    Modlumi - Easy 3D modelling
    408 Posts 9 Posters 71.1k Views 9 Watching
    • KrassK
      Krass
      your link is off
      Thomas I can't import image texture with the desktop version..
      Krass
      • pixelcruncherP
        @Krass Thanks! The repository was still private by mistake; the link works now: https://github.com/thomasloockx/modlumi-kitchenmaker
        About the image texture: I can't reproduce it here yet. Could you tell me:
        • How you import it: Materials > New image material..., or a texture inside an imported .skp?
        • What happens: an error message, or nothing at all?
        • The image's format (PNG, JPEG, WebP, TIFF...), its size, and the folder it's in (for example, does the path have accents in it?)
        A screenshot or the image itself would help too.
        • pixelcruncherP
          @pilou About your request for a sweep between 2 profiles and 2 rails: is it something like this?
          You pick a start profile, an end profile and two rails. The section blends from one profile into the other, and the rails set where each section sits, how it turns and how wide it is. Closed profiles get capped, so you end up with a solid.
          Mind you, this is just a demo: a vibe-coded plugin to explore what we can do with the plugin API, not a fully fleshed-out tool. But I think it could become a nice plugin. Let me know if this is what you had in mind, or what's missing.
            This one above is perfect for the 2 Rails / Profils! Excellent for a speedy volume!
            Of course you can add a "scalling rail" like a third rail but...
            I had thought about also a more simple first : Sweep with % πŸ™‚ (like the% Move Rotate existing)
            So same face Start and End but with a different size! And only one rail !
            Both seems useful! πŸ™‚
            • KrassK
              Krass
              I'm reading the instructions carefully, but I can't manage to install the plugin.
              Krass
              • KrassK
                Krass
                for th image import issue, it works now.
                For hte kitchen maker plugin. Do we only have to download plugin.json and and pic it from the plugin manger?
                Krass
                  Guide Lines and Points works as expected in Web version 0.15
                  But absolutely not in the Desktop version 0.15 ! πŸ™‚ So Bug!
                    Request
                    Multiple Push Pull
                    A random selection after a True Bend for example! πŸ™‚
                        Funny the file .modl above is just 55 Kb! πŸ˜‰
                        neige.zip
                        • pixelcruncherP
                          What did you do different for the image import that it works now?
                          I assume you only downloaded the plugin.json file, and picked that? Modlumi assumes a plugin lives in its own folder so it will pick all files surrounding that plugin.json file. You need to download the full github repo as a zip file. Sorry about that, the instructions on the GitHub repo were vague. I'm fixing that!
                          I've put detailed instructions here: https://modlumi.com/docs/user-guide/plugins/#install-a-plugin-from-github - Can you let me know if that works?
                          Cheers,
                          Thomas
                          • KrassK
                            Krass
                            Hello Thomas,
                            I'm not familiar with Gihub, so I still can't find any "ZIP" or "Download ZIP" button on the Github page
                            Krass
                            • KrassK
                              Krass
                              ok, I found it following your installing manual, Sorry. My impatience...
                              Krass
                              • pixelcruncherP
                                No worries! GitHub is a website where you can host program source code for free. It'll become even more important in the future because more and more non-programmers are using AI to create code. GitHub is the perfect place to share that code.
                                • KrassK
                                  Krass
                                  Krass
                                  • KrassK
                                    Krass
                                    I downloaded the zip file and first placed it on my desktop, then went to modlumi/extensions/install a plugin/; I selected the zip file and got an error.
                                    So, I moved the zip file to the user/local/modlumi/plugins folder and tried again, but got another error message.
                                    Krass
                                    • KrassK
                                      Krass
                                      Krass
                                      • pixelcruncherP
                                        @krass You need to upgrade to v0.15. Your build is out of date.
                                        • KrassK
                                          Krass
                                          thanks Thomas,
                                          The plugin is nice. Being able to place a piece of furniture aligned to the right or left with a single click is great. However, the fact that it generates groups instead of components is an issue... being able to change all the handles or the color of the cabinet bodies with a single click would be preferable.
                                          Krass
                                            If you want some ideas! πŸ™‚ TopMod is a free Killer! My TopMod little page : https://moiscript.weebly.com/topmod.html
                                            (and as you can import OBJ inside ModLumi) πŸ™‚ But...
                                            Bridge inside Vectary
                                            Bridge inside TopMod and transform !
                                            Render inside the regretted free Alpaca (after the TopMod transform of each segments! )
                                            The cool function of transform each segments!
                                            700746936_orig.gif!
                                            • 20
                                            • 21
                                            • 8 / 21
