    [Plugin] UVTools v0.1
    180 Posts 71 Posters 149.6k Views 71 Watching
    • majidM Offline
      majid
      i tried the ruby , but there is a problem when exporting to Kerkythea ..... it converts the shape to lots of faces whit lots of textures!!!!!!!!!!!!!! would be it reviewed to solve this problem?
      yours majid
      • FrederikF Offline
        Frederik
        Majid,
        Whaat have already provided an answer to this... 😉
        @whaat said:
        This seems to be an issue with non-triangular faces. If you can somehow triangulate the geometry prior to exporting, then the UVs should still be correct.
        My 'Polyreducer' script triangulates all of the faces of a mesh. However, it will also reduce some polys. (The minimum is 10%). Once I triangulated your spheres, I reapplied the spherical mapping and then exported to Indigo. It worked perfect! I expect it to work with other rendering engines as well.
        Another script that will triangulate faces is my 'SubD and Smooth' script (but it's not free)
        Below is made using the SubD and Smooth script and exported using SU2KT... 😄
        Works like a charm...!! 😍
        Cheers
        Kim Frederik
        • N Offline
          nektares
          indeed, just 5 mins using it and i got this result, works great
          and its so easy to use! congratulations.
          http://i249.photobucket.com/albums/gg239/nektares/uvmaps.jpg
            topmanblue
            😍 😍 thank you!!! good!!!
              Just catching up with all the news here...
              Great plugin, thanks a lot!
              I discovered however that if you want to UV map something on a reversed face, it gives a bugsplat. No worry about this at all though - at least it will teach everyone the lesson; "always orient your faces correctly"! 😉
                kwistenbiebel
                I would love to be able to UV-map textures like in this example, to go around (smooth)corners:
                (Do mind that a displacement map was added.)
                'wrap around' mapping?:
                http://i140.photobucket.com/albums/r3/kwistenbiebel1/demoscene_stone-01_1-1.jpg
                • W Offline
                  watkins
                  That lead flashing must have been rather tricky to fit!!
                  • W Offline
                    Whaat
                    You can already do this to a limited degree in SU by positioning a texture using the right-click context menu. Then, sample that texture with the ink-dropper prior to painting on an adjacent face. The UV mapping will then be continuous around the edge.
                    The sample image you posted can already be done in SU. I am sure of it. I will try to recreate a similar scene using displacement mapping with only SU and Indigo to test my theory.
                      kwistenbiebel
                      Oh cool!
                      You weren't referring to the projected method are you?
                      ...but to the method to texture a cilinder, right? (as in the video tuorials that once were on the official SU site).
                      • StinkieS Offline
                        Stinkie
                        Like, turning on "hidden geometry", then sample the texture, and paint it on the faces that have appeared due to turning on "hidden geo"? ❓
                        • soloS Offline
                          If you smooth the corners (bevel) and apply that awesome arroway texture, would it not work?
                          • StinkieS Offline
                            Stinkie
                            Maybe. Another way, I guess, might be drawing vertical lines between the corner (which would have to be, errrr, "arc-ular" 😄 )and the walls it connects. Then use cylindrical mapping on the "corner part". You'd have to sample the texture from the "corner" part prior to painting it to the rest of the walls, I think, as Whaat's plugin seems to mess alittle with the scale of the textures. Hope this makes sense.
                            • soloS Offline
                              I do not have the right texture, however the one I used should do, I used standard SU mapping (not projected) and got the following result.
                              http://img242.imageshack.us/img242/6005/smoothtextestok7.jpg
                              http://img518.imageshack.us/img518/7982/2008062116515420spx5.jpg
                              • StinkieS Offline
                                Stinkie
                                Looks good. Another problem solved. 👍
                                  kwistenbiebel
                                  Thanks my friends.
                                  So the easiest texturing tool of all takes care of this. Sometimes Sketchup surprises me 😄
                                  • W Offline
                                    Whaat
                                    Here's the test I promised.
                                    I only used the built-in SU texture tools as I described in previous post.
                                    Rendered in Indigo 1.1.5 using displacement mapping. Current beta version of SkIndigo may not produce this same result. (This is my unreleased working version)
                                    One extra step that I had to do to keep the edge from 'ripping' apart with the displacement mapping was to 'soften' the edges first in SU.
                                    EDIT: I also should point out that I did not bevel or round the edges at all to get this result.
                                    • StinkieS Offline
                                      Stinkie
                                      Cool. The "soften" thing's a good tip! Thanks.
                                        kwistenbiebel
                                        • soloS Offline
                                          Another moon wrap.
                                          http://img48.imageshack.us/img48/9475/moon1dl7.jpg
                                          http://img48.imageshack.us/img48/8757/moon2ju7.jpg
                                          Displacement added and quick animation.
                                          http://img48.imageshack.us/img48/6804/moonsj4.gif
                                          • soloS Offline
                                            I used Vue 6 xsream for the above, I export as .avi and use corel animation suite to create the .gif and optimise.
                                            • 3 / 9
