48/6804/moonsj4.gif
                          • soloS Offline
                            I used Vue 6 xsream for the above, I export as .avi and use corel animation suite to create the .gif and optimise.
                              lewiswadsworth
                              What are you using to make the animated gif, Pete?
                              col sporcar si trova
                                Cool texturing, Pete, though I think (if the image is tilable) you should scale it down by 2 or 4 or something. With so big craters it suggests that so big bombing of meteorites happened here that your moon would've exploded already 😄
                                • W Offline
                                  watkins
                                  Yes, it looks more like Phobos
                                  403 Forbidden
                                  (blog.wired.com)
                                  • Alan FraserA Offline
                                    Alan Fraser
                                    AS far as the stonework on the corner goes, my first thought was that as long as the walls are vertical, there ought to be no problem simply wrapping the texture around the corner using SU's "old" mapping tools. It's basically exactly the same as wrapping a label around a wine bottle...something that's been possible since (I think) V4.
                                    Dale's little experiment seems to bear this out.
                                    3D Figures
                                      kwistenbiebel
                                      It still remains difficult to get a texture wrapped around an object in a lot of cases.
                                      Even though I was able to remake Whaats example, on other, more subdivided structures, it is not that easy.
                                      I had to give up on this one:
                                      SU screen:
                                      http://i140.photobucket.com/albums/r3/kwistenbiebel1/disSU.jpg
                                      Indigo:
                                      http://i140.photobucket.com/albums/r3/kwistenbiebel1/disindigo.jpg
                                      • plot-parisP Offline
                                        plot-paris
                                        but it nevertheless looks great 😄
                                        honestly, the creators of this impressive ancient arch may have wanted to put an emphasis on the corner by using different stones (it even looks a bit like shells).
                                        which renderer did you use? fry?
                                          johnsenior1973
                                          Indigo. It's just above the picture.
                                            plot-paris
                                            how right you are. I missed that. thanks for pointing out,johnsenior1973.
                                            so thats the new version of indigo with displacement!?! 😲
                                            cool, should try that one out too (but I tink I will wait until the stable release. mine is an office computer after all 😄 )
                                            • 2 / 9
