    Modlumi - Easy 3D modelling
    408 Posts 9 Posters 71.1k Views 9 Watching
      Silly question but seems yes !
      We can lunch several versions in the same time! πŸ™‚ For my test only 2 !
      But the Ctrl + C, Ctrl + V seems not working betweem them !
      • pixelcruncherP
        Yeah πŸ™‚ That's a good idea. Do you want it to copy the selected geometry?
          Yes on some programs you can make a simple Copy Paste! πŸ™‚
          I think only selected geometry will be first the more simple! πŸ™‚
          Like this you can make some test in the same time! πŸ™‚ (depending of course of the free memory available) πŸ™‚
          A Drag & Drop will be more comfortable! But a shortCut is cool too!
          A Request : Right Click for recall the previous function... maybe yes existing in some ?
          KrassK 1 Reply Last reply
          • KrassK
            Krass @pixelcruncher
            here is the car
            @pixelcruncher C63+AMG+Coupe+W204+(1).skp
            Krass
            • KrassK
              Krass @pilou
              yes I use it everytime in the old SU
              Krass
              • pixelcruncherP
                Modlumi 0.14 is out
                Hi all,
                Modlumi 0.14 is out, in the browser at modlumi.com and for Windows: modlumi.com/download/latest/windows
                What's new
                • The Windows app now tells you when a new version is out. It checks when it starts and once a day, and shows a small notice where you can download the update, read what's new, skip that version, or close it. Help β†’ Check for Updates… checks right away, and Help β†’ Check for Updates Automatically turns the checks off. The check sends no ID and nothing about your models.
                • Choose the units new models start with. In Model Settings, Use for New Models keeps the current units, precision and suffix. Modlumi then starts in them, as does File β†’ New. Saved and imported models keep their own units. Thanks to the browser user who asked for this through the feedback form!
                Fixes
                • Rectangle and Extrude previews stay in place while you type a dimension. The typed value takes effect on Enter or a click.
                @pilou, about the version number: it goes up with each release, and this one is 0.14. From now on the desktop app tells you when a newer one is out. 0.13 doesn't check yet, so please download 0.14 from the site this one time.
                Full release notes: modlumi.com/docs/release-notes
                Cheers,
                Thomas
                  Not yet on the 0.14 the erase group on the Outliner! πŸ™‚
                  Number version of the "Installer" file is always crypted !:) modlumi-9dd7225-Setup-x64
                  0.14 on the desktop installed! πŸ™‚
                    Request:
                    does it possible to have the segment of the Arc Circle in the color of the axis after the first click ?
                    When it's snaped on it of course!
                    Now we have just the box message "On Red Axis"
                      Request
                      Have a Snap 3D when you Draw a Circle, a Polygon !
                      Seems Rectangle and Arc Circle has yet that!
                      Else it's a nightmare for make after a rotation etc...
                        There is something with the display of Guide Lines! ?
                        Create Guide Point fails..
                        Create normal Guide lines is difficult!
                        this function seems have regressed!
                          Request
                          Editing Points (geometry)
                          Subdivide a line
                          Push Pull a Line (s) like an extrude πŸ™‚
                          Subdivision of a solid volume
                          Multiple selection for multiple edition...
                            Bug about Sweep ? 0.14 File .modl linked!
                            bug_0.14.zip
                              Request
                              Sweep between 2 profils, 2 rails
                              Or more simple first : Sweep with % πŸ™‚ (like the Move Rotate existing)
                                Bug ? No Snap 3D for make the PushPull at the middle of a vertical side segment for example ?
                                Put a Point Guide or a Line help not more!
                                  Request
                                  When you have made a Push Pull on a face said 2 units
                                  You click on another face = same Push Pull ! πŸ™‚
                                    • pixelcruncherP
                                      Modlumi 0.15 is out
                                      Download it for Windows from https://modlumi.com/download/latest/windows, or open the browser version at https://modlumi.com/app/. If you already run 0.14 on Windows, it will offer you the update.
                                      New feature
                                      • Choose how many segments an arc has. As in SketchUp, type a count such as 12s and press Enter, or press + and -, before the first click or while drawing. Later arcs keep the count, from 2 to 360.
                                      Fixes
                                      • Textures show the right way up. Every image texture rendered upside down, including textures in imported SketchUp models. It was easy to miss on wood or brick and obvious on logos and text.
                                      • Guide lines reach the edges of the view again. In 0.14 guide lines stopped partway across the screen and changed length as you orbited.
                                      • Sweep tells you when the profile you point at has no face. Clicking an outline of edges with no face did nothing and showed no message. The status bar now says that the profile must be a face.
                                      • The Windows installer is named after the release. The installer's file name and the version in Windows' installed apps list showed only a code such as 9dd7225. They now start with the release number: modlumi-0.15-f3066c8-Setup-x64.exe.
                                      Full release notes: https://modlumi.com/docs/release-notes/
                                      Thanks for the reports. Keep them coming!
                                      • pixelcruncherP
                                        Here's another plugin. Mind you, this is all vibe-coded; it doesn't have the same level of care as Modlumi itself. It's an experiment to see how far I could take the API and what was still lacking:
                                        GitHub - thomasloockx/modlumi-kitchenmaker: Parametric kitchen cabinets for Modlumi, ported from IngeTrazo KitchenMaker V.2 for SketchUp (GPL-3.0)
                                        Parametric kitchen cabinets for Modlumi, ported from IngeTrazo KitchenMaker V.2 for SketchUp (GPL-3.0) - thomasloockx/modlumi-kitchenmaker
                                        GitHub (github.com)
                                        If you wanna build your own plugins: https://modlumi.com/docs/guides/getting-started/
                                        • KrassK
                                          Krass
                                          your link is off
                                          Thomas I can't import image texture with the desktop version..
                                          Krass
                                          • pixelcruncherP
                                            @Krass Thanks! The repository was still private by mistake; the link works now: https://github.com/thomasloockx/modlumi-kitchenmaker
                                            About the image texture: I can't reproduce it here yet. Could you tell me:
                                            • How you import it: Materials > New image material..., or a texture inside an imported .skp?
                                            • What happens: an error message, or nothing at all?
                                            • The image's format (PNG, JPEG, WebP, TIFF...), its size, and the folder it's in (for example, does the path have accents in it?)
                                            A screenshot or the image itself would help too.
                                            • 20
                                            • 21
                                            • 8 / 21
