    [Plugin] UVTools v0.1
    180 Posts 71 Posters 150.6k Views 71 Watching
      topmanblue
      😍 😍 thank you!!! good!!!
        Just catching up with all the news here...
        Great plugin, thanks a lot!
        I discovered however that if you want to UV map something on a reversed face, it gives a bugsplat. No worry about this at all though - at least it will teach everyone the lesson; "always orient your faces correctly"! 😉
          kwistenbiebel
          I would love to be able to UV-map textures like in this example, to go around (smooth)corners:
          (Do mind that a displacement map was added.)
          'wrap around' mapping?:
          http://i140.photobucket.com/albums/r3/kwistenbiebel1/demoscene_stone-01_1-1.jpg
          • W Offline
            watkins
            That lead flashing must have been rather tricky to fit!!
            • W Offline
              Whaat
              You can already do this to a limited degree in SU by positioning a texture using the right-click context menu. Then, sample that texture with the ink-dropper prior to painting on an adjacent face. The UV mapping will then be continuous around the edge.
              The sample image you posted can already be done in SU. I am sure of it. I will try to recreate a similar scene using displacement mapping with only SU and Indigo to test my theory.
                kwistenbiebel
                Oh cool!
                You weren't referring to the projected method are you?
                ...but to the method to texture a cilinder, right? (as in the video tuorials that once were on the official SU site).
                • StinkieS Offline
                  Stinkie
                  Like, turning on "hidden geometry", then sample the texture, and paint it on the faces that have appeared due to turning on "hidden geo"? ❓
                  • soloS Offline
                    If you smooth the corners (bevel) and apply that awesome arroway texture, would it not work?
                    • StinkieS Offline
                      Stinkie
                      Maybe. Another way, I guess, might be drawing vertical lines between the corner (which would have to be, errrr, "arc-ular" 😄 )and the walls it connects. Then use cylindrical mapping on the "corner part". You'd have to sample the texture from the "corner" part prior to painting it to the rest of the walls, I think, as Whaat's plugin seems to mess alittle with the scale of the textures. Hope this makes sense.
                      • soloS Offline
                        I do not have the right texture, however the one I used should do, I used standard SU mapping (not projected) and got the following result.
                        http://img242.imageshack.us/img242/6005/smoothtextestok7.jpg
                        http://img518.imageshack.us/img518/7982/2008062116515420spx5.jpg
                        • StinkieS Offline
                          Stinkie
                          Looks good. Another problem solved. 👍
                            kwistenbiebel
                            Thanks my friends.
                            So the easiest texturing tool of all takes care of this. Sometimes Sketchup surprises me 😄
                            • W Offline
                              Whaat
                              Here's the test I promised.
                              I only used the built-in SU texture tools as I described in previous post.
                              Rendered in Indigo 1.1.5 using displacement mapping. Current beta version of SkIndigo may not produce this same result. (This is my unreleased working version)
                              One extra step that I had to do to keep the edge from 'ripping' apart with the displacement mapping was to 'soften' the edges first in SU.
                              EDIT: I also should point out that I did not bevel or round the edges at all to get this result.
                              • StinkieS Offline
                                Stinkie
                                Cool. The "soften" thing's a good tip! Thanks.
                                  kwistenbiebel
                                  • soloS Offline
                                    Another moon wrap.
                                    http://img48.imageshack.us/img48/9475/moon1dl7.jpg
                                    http://img48.imageshack.us/img48/8757/moon2ju7.jpg
                                    Displacement added and quick animation.
                                    http://img48.imageshack.us/img48/6804/moonsj4.gif
                                    • soloS Offline
                                      I used Vue 6 xsream for the above, I export as .avi and use corel animation suite to create the .gif and optimise.
                                        lewiswadsworth
                                        What are you using to make the animated gif, Pete?
                                        col sporcar si trova
                                          Cool texturing, Pete, though I think (if the image is tilable) you should scale it down by 2 or 4 or something. With so big craters it suggests that so big bombing of meteorites happened here that your moon would've exploded already 😄
                                          • W Offline
                                            watkins
                                            Yes, it looks more like Phobos
                                            403 Forbidden
                                            (blog.wired.com)
                                            • 4 / 9
