    Modlumi - Easy 3D modelling
    414 Posts 9 Posters 74.0k Views 9 Watching
      There is something with the display of Guide Lines! ?
      Create Guide Point fails..
      Create normal Guide lines is difficult!
      this function seems have regressed!
        Request
        Editing Points (geometry)
        Subdivide a line
        Push Pull a Line (s) like an extrude πŸ™‚
        Subdivision of a solid volume
        Multiple selection for multiple edition...
          Bug about Sweep ? 0.14 File .modl linked!
          bug_0.14.zip
            Request
            Sweep between 2 profils, 2 rails
            Or more simple first : Sweep with % πŸ™‚ (like the Move Rotate existing)
              Bug ? No Snap 3D for make the PushPull at the middle of a vertical side segment for example ?
              Put a Point Guide or a Line help not more!
                Request
                When you have made a Push Pull on a face said 2 units
                You click on another face = same Push Pull ! πŸ™‚
                  • pixelcruncherP
                    Modlumi 0.15 is out
                    Download it for Windows from https://modlumi.com/download/latest/windows, or open the browser version at https://modlumi.com/app/. If you already run 0.14 on Windows, it will offer you the update.
                    New feature
                    • Choose how many segments an arc has. As in SketchUp, type a count such as 12s and press Enter, or press + and -, before the first click or while drawing. Later arcs keep the count, from 2 to 360.
                    Fixes
                    • Textures show the right way up. Every image texture rendered upside down, including textures in imported SketchUp models. It was easy to miss on wood or brick and obvious on logos and text.
                    • Guide lines reach the edges of the view again. In 0.14 guide lines stopped partway across the screen and changed length as you orbited.
                    • Sweep tells you when the profile you point at has no face. Clicking an outline of edges with no face did nothing and showed no message. The status bar now says that the profile must be a face.
                    • The Windows installer is named after the release. The installer's file name and the version in Windows' installed apps list showed only a code such as 9dd7225. They now start with the release number: modlumi-0.15-f3066c8-Setup-x64.exe.
                    Full release notes: https://modlumi.com/docs/release-notes/
                    Thanks for the reports. Keep them coming!
                    • pixelcruncherP
                      Here's another plugin. Mind you, this is all vibe-coded; it doesn't have the same level of care as Modlumi itself. It's an experiment to see how far I could take the API and what was still lacking:
                      GitHub - thomasloockx/modlumi-kitchenmaker: Parametric kitchen cabinets for Modlumi, ported from IngeTrazo KitchenMaker V.2 for SketchUp (GPL-3.0)
                      Parametric kitchen cabinets for Modlumi, ported from IngeTrazo KitchenMaker V.2 for SketchUp (GPL-3.0) - thomasloockx/modlumi-kitchenmaker
                      GitHub (github.com)
                      If you wanna build your own plugins: https://modlumi.com/docs/guides/getting-started/
                      • KrassK
                        Krass
                        your link is off
                        Thomas I can't import image texture with the desktop version..
                        Krass
                        • pixelcruncherP
                          @Krass Thanks! The repository was still private by mistake; the link works now: https://github.com/thomasloockx/modlumi-kitchenmaker
                          About the image texture: I can't reproduce it here yet. Could you tell me:
                          • How you import it: Materials > New image material..., or a texture inside an imported .skp?
                          • What happens: an error message, or nothing at all?
                          • The image's format (PNG, JPEG, WebP, TIFF...), its size, and the folder it's in (for example, does the path have accents in it?)
                          A screenshot or the image itself would help too.
                          • pixelcruncherP
                            @pilou About your request for a sweep between 2 profiles and 2 rails: is it something like this?
                            You pick a start profile, an end profile and two rails. The section blends from one profile into the other, and the rails set where each section sits, how it turns and how wide it is. Closed profiles get capped, so you end up with a solid.
                            Mind you, this is just a demo: a vibe-coded plugin to explore what we can do with the plugin API, not a fully fleshed-out tool. But I think it could become a nice plugin. Let me know if this is what you had in mind, or what's missing.
                              This one above is perfect for the 2 Rails / Profils! Excellent for a speedy volume!
                              Of course you can add a "scalling rail" like a third rail but...
                              I had thought about also a more simple first : Sweep with % πŸ™‚ (like the% Move Rotate existing)
                              So same face Start and End but with a different size! And only one rail !
                              Both seems useful! πŸ™‚
                              • KrassK
                                Krass
                                I'm reading the instructions carefully, but I can't manage to install the plugin.
                                Krass
                                • KrassK
                                  Krass
                                  for th image import issue, it works now.
                                  For hte kitchen maker plugin. Do we only have to download plugin.json and and pic it from the plugin manger?
                                  Krass
                                    Guide Lines and Points works as expected in Web version 0.15
                                    But absolutely not in the Desktop version 0.15 ! πŸ™‚ So Bug!
                                      Request
                                      Multiple Push Pull
                                      A random selection after a True Bend for example! πŸ™‚
                                          Funny the file .modl above is just 55 Kb! πŸ˜‰
                                          neige.zip
                                          • pixelcruncherP
                                            What did you do different for the image import that it works now?
                                            I assume you only downloaded the plugin.json file, and picked that? Modlumi assumes a plugin lives in its own folder so it will pick all files surrounding that plugin.json file. You need to download the full github repo as a zip file. Sorry about that, the instructions on the GitHub repo were vague. I'm fixing that!
                                            I've put detailed instructions here: https://modlumi.com/docs/user-guide/plugins/#install-a-plugin-from-github - Can you let me know if that works?
                                            Cheers,
                                            Thomas
