    [Plugin] UVTools v0.1
    180 Posts 71 Posters 150.6k Views 71 Watching
    • W Offline
      Whaat
      @kwistenbiebel said:
      I would love to be able to UV-map textures like in this example, to go around (smooth)corners:
      (Do mind that a displacement map was added.)
      'wrap around' mapping?:
      You can already do this to a limited degree in SU by positioning a texture using the right-click context menu. Then, sample that texture with the ink-dropper prior to painting on an adjacent face. The UV mapping will then be continuous around the edge.
      The sample image you posted can already be done in SU. I am sure of it. I will try to recreate a similar scene using displacement mapping with only SU and Indigo to test my theory.
        kwistenbiebel
        Oh cool!
        You weren't referring to the projected method are you?
        ...but to the method to texture a cilinder, right? (as in the video tuorials that once were on the official SU site).
        • StinkieS Offline
          Stinkie
          Like, turning on "hidden geometry", then sample the texture, and paint it on the faces that have appeared due to turning on "hidden geo"? ❓
          • soloS Offline
            If you smooth the corners (bevel) and apply that awesome arroway texture, would it not work?
            • StinkieS Offline
              Stinkie
              Maybe. Another way, I guess, might be drawing vertical lines between the corner (which would have to be, errrr, "arc-ular" 😄 )and the walls it connects. Then use cylindrical mapping on the "corner part". You'd have to sample the texture from the "corner" part prior to painting it to the rest of the walls, I think, as Whaat's plugin seems to mess alittle with the scale of the textures. Hope this makes sense.
              • soloS Offline
                I do not have the right texture, however the one I used should do, I used standard SU mapping (not projected) and got the following result.
                http://img242.imageshack.us/img242/6005/smoothtextestok7.jpg
                http://img518.imageshack.us/img518/7982/2008062116515420spx5.jpg
                • StinkieS Offline
                  Stinkie
                  Looks good. Another problem solved. 👍
                    kwistenbiebel
                    Thanks my friends.
                    So the easiest texturing tool of all takes care of this. Sometimes Sketchup surprises me 😄
                    • W Offline
                      Whaat
                      Here's the test I promised.
                      I only used the built-in SU texture tools as I described in previous post.
                      Rendered in Indigo 1.1.5 using displacement mapping. Current beta version of SkIndigo may not produce this same result. (This is my unreleased working version)
                      One extra step that I had to do to keep the edge from 'ripping' apart with the displacement mapping was to 'soften' the edges first in SU.
                      EDIT: I also should point out that I did not bevel or round the edges at all to get this result.
                      • StinkieS Offline
                        Stinkie
                        Cool. The "soften" thing's a good tip! Thanks.
                          kwistenbiebel
                          • soloS Offline
                            Another moon wrap.
                            http://img48.imageshack.us/img48/9475/moon1dl7.jpg
                            http://img48.imageshack.us/img48/8757/moon2ju7.jpg
                            Displacement added and quick animation.
                            http://img48.imageshack.us/img48/6804/moonsj4.gif
                            • soloS Offline
                              I used Vue 6 xsream for the above, I export as .avi and use corel animation suite to create the .gif and optimise.
                                lewiswadsworth
                                What are you using to make the animated gif, Pete?
                                col sporcar si trova
                                  Cool texturing, Pete, though I think (if the image is tilable) you should scale it down by 2 or 4 or something. With so big craters it suggests that so big bombing of meteorites happened here that your moon would've exploded already 😄
                                  • W Offline
                                    watkins
                                    Yes, it looks more like Phobos
                                    403 Forbidden
                                    (blog.wired.com)
                                    • Alan FraserA Offline
                                      Alan Fraser
                                      AS far as the stonework on the corner goes, my first thought was that as long as the walls are vertical, there ought to be no problem simply wrapping the texture around the corner using SU's "old" mapping tools. It's basically exactly the same as wrapping a label around a wine bottle...something that's been possible since (I think) V4.
                                      Dale's little experiment seems to bear this out.
                                      3D Figures
                                        kwistenbiebel
                                        It still remains difficult to get a texture wrapped around an object in a lot of cases.
                                        Even though I was able to remake Whaats example, on other, more subdivided structures, it is not that easy.
                                        I had to give up on this one:
                                        SU screen:
                                        http://i140.photobucket.com/albums/r3/kwistenbiebel1/disSU.jpg
                                        Indigo:
                                        http://i140.photobucket.com/albums/r3/kwistenbiebel1/disindigo.jpg
                                        • plot-parisP Offline
                                          plot-paris
                                          but it nevertheless looks great 😄
                                          honestly, the creators of this impressive ancient arch may have wanted to put an emphasis on the corner by using different stones (it even looks a bit like shells).
                                          which renderer did you use? fry?
                                            johnsenior1973
                                            Indigo. It's just above the picture.
                                            • 4 / 9
